Display for multi channel water expansion
Ask in here.
Ismaclst
Post by Ismaclst »
I have the multi channel water expansion and I'm using the 2014 screen. What do I need to insert into my code to display the values of each channel on the main screen?
Re: Display for multi channel water expansion
Add this to setup()
    ReefAngel.AddMultiChannelWaterLevelExpansion();  // Multi-Channel Water Level Expansion Module
Ismaclst
Post by Ismaclst »
Ok, thanks Roberto. I see that it has channels 0 through 5. If I just have the multi channel expansion and not the single, would I start out on channel 1 or channel 0?
I think it is channel 0 through 4.
Channel 0 - Single
Channel 1 through 4 - Multi-Channel
Ismaclst
Post by Ismaclst »
Oh, yeah you are right it's 0 through 4 , thanks.
