Freakin WiFi
Re: Freakin WiFi
You can, but when programming, you need to turn it off or you get errors like you were seeing. The client suite was trying to access the wifi while you were programming and messing with your programming
ganjero
Re: Freakin WiFi
Paul,
What router are you using? Did you fully solve your issue?
Ever since I got Brighthouse I completely lost my connectivity. Port fowarding doesn't work for my RA, and I also get intermittent connection.
edit:mhmm...my webbanner seems to update but I have no access in the portal.
