Custom menu question
maxxdog21
I am going to try my hand at building a custom menu. One of the entries that I would like to have is the ability to manually turn on one set of lights. Could you advise me on how to do this?
Re: Custom menu question
I use this:
My lights are on Port 3 and 4.
You can move the 1s to whatever port you have your lights.
void MenuEntry4()
ReefAngel.Relay.RelayMaskOn|=B00001100; //Override Lights On;
ReefAngel.DisplayedMenu=RETURN_MAIN_MODE;
maxxdog21
Thanks Roberto. I put in the code and when I tried to compile it, it gave me an error message that the sketch was too big. I can make it work if I take out the 4th menu entry - set time and date. I don't really don't need it but what if I want to add another menu entry? Like a nother wavmaker mode? Will it be too big again? Why is my code so big?
maxxdog21
This was my running pde file - all I added were the custom menu lines. Here is the code:
#define DateTimeSetup
#define DisplayLEDPWM
#define RelayExp
#define wifi
#define VersionMenu
#define PWMEXPANSION
#define CUSTOM_MENU
#define CUSTOM_MENU_ENTRIES 4
#define CUSTOM_MAIN
#define NUMBERS_8x16
#define COLORS_PDE
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_Wifi.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#include <ReefAngel_Salinity.h>
#include <ReefAngel_Colors.h>
#include <avr/pgmspace.h>
prog_char menu0_label[] PROGMEM = "Feeding Time";
prog_char menu2_label[] PROGMEM = "Lights On";
prog_char menu3_label[] PROGMEM = "Set time and date";
menu0_label, menu1_label, menu2_label, menu3_label};
void MenuEntry1()
ReefAngel.DisplayMenuEntry("Feeding Time");
ReefAngel.FeedingModeStart();
void MenuEntry2()
ReefAngel.DisplayMenuEntry("Water Change");
void MenuEntry3()
ReefAngel.DisplayMenuEntry("Lights On");
ReefAngel.Relay.RelayMaskOn|=B00000001; //Override Lights On;
void MenuEntry4()
ReefAngel.DisplayMenuEntry("Set time and date");
ReefAngel.SetupDateTime();
byte PWMChannel[]={
0,0,0,0,0,0};
//Top Banner
ReefAngel.LCD.DrawText(COLOR_BLACK, COLOR_SKYBLUE, 9, 2, " Harry's 120H Reef ");
// Display Temp Text
ReefAngel.LCD.DrawText(0,255,8,12,"Temp");
// Display the T1 temp value
char text[7];
ConvertNumToString(text, ReefAngel.Params.Temp1, 10);
ReefAngel.LCD.Clear(255, 4, 22, 37, 38);
ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 4, 22, text, Num8x16);
// Display Salt Text
ReefAngel.LCD.DrawText(0,255,54,12,"Salt");
// Display Salt Value
ReefAngel.LCD.Clear(255, 52, 22, 75, 38);
ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 52, 22, text, Num8x16);
// Display pH Text
ReefAngel.LCD.DrawText(0,255,112,12,"pH");
// Display pH Value
ReefAngel.LCD.Clear(255, 94, 22, 106, 38);
ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 94, 22, text, Num8x16);
// Display Actinic Percentage Text
ReefAngel.LCD.DrawText(0,255,8,40,"Blue LED %");
// Display Actinic Percentage Value
ConvertNumToString(text, PWMChannel[1], 1);
strcat(text," ");
ReefAngel.LCD.DrawText(0, 255, 80, 40, text);
// Display Daylight Percentage Text
ReefAngel.LCD.DrawText(0,255,8,50,"White LED %");
// Display Daylight Percentage Value
ConvertNumToString(text, PWMChannel[0], 1);
strcat(text," ");
ReefAngel.LCD.DrawText(0, 255, 80, 50, text);
// Display Moonlight Phase Text
ReefAngel.LCD.DrawText(0,255,8,60,"Moonlight ");
// Display Moonlight Phase Value
ConvertNumToString(text, PWMChannel[2], 1);
strcat(text," ");
ReefAngel.LCD.DrawText(0, 255, 80, 60, text);
ReefAngel.LCD.DrawOutletBox(13, 109, TempRelay);
ReefAngel.FeedingModePorts = B00110000;
ReefAngel.FeedingModePortsE[0] = B00110000;
ReefAngel.WaterChangePorts = B00111100;
ReefAngel.WaterChangePortsE[0] = B00110011;
ReefAngel.OverheatShutoffPorts = B00000011;
ReefAngel.LightsOnPorts = B00011110;
ReefAngel.Relay.On(Port3);
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.On(Box1_Port2);
// Wavemaker timer
ReefAngel.Timer[1].SetInterval(random(15,90));
ReefAngel.Timer[1].Start();
ReefAngel.Relay.On(Port6);
ReefAngel.Relay.On(Box1_Port6);
// Specific functions
// T5 White
ReefAngel.StandardLights(Port1,10,30,20,0);
//T5 Blue
ReefAngel.StandardLights(Port2,9,30,20,45);
//LED Blue
ReefAngel.StandardLights(Port7,9,0,21,15);
//LED White
ReefAngel.StandardLights(Port8,10,0,20,30);
//Heater
ReefAngel.StandardHeater(Box1_Port3,773,783);
//Refugium
ReefAngel.StandardLights(Box1_Port4,21,0,7,0);
//Fan
ReefAngel.StandardLights(Box1_Port7,8,30,21,0);
//LED Moonlight
ReefAngel.StandardLights(Box1_Port8,20,45,7,30);
// Channel 0 = White
PWMChannel[0]=PWMSlope(10,0,20,30,0,100,30,PWMChannel[0]); // calculate slope %
// Channel 1 = Blue
PWMChannel[1]=PWMSlope(9,0,21,15,0,100,30,PWMChannel[1]); // calculate slope %
// Channel 2= Moonlights
PWMChannel[2]=MoonPhase(); // calculate moon phase %
// this section sends the data to the PWM expansion module
for (int a=0;a<4;a++)
ReefAngel.PWM.Expansion(a,int(2.55*PWMChannel[a]));
// Wavemaker
ReefAngel.Relay.Toggle(Box1_Port5);
ReefAngel.Relay.Toggle(Box1_Port6);
maxxdog21
And my features file as well:
// AutoGenerated file by RAGen (v1.1.0.124), (10/22/2011 19:43)
* Copyright 2010-11 Curt Binder
* Licensed under the Apache License, Version 2.0 (the "License")
// #define SIMPLE_MENU
#define wifi
#define RelayExp
#define WDT
#define SALINITYEXPANSION
#define CUSTOM_MENU
#define CUSTOM_MAIN
#define COLORS_PDE
#endif // __REEFANGEL_FEATURES_H__
maxxdog21
Yes, I do. I do not have it running yet but it's next on the to do list...
Ok, so you can remove the date/time setup. It takes quite a bit of memory.
You can use the wifi very easily to update the time.
Make sure to also remove this line in the features file:
maxxdog21
I did try that and the pde will compile. The time/date is big - That's what I thought. But, if I want to add another menu entry of any kind, will the code be too big again or will it be okay(being that the t/d function is huge)?
- Contact:
Adding menu entries does not increase code size by a whole lot. The more complex the function is, the larger the code size increase will be. I cannot give you an example, just a general guideline.
maxxdog21
I figured as much. The time/date code segment must be big, even if it seems to be a simple function.
- Contact:
yes it is big. there is a lot that has to be done with updating the screen on the changes. so it does require some space.
