Cloud and Lightning Code for Dimming Expansion
Here it is. See this thread for general instructions.
Up in the globals section (somewhere before void setup()) add this line:
int DaylightPWMValue=0;        // For cloud code
In your loop, you need to find whatever function is controlling your white lights and set it to the DaylightPWMValue variable. For example, I use something like this:
DaylightPWMValue=PWMSlopeHighRes(10,30,22,0,0,85,60,0);
 CheckCloud();
 ReefAngel.PWM.SetChannelRaw(1,DaylightPWMValue);
Which is a high res (12 bit) slope that starts at 1030, runs until 2200, starts at 0%, ends at 85%, and takes 60 minutes to ramp up and down. If this part confuses you, post your lighting control code and I can help you with it.
Essentially what this section does is set the baseline lighting for when there is no cloud going on. This is your everyday lighting routine.
At the very end of your code, after the final }, paste in all this stuff.
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 7
#define Min_Clouds_per_Day 1
#define Max_Clouds_per_Day 2
  // In this example, start cloud after noon
#define Start_Cloud_After NumMins(12,00)
#define End_Cloud_Before NumMins(21,00)
  // Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes
  // of effects or unforseen result could happen.
  // In our example, we have 510 minutes between Start_Cloud_After and End_Cloud_Before, so double the
  // 250 minutes (or 500 minutes) can fit in that 510 minutes window.
  // Add Random Lightning modes
#define Calm 0    // No lightning
#define Slow 1    // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
#define Fast 2    // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
#define Mega 3    // Lightning throughout the cloud, higher chance as it gets darker
#define Mega2 4   // Like Mega, but with more lightning
  // Example:  { Calm, Fast, Mega, Mega2 } to randomize all four modes.
  // { Mega2 } for just Mega2.  { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
  byte LightningModes[] = {Mega2,Mega,Mega};
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
  static byte lightningMode=0;
  static time_t DelayCounter=millis();    // Variable for lightning timing.
  static int DelayTime=random(1000);      // Variable for lightning timimg.
#ifdef forcecloudcalculation
  if (cloudchance==255)
#else
#endif
      randomSeed(millis());    // Seed the random number generator
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  if (cloudchance)
    //is it time for cloud yet?
      DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue/40.95,0,180)*40.95;
      if (chooseLightning)
        chooseLightning=false;
      switch (lightningMode)
      case Calm:
        break;
      case Mega:
        // Lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
          // Send the trigger
          Strike();
          DelayCounter=millis();    // If we just had a round of flashes, then lets put in a longer delay
          DelayTime=random(1000);   // of up to a second for dramatic effect before we do another round.
        break;
      case Mega2:
        // Higher lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
          Strike();
        break;
      case Fast:
          Strike();
        break;
      case Slow:
        // Slow lightning for 5 seconds in the middle of the cloud.  Suitable for slower ELN style drivers
          else lightningstatus=0;
          if (lightningstatus)
            DaylightPWMValue=4095;
            DaylightPWMValue=0;
          delay(1);
        break;
      default:
        break;
      cloudindex++;
      if (cloudindex < numclouds)
    /*ReefAngel.LCD.Clear(255,0,120,132,132);
     ReefAngel.LCD.DrawText(0,255,51,120,"00:00"); */
      int x=0;
      else x=17;
      //ReefAngel.LCD.DrawText(0,255,x,120,(cloudstart/60));
      ReefAngel.CustomVar[3]=cloudstart/60; // Write the hour of the next cloud to custom variable for Portal reporting
      else x=35;
      //ReefAngel.LCD.DrawText(0,255,x,120,(cloudstart%60));
      ReefAngel.CustomVar[4]=cloudstart%60; // Write the minute of the next cloud to custom variable for Portal reporting
    //ReefAngel.LCD.DrawText(0,255,90,120,cloudduration);
    ReefAngel.CustomVar[7]=(cloudduration);    // Put the duration of the next cloud in a custom var for the portal
    if (lightningchance)
      int x=0;
      if (((cloudstart+(cloudduration/2))/60)>=10) x=51;
      else x=57;
      //ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))/60));
      ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60;    // Write the hour of the next lightning to a custom variable for the Portal
      if (((cloudstart+(cloudduration/2))%60)>=10) x=69;
      else x=75;
      //ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60)); // Write the minute of the next lightning to a custom variable for the Portal
        ReefAngel.CustomVar[6]=(cloudstart+(cloudduration/2))%60;
void Strike()
  int a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
  for (int i=0; i<a; i++)
    // Flash on
    int newdata=4095;
    Wire.beginTransmission(0x40);      // Address of the dimming expansion module
    Wire.write(0x8+(4*1));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 1.
