Restore EEPROM Icons
KRavEN
Post by KRavEN »
I'm looking for the sketch to restore the I2C eeprom with the images for feeding, waterchange, etc...
I found an old sketch on the google groups called AllIconLoad.pde and I modified it for the new Wire library but I'm still just seeing a black box when I have #define DisplayImages in ReefAngel_Features.h.
Re: Restore EEPROM Icons
Check if you got a jumper on JP1.
It's the write enable of the I2C eeprom.
KRavEN
Post by KRavEN »
I tried with the jumper on but no dice
Can you confirm you wrote stuff to memory?
It may be something related to the #define not being set correctly when arduino compiles.
We may need to add something for the auto feature detect when arduino compiles the code
KRavEN
Post by KRavEN »
I'll debug it and see what I can work out.
