help understanding a line of code in PWM cloud effect PDE
rufessor
Post by rufessor »
Hi All-
I have the PWM module and am going line by line through the code I post below and I am trying to figure out if I missed the decleration of the variable "day" or if somehow its implicitly implied in the statement I underlined. I am a bit confused what day is referencing in the logic statment on that line... a little help please
perhaps just explain what exactly that is doing. Kinda still getting a grasp on logic in c++ as it uses different text for some comparators than VBasic which I know a bit more about.
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
Re: help understanding a line of code in PWM cloud effect P
day() is define on the time.cpp library.
It returns the day of the month.
% is modulo mathematical formula
http://arduino.cc/en/Reference/Modulo
So, that line basically finds out if today is the day for clouds based on Clouds_Every_X_Days defined within the code.
rufessor
Post by rufessor »
rimai wrote:day() is define on the time.cpp library.
That makes sense.... I was looking through the libraries but could not get into them fully on the computer I am on so I kinda wondered if it was something like that. THANKS!
I need to print them out so I can find this stuff... its going to take a WHILE to get all this in my head...
revised plan, no way can I implement anything fancy, I could load code but to modify it I need to get WAY more time with this. Just going to load that PWM program in tonight and try running lights!
I will worry about the rest over time... perhaps a long time!