    Wire.write(newdata&0xff);          // Send the data 8 bits at a time.  This sends the LSB
    Wire.write(newdata>>8);            // This sends the MSB
    Wire.endTransmission();
    int randy=random(20,80);    // Random number for a delay
    if (randy>71) randy=((randy-70)/2)*100;    // Small chance of a longer delay
    delay(randy);                // Wait from 20 to 69 ms, or 100-400 ms
    // Flash off.  Return to baseline.
    newdata=ReefAngel.PWM.GetChannelValueRaw(1);   // Use the channel number you're flashing here
    Wire.beginTransmission(0x40);    // Same as above
    delay(random(30,50));                // Wait from 30 to 49 ms
    wdt_reset();    // Reset watchdog timer to avoid re-boots
  cstart*=60;
  cend*=60;
  if (n>cend) return (int) PWMStart;
As written, this flashes channel 1 on the standard 6 channel Dimming Expansion Module.
This version does not write times to the screen. That option does not work well with the new screen functions. It will write the times into the custom variables so you can see them on the portal.
What's new:
Lightning generator broken out into its own function strike() since it's somewhat longer and more complicated now for the dimming module.
Everything is in 12 bit hi-res now. This pretty much breaks "Slow" mode. I should probably just depreciate it.
As always, ask away with any questions or comments.
Re: Cloud and Lightning Code for Dimming Expansion
Reserved for future use.
Awesome Colin.
I just need to get some time to mod my lights for the control.
I still want slow mode :)
MDB1029
Post by MDB1029 »
Are you able to use this along with the sunlocation code?
Probably not without modification.
lnevo wrote:I still want slow mode :)
Fixed, just for you. :D
I think Steve would have needed it too, he just doesn't know it yet.
OK. Thanks????
Your hacking blacboxes yes?
Not yet. Still trying to set up the 90 gallon.
Colin;
How would you write this if you wanted to control 2 channels.
I have my white (Daylights) set up on Channel 0 and 2.
Would it be like this...
int DaylightPWMValue=2;        // For cloud code
or this
int DaylightPWMValue=0,2;        // For cloud code
No, it'll take a little more than that. It'll take a modification to the strike() subroutine to add the extra channel. I'll see if I can come up with something tonight after work.
Thanks.
Also the 2 white channels are offset by 30 min so would the strikes be on sync or not?
My lighting is setup like this.
ReefAngel.StandardLights( Actinic_Lights,12,0,22,0 );
ReefAngel.StandardLights( Day_Lights,12,30,21,0 );
//East to West Sunrise/Sunset Dimming
ReefAngel.PWM.SetChannel( 0, PWMSlope(12,30,20,30,0,100,60,0) );
ReefAngel.PWM.SetChannel( 1, PWMSlope(12,0,21,30,0,100,60,0) );
ReefAngel.PWM.SetChannel( 2, PWMSlope(13,0,21,0,0,100,60,0) );
ReefAngel.PWM.SetChannel( 3, PWMSlope(12,30,22,0,0,100,60,0) );
The first part just turns the relay ports on and off, but the 2nd part is the east to west dimming.
Are you using fast drivers?
I think they are slow drivers that is why Lee wanted the slow mode and said
lnevo wrote:I think Steve would have needed it too, he just doesn't know it yet.
I'm using the Evergrow Dimmable Full Spectrum D2120
Following
That complicates things a bit more since Slow is handled differently. Give me a little more time to write it up.
No problem.
Thank you.
I have it worked out in my head, just have a 12 hour work shift today. :D
That's great.
Hope your shift is not to difficult.
No rush.
Whenever you can get it together.
OK. I wasn't able to test, but I think this should do it.
