I would like to use the daylight channel to activate a relay. Can I change the name of the channel to Ro Shut Off? It will just have to be off or at 100 percent to activate a 5v relay.
Also my actinic channel is setup to activate the buzzer however when I use the lights on feature in the app it actives. Is there something I can change in the code? Thank you
Changing Daylight Channel
- ewaldsreef
- Contact:
Re: Changing Daylight Channel
For the buzzer, add this line to your loop():
LightsOverride=false;
- ewaldsreef
- Contact:
Thank you for your help. I will add in the override. Let me get it set up and post what I have.
- ewaldsreef
- Contact:
I added the finished product in the " You and your tank section"
Thank you so much!
Thank you so much!
