How do I code an alert when there is a Leak?
#include <WiFiAlert.h>
void emergencyLeak(char *message);
InternalMemory.LCDID_write(255); //Old LCD
//ReefAngel.Use2014Screen(); // Let's use 2014 Screen
ReefAngel.FeedingModePorts = Port3Bit;
ReefAngel.WaterChangePorts = Port2Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit;
// Ports turned off when Leak is detected
ReefAngel.LeakShutoffPorts = Port4Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( Port1,245,761 );
ReefAngel.StandardFan( Port2,771,255 );
if (ReefAngel.IsLeakDetected())
emergencyLeak("Leak");
ReefAngel.Portal( "rsalomez", "xxxxxxx" );
void emergencyLeak(char *message){
static WiFiAlert t;
t.SetDelay(0);
t.Send(message);
DISPLAYLOG=true;
LOGMESSAGE = message;
Portal() function requires security key: ON
Portal() security key: xxxxxx
Send email notifications --> ON
Email address(es): my email
Temperature 1 >= 28
Water Leak Flag = 1
Thanks for your help
