can somebody help me code in to have my skimmer shut off once my ATO Low Timeout is triggered had my skimmer dump my sump out the other day and wanna make sure it dosnt happen again.. TIA
Heres my Code
ReefAngel.FeedingModePorts = Port3Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port6Bit | Port7Bit;
ReefAngel.StandardLights( Port1,19,0,14,0 );
ReefAngel.StandardLights( Port2,14,0,19,0 );
ReefAngel.Relay.DelayedOn( Port3,90 );
ReefAngel.SingleATO( true,Port4,220,0 );
ReefAngel.StandardLights( Port6,10,0,21,0 );
ReefAngel.StandardHeater( Port7,783,785 );
ReefAngel.DCPump.SetMode( ShortPulse,100,75 );
ReefAngel.DCPump.ExpansionChannel[0] = AntiSync;
ReefAngel.DosingPumpRepeat(Box1_Port1,300,360,34); // Alk Dose every 720 minutes with 540 minutes offset for 45 seconds
ReefAngel.DosingPumpRepeat(Box1_Port2,345,360,34); // Ca Dose every 720 minutes with 600 minutes offset for 45 seconds
if (hour()>=21 || hour()<2)
ReefAngel.DCPump.SetMode( NutrientTransport,65,20 );
ReefAngel.DCPump.SetMode( ShortPulse,75,50 );
ReefAngel.Portal( "paulweck" );
Skimmer shut off when ATO times out
Paulweck
Paulweck
Re: Skimmer shut off when ATO times out
I can't remember if this was added on dev branch or not, but try it:
if (ReefAngel.isATOTimeOut()) ReefAngel.Relay.Off(Port3);
