I have problem with my lighting . I have my light setup on port 1 to go on at 5pm turn off at 2am. On the controller port 1 is red does that mean there overheat problem? Also port 2 is red which is my heater. The tank is running at 76 so no over heat problem. How do i fix this problem is my temp probe bad? Here is code. Thanks is for the help .
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port1Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port8Bit;
ReefAngel.Relay.On( Port5 );
ReefAngel.Relay.On( Port7 );
ReefAngel.DayLights( Port1 );
ReefAngel.StandardFan( Port3 );
ReefAngel.DosingPumpRepeat1( Port4 );
ReefAngel.DayLights( Port8 );
Lights won't turn on
- cosmith71
Re: Lights won't turn on
Red just means "off". Green is on.
Without seeing your memory file, it's hard to troubleshoot. Re-do your code with hard-coded values (in the wizard) and see if that works.
darkvenom
The red led on the controller is on. What does that mean?
darkvenom
Hmm what is hard coded values? How u go about doing that.. How do I pull up the memory info for u to look at?
It is either an ATO timeout or a overheat.
Generate another code with the wizard and choose hard coded settings instead of memory settings.
darkvenom
ok thanks works great now !!
