inserting custom code
slm222
Post by slm222 »
hello, I have a question. im really inexperienced at coding, which is a reason I went with a reef angel ( im wanting to learn more coding). I have a vague memory of html back in college days. Well... on to the question.
I saw the coding id like to try with my jebaos.
if (hour()>=8 && hour()<12)
  ReefAngel.PWM.SetDaylight( ReefCrestMode(60,20,true) ); // ReefCrest at 60% +/- 20% on sync mode
  ReefAngel.PWM.SetActinic( ReefCrestMode(60,20,false) ); // ReefCrest at 60% +/- 20% on anti-sync mode
else if (hour()>=12 && hour()<18)
  ReefAngel.PWM.SetDaylight( ShortPulseMode(0,60,200,true) ); // Short pulse at 60% with 200ms pulse on sync mode
  ReefAngel.PWM.SetActinic( ShortPulseMode(0,60,200,false) ); // Short pulse at 60% with 200ms pulse on anti-sync mode
  ReefAngel.PWM.SetDaylight( LongPulseMode(0,60,10,true) ); // Long pulse at 60% with 10s pulse on sync mode
  ReefAngel.PWM.SetActinic( LongPulseMode(0,60,10,false) ); // Long pulse at 60% with 10s pulse on anti-sync mode
if I wanted to put that code in what would I need to change in my current code?
ReefAngel.MHLights( Port1,12,30,14,30,5 );
ReefAngel.MHLights( Port2,5,0,22,0,10 );
ReefAngel.StandardLights( Port3,18,0,10,0 );
ReefAngel.StandardHeater( Port4,770,788 );
ReefAngel.StandardLights( Port5,18,0,10,0 );
ReefAngel.SingleATO( true,Port8,180,0 );
ReefAngel.PWM.SetDaylight( PWMSlope(8,0,20,0,5,100,120,5) );
ReefAngel.PWM.SetActinic( PWMSlope(8,0,20,0,5,100,120,5) );
ReefAngel.DCPump.SetMode( LongPulse,100,180 );
Lionfan
Re: inserting custom code
Post by Lionfan »
slm222 wrote:hello, I have a question. im really inexperienced at coding, which is a reason I went with a reef angel ( im wanting to learn more coding). I have a vague memory of html back in college days. Well... on to the question.
I'm gonna say delete "ReefAngel.DCPump.SetMode( LongPulse,100,180 );"
and replace it with your new code.
Uhh.. just kind of browsing thru your code, do you realize your Daylight and Actnic Ports are set to be both for your lights, and DC pump?
slm222
Post by slm222 »
Im sure about that part. Everything on there so far is via the wizard. I am using the director for some Ai hydras I have.
So your lights aren't plugged into the daylight and actinic ports? You should take out the lighting code then. The way it's written now, the SetDayLight and SetActinic functions are being immediately over-written by the DCPump.SetMode function.
Otherwise, as stated above, put all that pump code in place of the ReefAngel.DCPump.SetMode line. In fact, you can take out all four of the current DCPump lines as the new code handles all that.
slm222
Post by slm222 »
Ok I got it to work. seems to be working well, here is what I ended up with. Lionfan and cosmith71, thank you for the above corrections and steering me in the right course.
if (hour()>=7 && hour()<10)
  ReefAngel.PWM.SetDaylight( SineMode(0,100,250,true) ); // Long pulse at 100% with 300s pulse on sync mode
  ReefAngel.PWM.SetActinic( SineMode(0,100,250,false) ); // Long pulse at 100% with 300s pulse on anti-sync mode
else if (hour()>=10 && hour()<12)
  ReefAngel.PWM.SetDaylight( SineMode(0,100,180,true) ); // Sine Wave at 100% with 180s pulse on sync mode
  ReefAngel.PWM.SetActinic( SineMode(0,100,180,false) ); // Sine Wave at 100% with 180s pulse on anti-sync mode
else if (hour()>=12 && hour()<15)
  ReefAngel.PWM.SetDaylight( ReefCrestMode(80,20,true) ); // ReefCrest at 80% +/- 20% on sync mode
  ReefAngel.PWM.SetActinic( ReefCrestMode(80,20,false) ); // ReefCrest at 80% +/- 20% on anti-sync mode
else if (hour()>=15 && hour()<17)
else if (hour()>=17 && hour()<20)
  ReefAngel.PWM.SetDaylight( SineMode(0,35,400,true) ); // Sine Wave at 35% with 300s pulse on sync mode
  ReefAngel.PWM.SetActinic( SineMode(0,35,400,false) ); // Sine Wave at 35% with 300s pulse on anti-sync mode
I removed all the extra DC stuff do I leave this or remove it?
You can leave that out. You're setting the PWM ports directly instead of using the PWM.SetMode stuff so you don't need it.
slm222
Post by slm222 »
I ran into a problem once removing the dc pump code and setting everything to the PWM directly. My feed mode and water change mode no longer turn off the pumps.
Lionfan
Post by Lionfan »
slm222 wrote:I ran into a problem once removing the dc pump code and setting everything to the PWM directly. My feed mode and water change mode no longer turn off the pumps.
Repost you're code.
I think maybe you bypassed the DCpumpFeedingspeed
slm222
Post by slm222 »
    ReefAngel.AddStandardMenu();  // Add Standard Menu
    ReefAngel.FeedingModePorts = Port2Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port2Bit | Port8Bit;
    ReefAngel.Relay.On( Port7 );
    ReefAngel.MHLights( Port1,12,30,14,30,5 ); //t5ho
    ReefAngel.MHLights( Port2,5,0,22,0,5 ); //skimmer
    ReefAngel.StandardLights( Port3,18,0,10,0 ); //fugelight
    ReefAngel.StandardHeater( Port4,780,788 ); //heater
    ReefAngel.StandardLights( Port5,18,0,10,0 ); //scrubber light
    ReefAngel.SingleATO( true,Port8,300,0 ); // ato
// Wave Makers
  ReefAngel.PWM.SetDaylight( SineMode(0,100,300,true) ); // Long pulse at 100% with 300s pulse on sync mode
  ReefAngel.PWM.SetActinic( SineMode(0,100,300,false) ); // Long pulse at 100% with 300s pulse on anti-sync mode
