RANet Add-On
Xender
Re: RANet Add-On
Post by Xender »
Hello,
I'm using DI-O wireless which is CHACON protocol (433Mhz).
Can we have CHACON also supported?
We can use :
- USB wireless key like : Transceiver USB Rfxcom
- 433Mhz RF link kit : http://www.seeedstudio.com/depot/433Mhz ... p-127.html
- 433Mhz Wireless Serial Transceiver Module - 1 Kilometer : http://www.seeedstudio.com/depot/433Mhz ... Path=19_22
Also some of ather maybe interested with EnOcean, X10, etc
Fresh Water Aquarium 180*60*80
Salt Water Aquarium 60*60*60
Click Here to see the Video of my Fresh Water Aquarium
Re: RANet Add-On
Any news, Roberto?
Re: RANet Add-On
Yeap. I got a couple of them made and are available.
I also made one of the dimmable LED drivers and it is also working beautiful :)
I should have the RANet-ready Relay box in a couple weeks.
Re: RANet Add-On
Any news on a dimming expansion?
Re: RANet Add-On
I'm interested in the Relay box.
jegillis
Re: RANet Add-On
Post by jegillis »
How much is the RANet Add-On and LED driver going to cost me?
GiraffeCat
Re: RANet Add-On
Post by GiraffeCat »
rimai wrote:Yeap. I got a couple of them made and are available.
Okay. I hate all the darn wires. Pm me how much for the relay box and RANet add on board. The wireless LED driver looks good.
Other ideas...
1. Wireless Dimming Expansion 8 or 16 port options.
2. Wireless Jebao Driver - could just plug in the pump power and tap into that for running the electronics.
3. Wireless Dosing Pumps - as in - on when wanted vs tying up an outlet on relay box/power control expansion.
4. RACam - just a nice little hd camera on a pcb for your tank. Maybe use one of those Spark Chips you ordered.
Late,
GC
.....Your forefathers wisely set aside their compassion - Steeled themselves for what needed to be done.......
GiraffeCat
Re: RANet Add-On
I tried to PM you for instruction. Not sure if they ever got to you. LMK.
GC
Update 1054 : Still sitting in my Outbox......... This is how my day is going to go? :x
Re: RANet Add-On
I have had the same problem when trying to PM Roberto, it just sits in my outbox for a while and then eventually goes thru.
Re: RANet Add-On
It stays in outbox until I read it.
GiraffeCat
Re: RANet Add-On
rimai wrote:It stays in outbox until I read it.
Yep, I am an unintelligent bass. I am used to vBulletin, this is phpBB. Feeling sheepish. Sorry for the 3 PM's filling up your inbox.
Info sent.
Also, just wondering - How much for a 16 channel Dimming expansion? Just want to start saving for the "next round" of purchases. My expansion hub feels lonely - no one to talk to sitting in the cupboard. :lol:
Late,
GC
PS - Like any of the/my ideas for RANet?
dapg8gt
Re: RANet Add-On
Post by dapg8gt »
What is the distance on these? Like can I add on and control my frag tank in another room with the relays? Regardless it's a game changer for sure.. This will make the controller such a clean install.
Please Pm me the details, price of the add on and relays etc.. I may need start a sps sale thread to fund it since my tank is a little crowded at the moment =) ..
Re: RANet Add-On
Yes :)
The wireless module we use is rated for 300ft clear range.
Re: RANet Add-On
I updated the OP with a new video :)
RANet Add-On
Where?
Edit: nvm, doesnt show in tapatalk
Re: RANet Add-On
Damn that is so cool. Can we get an IO module?
GiraffeCat
Re: RANet Add-On
How is the RANet Relay Box code done? Just Like a standard relay expansion? Something else?
ReefAngel.StandardLights( Box1_Port3,22,13,19,0 );
or something like
ReefAngel.RANet.Relay.StandardLights( Port3,22,13,19,0);
Already added lines/file for the Dimming Expansion based on this:
http://forum.reefangel.com/viewtopic.php?f=3&t=4851
(Oh. Roberto. Is your very specific folder location in Post 6 my fault? He He :lol: )
Thank you in advance.
LMK,
GC
Re: RANet Add-On
I just got mine today and haven't set it up yet, but from what I understand it is coded like a standard relay.
GiraffeCat
Re: RANet Add-On
Sacohen wrote:I just got mine today and haven't set it up yet, but from what I understand it is coded like a standard relay.
Thanks. I was thinking that since the dimming expansion is coded the same, the relay box might be as well.
I never looked (and likely couldn't tell anyway), but I guess the new file in the libraries folder is like a new organizational structure - if it sees code for a standard relay box, but doesn't have one on the "USB" port, it goes to the RANet board next. Makes me wonder if I had both a standard relay expansion, and the RANet relay expansion, which would be Box 1? That brings up another question - How many RANet Relay boxes can I have?
Let me know if it works for you the standard code way. I doubt I am going to try and test tonight.
GC
howaboutme
Re: RANet Add-On
Post by howaboutme »
Roberto... Are you selling these to the masses? What's the price on the add on and relay?
Jack
Re: RANet Add-On
There dip switches on the side of the RANet so you fill them to be relay expansion 1 or 2.
I may be wrong, but you are limited to the same # of relay expansions as normal, which is 8.
Re: RANet Add-On
GiraffeCat wrote: That brings up another question - How many RANet Relay boxes can I have?
You can have 8 total expansion boxes. Mix/match of wired or wireless.
The wireless boxes have a dip switch on the side that you can use to set just like the expansion relay module.
GiraffeCat
Re: RANet Add-On
Sacohen wrote:.....I may be wrong, but you are limited to the same # of ...........
I have been reading on this sight for long enough to know that there are several people that are usually not wrong. :geek: :ugeek:
Thank you for all your help.
Roberto, too.
Dan
Smotz
Re: RANet Add-On
Post by Smotz »
When can we buy?
Re: RANet Add-On
I believe you need to PM Roberto. He has some in, but has not put them in the store yet.
I got mine a couple of weeks ago, but have not hooked it up because I'm setting it up for my 90 gallon upgrade that I just started.
billw
Re: RANet Add-On
Post by billw »
Any discussion of a remote temp probe? Would be great for keeping an eye on heater malfunction in the qt/frag tanks .
Re: RANet Add-On
Or a remote Salinity probe for a mixing station. Also the ability to have 2 Salinity probes.
billw
Re: RANet Add-On
Post by billw »
Sacohen wrote:Or a remote Salinity probe for a mixing station. Also the ability to have 2 Salinity probes.
Yes a probe module would be nice :)
Smotz
Re: RANet Add-On
Post by Smotz »
where are we with this project? Wondering if I should get a second RA or look in to this..
Re: RANet Add-On
The remote relay and dimming expansion are the only things available right now.
I have the relay and it works great.
