ATO Hi or Lo turn off main pump
djbm3
Post by djbm3 »
Can we program the float switches for ATO Hi or Lo to turn off main pump? I currently have a pvc pipe with the two float switches attached. One facing up in the water floating and another mounted higher up for a high water mark. On the Reef angel client the ATO Hi & Lo show green... which is what I consider to be in safe zone. They turn red when out of that safe zone and I would like to have my pump turn off on a trigger of those.
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port7Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port7Bit;
InternalMemory.OverheatTemp_write( 835 );
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardHeater( Port1,786,790 );
ReefAngel.Wavemaker( Port5,20 );
ReefAngel.Relay.Set( Port6, !ReefAngel.Relay.Status( Port5 ) );
ReefAngel.StandardLights( Port7,16,0,12,0 );
if (now()%180<22)
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Port6);
Blend-FM.com Faded Friday's every Friday night at: https://www.stream.me/BlendFM
Re: ATO Hi or Lo turn off main pump
Try this:
ReefAngel.Relay.Set(Port8, ReefAngel.LowATO.IsActive() && ReefAngel.HighATO.IsActive());
djbm3
Post by djbm3 »
yep that works. I changed the port from 8 to 3 where my main pump is plugged in. Thank you!
