Help with equipment
Talk about you and your tank/equipment
nhago
Help with equipment
Post by nhago »
Hi guys, I have a RA+ and am currently in the process of upgrading my tank.
On the new one (150g - 72x24x18), I'll control at least 2 jebao power heads, an ATO, 3 modded black boxes, jebao dosing pumps and perhaps my return pump.
I know I need a dimming expansion, but I am wondering if I need anything else. Can you guys point me the right way, please? Thank you!
Re: Help with equipment
You'll need
2 or 3 Jebao/Speedwave Cables (3) if the return pump is a DC pump and you want to control the speed of it.
Dimming Expansion (Like you said)
ATO Float switched (unless you still have your originals) (1 or 2 depending on how you are setting it up.
The 3 modded black boxes will use all 6 of your dimming channels on the Dimming Expansion and the 2 Jebao's will use the Daylight and Actinic dimming ports on the relay.
If you have a DC return pump and want to control it then you wold need a modded Jebao/Speedwave Cable to plug it into one of the ATO ports.
