a heater with a back up heater?
Ask in here.
MDB1029
Post by MDB1029 »
So i have 2 heaters and i am wanting to use 1 instead of 2 for normal use and have my second one as backup/emergency use.
From looking around i think this would be what i am looking at but i modified it to fit my relay and specifications
if ( ReefAngel.Params.Temp[T1_PROBE] < (InternalMemory.HeaterTempOn_read() - 10)) { ReefAngel.Relay.On(Port3); };
if ( ReefAngel.Params.Temp[T1_PROBE] > (InternalMemory.HeaterTempOff_read() - 5)) { ReefAngel.Relay.Off(Port3); };
So IF i am right, my main heater on relay 2 and aux heater on relay 3, my internal memory is set to come on at 76.9 and off at 78.00. The aux heater will come on at 75.9 and turn off at 77.5 and these would be able to be changed from the internal memory via the temp for relay 2?
Re: a heater with a back up heater?
Looks correct :)
MDB1029
Post by MDB1029 »
Am i putting this in the correct spot?
    ReefAngel.SingleATOLow( Port5 );
    ReefAngel.MoonLights( Port7 );
    ReefAngel.DayLights( Box1_Port1 );
    ReefAngel.Relay.Set( Box1_Port2, !ReefAngel.Relay.Status( Box1_Port1 ) );
    ReefAngel.Relay.Set(Port8, now()%21600<10800);
Yeap
MDB1029
Post by MDB1029 »
Thank you again!