Up in globals:
int DaylightPWMValue0=0;        // For cloud code, channel 0
int DaylightPWMValue2=0;        // For cloud code, chennel 2
Replace your lighting code in loop() with this:
ReefAngel.PWM.SetChannel( 1, PWMSlopeHighRes(12,0,21,30,0,100,60,0) );  // Schedule for blues
ReefAngel.PWM.SetChannel( 3, PWMSlopeHighRes(12,30,22,0,0,100,60,0) );
DaylightPWMValue0=PWMSlopeHighRes(12,30,20,30,0,100,60,0);    //  Default for whites
DaylightPWMValue2=PWMSlopeHighRes(13,0,21,0,0,100,60,0);
CheckCloud();    //  Check for cloud and slow lightning.
ReefAngel.PWM.SetChannelRaw(0,DaylightPWMValue0);  //  Write values for either default or cloud/slow
ReefAngel.PWM.SetChannelRaw(2,DaylightPWMValue2);  //  lightning if it's time.
And here's the stuff at the end.
void CheckCloud()
#else
#endif
      if (cloudchance)
  if (cloudchance)
      DaylightPWMValue0=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue0/40.95,0,180)*40.95;
      DaylightPWMValue2=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue2/40.95,0,180)*40.95;
      case Calm:
        break;
      case Mega:
          // Send the trigger
          Strike();
        break;
      case Mega2:
          Strike();
        break;
      case Fast:
          Strike();
        break;
      case Slow:
            DaylightPWMValue0=4095;
            DaylightPWMValue2=4095;
          delay(1);
        break;
      default:
        break;
      cloudindex++;
      int x=0;
      else x=17;
      else x=35;
      int x=0;
      else x=57;
      else x=75;
void Strike()
    // Flash on
    int newdata=4095;
    Wire.write(0x8+(4*0));             // 0x8 is channel 0, 0x12 is channel 1, etc.  This is channel 0.
    Wire.write(0x8+(4*2));             // 0x8 is channel 0, 0x12 is channel 1, etc.  This is channel 2.
    newdata=ReefAngel.PWM.GetChannelValueRaw(0);   // Use the channel number you're flashing here
    newdata=ReefAngel.PWM.GetChannelValueRaw(2);   // Use the channel number you're flashing here
  cstart*=60;
  cend*=60;
Let me know how it works. This code should also work for fast drivers on channels 0 and 2 for the other modes.
Thanks Colin.
I'll try to test it tonight.
If not definitely over the weekend.
There's some errors in the code.
I guess this is the line that does the cloud but you want to do it for both and this one is never declared so I'm guessing
Colin, I need a way to call the cloud/lightning routine on demand. What you got for me? I haven't read through the code enough to comprehend that yet.
Ooops, missed that part. It's fixed now.
Give me a bit on the on-demand. I have an idea.
I actually added two more variables for my actinics and using another function to do an override (for presets 60/40 80/20, etc.)
I want one of those relays to trigger a cloud/lightning and then I think my life will be complete :)
I got the a 'DaylightPWMValue' error was not declared in this scope on DaylightPWMValue0=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue/40.95,0,180)*40.95;
Also when you say the last stuff goes "At the very end, outside of loop() and past everything else add this.", is that after the...
Ooops, fixed.
Put it at the very end of everything. You technically could put it before void DrawCustomGraph() but it's easier if you just put it at the very end of the sketch.
On demand cloud. It's a little dirty, but it works.
void CheckCloud()
#else
#endif
      if (cloudchance)
  if (cloudchance)
     if (ReefAngel.Relay.Status(Port6))      // Change this to whatever port you want to use as a trigger.
      cloudstart = NumMins(hour(), minute());
      ReefAngel.Relay.Override(Port6,2);    // Here, too.
      case Calm:
        break;
      case Mega:
          // Send the trigger
          Strike();
        break;
      case Mega2:
          Strike();
        break;
      case Fast:
          Strike();
        break;
      case Slow:
          delay(1);
        break;
      default:
        break;
      cloudindex++;
      int x=0;
      else x=17;
      else x=35;
      int x=0;
      else x=57;
      else x=75;
void Strike()
    // Flash on
    int newdata=4095;
  cstart*=60;
  cend*=60;
The difference is this section here.
Change to whichever port you want to use as a trigger. You can use a port on a non-existent relay box. If that port is turned on, the cloud will start. There has to be a chance of clouds for that day and it will use whatever lightning type is next up (if you're using multiple types).
Very cool Colin.
I haven't had a chance to try the cloud and lightning code yet because I had some issue with my tank that I've been trying to work out this weekend, but I can't wait to.
The on demand feature is very awesome.
