Automatic Water Change Idea
dedvalson
Post by dedvalson »
Hi,
I wanted to get your opinion on an idea I have for an automatic water changer.
I currently have 3 pumps. One is my normal ATO and comes from a large barrel of RO/DI water. I have a second pump coming from a large barrel of saltwater and a third which pumps water out of my sump and into a drain.
I currently run my ATO using one of the 4 level sensors in my 4 channel level sensor.
I was considering the following:
During the hour from 0100 to 0200 hours I would disable the normal ATO.
From 0100 to 0115 I would run the drain pump until the level sensor read less than 50% (I normally run it at 75%)
From 0115 to 0200 I would run the normal ATO program, but using the saltwater pump instead.
At 0200, normal ATO operation would resume.
By basing it on time and levels like this, I don't need any flags. I think it would work properly even if the controller reset at any point in it.
Do you see any problems with this scheme?
Don
Re: Automatic Water Change Idea
Best way to do it IMO.
ucez
Post by ucez »
I do something similar, but not linked to water level. The salt pump and drain pump turn on simultaneously and are calibrated to add/remove same amount of water.
Sent from my LG-V410 using Tapatalk
gaberosenfield
Post by gaberosenfield »
I do exactly what you do, but with float switches. ~0.66% water change automatically every evening. Not much, but enough to amount to about a single 15% water change per month. And no buckets lifted. EVER. :-)
