constant sketch too big
Ask in here.
Marvollo
Post by Marvollo »
Hi,
I have had my code the same for over a year now. I used the wizard to try and tweak my heater timer settings. No matter what I do every sketch is saying it's too large. This is with both using in internal memory or in the code setting with the wizard.
The only thing that has changed is my pc is now on windows 10 - which somehow caused me to lose my old sketch settings. Mybe the ttl cable is not connecting? I hear my pc recognize it though.
here is an example:
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit | Port7Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.StandardFan( Port2,780,790 );
ReefAngel.StandardLights( Port3,12,0,20,0 );
ReefAngel.StandardLights( Port4,10,30,20,30 );
ReefAngel.StandardFan( Port5,785,795 );
ReefAngel.StandardLights( Port6,6,0,1,0 );
ReefAngel.Relay.Set( Port7, !ReefAngel.Relay.Status( Port4 ) );
ReefAngel.StandardHeater( Port8,780,790 );
ReefAngel.PWM.SetDaylight( PWMSlope(12,0,20,0,15,70,30,15) );
ReefAngel.PWM.SetActinic( PWMSlope(10,30,20,30,15,100,30,15) );
ReefAngel.Portal( "marvollo" );
Marvollo
Re: constant sketch too big
Post by Marvollo »
how do i remove all code from the head unit to start fresh? I can't upload anything the head unit says, memory updated you can now upload your ino code
what version of the libraries are you using?
if you reinstalled the software, then you probably have the latest which will be a problem for those with the standard ra. I forget what version is the last version that will load onto the standard ra. i think it was 1.0.6 (or somewhere around there... someone else will chime in with the correct version).
so you will need to downgrade the libraries to make it work.
Marvollo
Post by Marvollo »
reverted back to 1.0.6 and now i get:
Watchdog Timer
Version Menu
Dimming Signal
Wifi Attachment
Simple Menu
C:\Users\Jeremy\Documents\Arduino\libraries\Humidity\Humidity.cpp: In member function 'void HumidityClass::Read()':
C:\Users\Jeremy\Documents\Arduino\libraries\Humidity\Humidity.cpp:40: error: 'I2CHumidity' was not declared in this scope
C:\Users\Jeremy\Documents\Arduino\libraries\Humidity\Humidity.cpp:56: error: 'crc16' was not declared in this scope
Marvollo
Post by Marvollo »
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <Salinity.h>
#include <RF.h>
#include <IO.h>
#include <ORP.h>
#include <AI.h>
#include <PH.h>
#include <WaterLevel.h>
#include <Humidity.h>
#include <DCPump.h>
#include <PAR.h>
#include <ReefAngel.h>
    ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.StandardFan( Port2,780,788 );
    ReefAngel.StandardLights( Port4,11,0,21,0 );
    ReefAngel.StandardLights( Port6,7,0,2,0 );
    ReefAngel.Relay.Set( Port7, !ReefAngel.Relay.Status( Port3 ) );
    ReefAngel.StandardHeater( Port8,780,785 );
    ReefAngel.PWM.SetActinic( PWMSlope(11,0,21,0,15,100,30,15) );
In file included from C:\Users\Jeremy\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:91,
from sketch_dec07b.cpp:30:
C:\Users\Jeremy\Documents\Arduino\libraries\ReefAngel/Standard/public.h:3: error: 'DS1307RTC' does not name a type
how do i fix this? I tried deleting line ds1307rtc
this was with trying 1.1.0 libraries on the 1.1.1 reef angel installer
I don't think you reverted back correctly.
https://github.com/reefangel/Libraries/ ... v1.0.6.zip
Delete the contents of /Dcouments/Arduino/libraries folder and then copy the ones in the zip file into the same empty libraries folder.
Marvollo
Post by Marvollo »
Error: C:\Users\Jeremy\Documents\Arduino\libraries\ReefAngel\ReefAngel.h (The system cannot find the file specified)
i get this every time i try to switch the library to 1.0.6
I think you are not copying it correctly.
The contents need to be the same as before you deleted the contents of the 1.1.0 libraries.
Can you post a screen shot of how your libraries folder looks like?
Marvollo
Post by Marvollo »
ok thanks, i got it to work.
Now I can't seem to get the uapp to work any more. I am able to connect to portal and the information is all correct.
on my app it says forum id not set up and wont pull up my parameters. Hitting refresh brings status.html timeout.
I would recommend you upgrading your board to RA+ to be able to use all the features.
The standard RA is very limited with the recent libraries updates.
You can also try the other releases until you find one that works for you, if any will. But I still think you should upgrade.
