I have a PWM 2.1
I opened it up and didnt see the jumpers for 5/10v and analog/pwm.
Does the 2.1 have analog capabilities?
can it switch from 5-10, or which one is it?
Thanks.
older PWM?
older PWM?
45g corner, 90g main, 90g staging, 25g frag, working on a 180g setup.
Re: older PWM?
Ouch bummer, can the RA run any lights without the expansion? If so, is it analog?
Re: older PWM?
The relay box has 2 dimming ports. They are most likely 0-10v pwm unless you opted for analog when you bought it.
Re: older PWM?
How can I tell?
Re: older PWM?
Im not seeing anything anything on the outside, would it be inside?
Re: older PWM?
The sticker is generally on the bottom of the unit.
