What is the best way to code a port to run 3 times a week?
Ask in here.
Re: What is the best way to code a port to run 3 times a wee
yes
I tried the code and it worked fine.
I'll set up the other days later.
Thanks everyone.
So if I wanted 9:05pm would it be...
ReefAngel.Relay.Off(Main_RODI);
if (weekday()==dowMonday && hour()==2105 && minute()<5)
  ReefAngel.Relay.On(Main_RODI);
no hour() only returns the hour not the time. You'd have to check minute >= 5 && < 10
So i tried this...
if (weekday()==dowSunday && hour()==9 >= 5 && < 10 && minute()<5)
and I'm getting an "expected primary-expression before '<' token" error with the line I'm working on highlighted and the 1st "(" circled.
I'm obviously missing a comma or something, but don't know where.
No. You need to check for day of the week, hour and minutes.
If you want minutes >= 5 and minutes < 10, it would be minute()>=5 && minute() <10
Ok. That makes sense.
Thanks.
So I've got this now and an still getting an error of expected ')' before 'minute'.
if (weekday()==dowSunday && hour()==11 minute()>=25 && minute()<30 && minute()<5)
I hate trying to figure out error messages. Ugh. :x
I tried putting a parenthesis () around (minute()>=25 && minute()<30 and got 11 can not be used as a function.
I figured out the error message. I was missing && in between the 11 and the minute, but it doesn't seem to be working.
The way I understand it with this code the Test+Light port, which is port 5 on the main relay, will run Tuesdays from 9:20pm to 9:25pm.
ReefAngel.Relay.Off(Test_Light);
if (weekday()==dowTuesday && hour()==21 && minute()>=20 && minute()<25 && minute()<5)
  ReefAngel.Relay.On(Test_Light);
Nothing happened at 9:20pm.
Help???
billw
Post by billw »
You have an impossible condition: minute >= 20 AND minute < 5. Those 2 conditions are mutually exclusive hence nothing happens. If you remove the " &&minute()<5" clause you should get something between 21:20 and 21:24:59.
Thanks.
I'll try it later.
That did it. Thanks again.
I put this code in to turn on the solenoid for my RO/DI unit Monday, Wednesday and Friday on last Friday the 24th.
I just noticed that it only turned on on that Friday. It didn't turn on on Monday or Yesterday (Wednesday).
Is there another way to do multiple if conditions like Roberto suggested?
//Flush RO/DI Membrane 3 times a week @ 9pm.
if (weekday()==dowMonday && hour()==21 && minute()<5)
if (weekday()==dowWednesday && hour()==21 && minute()<5)
if (weekday()==dowFriday && hour()==21 && minute()<10)
You should have just one Off at the beginning of the if statements or they will override the previous ones
Ok. I guess that is what's been happening. Thanks.
It worked perfectly.
I had a test time yesterday at 9pm, which went off fine and then it went off again tonight, as well as the other port turned on at 9:05.
Thanks for all the help.
I learned a bunch with this.
