Help with 2 X Jebao Wave-makers and Application Iterface
Ask in here.
raythesaint
Post by raythesaint »
So I've been jacking with my Jebao's since I got my speed-cables in the mail last Saturday. My Jebao's are on port 5 and port 6. When using the RA Wizard for setup only port 5 seems to be operational clicking on every several minutes, I have yet to see port 6 active. I tried a custom code after reading various member posts but neither wave-maker turned on at all even though the head-unit and app said otherwise.
I have 2 X Jebao RW-8's connected by 2 speed-cables to Daylight and Actinic channel dimming ports.
This is what I was attempting to do:
1. Set custom port labels
2. Set a day wave pattern to reef crest min @30% and max @60%
one set to sync and the other to anti-sync on @14:00 and off @20:30
Set night to lagoon @30%
one set to sync and the other to anti-sync on @20:31 and off @13:59
3. Setup app control for wave-makers
I would like to change settings "intensity, mode, timer" for my wave-makers from the app or at least through the head-unit.
I will post my code hopefully someone can spot what I did wrong...
    ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port5Bit | Port7Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port7Bit;
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.On( Port5 );
    ReefAngel.Relay.On( Port7 );
//Define labels for 2014 LCD screen
#define ATO                   8
#define Reactor              7
#define WM2                  6
#define WM1                  5
#define UVL                   4
#define Heater               3
#define Skimmer            2
#define Return               1
    ReefAngel.StandardHeater( Port3,751,791 );
    ReefAngel.WavemakerRandom( Port5,30,60 );
    ReefAngel.WavemakerRandom( Port6,30,60 );
    ReefAngel.StandardATO( Port8,60 );
    ReefAngel.PWM.SetDaylight( PWMSlope(14,0,20,30,30,60,15,30) );
    ReefAngel.PWM.SetActinic( PWMSlope(14,0,21,0,30,60,15,30) );
    ReefAngel.DCPump.SetMode( ReefCrest,60,10 );
    ReefAngel.PWM.SetDaylight( PWMSlope(20,31,13,59,30) );
    ReefAngel.PWM.SetActinic( PWMSlope(20,31,13,59,30) );
    ReefAngel.DCPump.SetMode( Lagoon,30,10 );
    ReefAngel.Portal( "raythesaint" );
Re: Help with 2 X Jebao Wave-makers and Application Iterface
Port 5 and port 6 need to be set to always on.
Are you able to control them with the phone app right now?
raythesaint
N0, I can see the mode and speed but that's it. I can manipulate the port settings, initiate feed, and water change but that's about it. I forgot to mention I have a Windows phone if that makes a difference. I also forgot to mention my custom port labels did not work either. I will try setting ports 5 and 6 to always on tomorrow... Thanks
Let's do one thing at a time.
For labels: http://forum.reefangel.com/viewtopic.ph ... stomlabels
For the pump, use this code and let us know if the pumps work in short pulse mode.
    ReefAngel.DCPump.SetMode( ShortPulse,50,500 );
raythesaint
:D OK, after I loaded the code the Jebao on the daylight channel was working but actinic was not. In fact the Jebao on the actinic channel didn't even show on the display. I looked under the tank to check the speed-cable connections and I could see copper wire below the plug at the actinic dimmer port. I pushed it up and it turned on, both Jebaos are pulsing now. Still no control at the app though.
Good, so we know you can control the pumps.
Now, let's move the setting from hard coded to memory.
Replace this:
To this:
You should be able to control with app now.
raythesaint
When I changed DCPump memory to true and hit compile I got this error message:'True' was not declared in this scope?
case sensitivity is very important
raythesaint
That was it, I used upper case T for true. Code uploaded but still can't control pumps from app? Sorry for being such a pain... Thanks
Humm...
Removing this shouldn't affect it, but try.
raythesaint
No, no change, do I have to select anything or turn anything on in the app that would show the controls?
Are you talking about the android app?
raythesaint
I don't know, it's called Reef Angel remote and I downloaded it from the Windows store.
raythesaint
I just downloaded the Reef Angel app on my daughters iPad and works perfect. I can change modes, speed, and intensity. The app for the Windows phone is shight! I guess I'll be looking for a new phone now... Thanks for all your help, I feel a lot better about my RA now that I have more control.
raythesaint wrote:I just downloaded the Reef Angel app on my daughters iPad and works perfect. I can change modes, speed, and intensity. The app for the Windows phone is shight! I guess I'll be looking for a new phone now... Thanks for all your help, I feel a lot better about my RA now that I have more control.
i hear the android app is pretty good. ;)
Sent from my Moto X
raythesaint
Just bought an LG Escape 2 Android OS 5.0.2 and I installed the RA app from the Google play store. Once again I can see the mode, speed, duration and threshold but I can't change them. Do I need to enable something to do change settings of my Jebaos? Thanks
Long press on the android.
yep, long press on the value and a dialog box will popup.
I would suggest that you look through the manual i posted in the android app thread on the forum. that explains everything in detail.
Sent from my Moto X
raythesaint
Got it, long hold I will check out the manual... Thanks
01M5PWR
Post by 01M5PWR »
Ray,
I have my wavemakers set up the same way. I am currently running them via internal memory and the app settings. My question to you is, how did you get the day and night mode to change with the app?
120g High Mixed Reef
60g Cube Mixed Reef
raythesaint
Sorry for the delay, I didn't get a push notification when you posted. I'm not sure, I was looking for that too, I think day and night modes have to be stated in the code because it's not part of the default interface. If you already got it sorted out please let me know how you did it... Thanks
Yeah that needs to be programmed separately
