AWC Code
Ask in here.
Ismaclst
AWC Code
Post by Ismaclst »
I need help coding for my automatic water change pump. I want to turn on port 2 every 6 hours for 18 min. I also want to use the two float switches in the saltwater container to have port 2 turn off when it reaches the low float switch and have it turn back on when the high is activated. This would act as a fail safe so when the saltwater bin gets too low it won't pump water out of the tank when there is no more water in the saltwater container. Here is my current code.
  ReefAngel.DDNS("Damien");
  ReefAngel.AddMultiChannelWaterLevelExpansion();  // Multi-Channel Water Level Expanion Module
  ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port6Bit | Port7Bit | Port8Bit;
  ReefAngel.LightsOnPorts = Port5Bit;
  InternalMemory.WaterLevelMax_write(1800);
  ReefAngel.StandardHeater( Port3,780,785 );
  ReefAngel.WaterLevelATO(4,Port4,240,36,38);
  if (ReefAngel.WaterLevel.GetLevel(1)>45) ReefAngel.PWM.SetActinic(50);
    ReefAngel.PWM.SetActinic(100);
  if (ReefAngel.WaterLevel.GetLevel(2)>85)
    ReefAngel.Relay.Off(Port1);
    ReefAngel.Relay.On(Port1);
  ReefAngel.Portal( "Ismaclst" );
Re: AWC Code
So first let's code Port2..
ReefAngel.Relay.Set(Port2, now()%6*SECS_PER_HOUR<18*SECS_PER_MINUTE);
This tells Port2 to turn on if the condition is met. The condition breaks down the current time into 6 hour chunks. If that time is less than 18 minutes then the port will be on. You can adjust the runtime by changing 18*SECS_PER_MINUTE and the repeat interval by changing the 6*SECS_PER_HOUR.
Now, let's focus on the float switches.
if (ReefAngel.LowATO.IsActive()) ReefAngel.Relay.Override(Port2,0); // Disable the port until overriden manually
if (ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Override(Port2,2); // Set port back to auto
Pretty straight forward :)
Ismaclst
Re: AWC Code
Post by Ismaclst »
Great, thanks! I'm obviously not very good at coding! So does the first line go in the void setup and the other goes in the void loop? Can't wait to have this automated to reduce tank maintenance.
Re: AWC Code
Best thing I've ever done!!! Can't believe it took me so long to get the tubing run and everything mounted. Was sitting on all the equipment for almost 2 years...
Ismaclst
Re: AWC Code
Post by Ismaclst »
I had a SECS_PER_MINUTE not declared in this scope, error.
Re: AWC Code
Sorry, use SECS_PER_MIN you could also just use 60 :)
my bad..
Ismaclst
Re: AWC Code
Post by Ismaclst »
Thanks, compiled fine.
Ismaclst
Re: AWC Code
Post by Ismaclst »
What would I need to change this to if I was going to use channel 1 of the multi channel water expansion? I was going to use the float switches but it would require a fancy bracket. Since I had one channel left, I figured this would make it a lot easier to setup.
Re: AWC Code
ReefAngel.WaterLevel.GetChannel(1)<X
ReefAngel.WaterLevel.GetLevel(1)>Y
Where X and Y are the values you want to use to trigger
Ismaclst
Re: AWC Code
Post by Ismaclst »
Would it be something like this
if (ReefAngel.WaterLevel.GetLevel(1)<5)
  if (ReefAngel.WaterLevel.GetLevel(1)>90)
Re: AWC Code
Yep
Ismaclst
Re: AWC Code
Post by Ismaclst »
Ismaclst
Re: AWC Code
Post by Ismaclst »
I finally got my pump and plumbing hooked up for my AWC last night. I put a bucket at the discharge tubing end to see if it was actually pumping water from the sump. I got home from work today to find that there was no water in the bucket when there should have been about a gallon. I checked the portal to see if that port turned on but it hadn't all day. Not sure if something is wrong with by code or not. Here is my most recent one.
#include <Tide.h>
Tide tide;
  ReefAngel.Relay.Set(Port8, now()%6*SECS_PER_HOUR<30*SECS_PER_MIN);
  tide.Init(55,10,30);
  tide.SetWaveLength(12+SECS_PER_HOUR);
  ReefAngel.WaterLevelATO(4,Port4,240,28,31);
  if (ReefAngel.WaterLevel.GetLevel(1)<5) //Disable the port until overriden manually
    ReefAngel.Relay.Override(Port8,0);    //Saltwater Reservoir
  if (ReefAngel.WaterLevel.GetLevel(1)>80)   // Set port back to auto
    ReefAngel.Relay.Override(Port8,2);
  if (ReefAngel.WaterLevel.GetLevel(2)>80) //Overflow
  if (ReefAngel.WaterLevel.GetLevel(3)>87) //ATO Reservoir
    ReefAngel.Relay.Off(Port5);
  if (ReefAngel.WaterLevel.GetLevel(3)<1)
    ReefAngel.Relay.On(Port5);
byte setMaxspect(byte minSpeed, byte maxSpeed, boolean PulseSync)
  int reverse_speed=0;
  int forward_speed=45;
   // swap between forward and reverse every X seconds
   reverse_speed = ShortPulseMode(0,100,ReefAngel.DCPump.Duration*2,true);
   if (reverse_speed == 100) {
     // while we are going in reverse increase the speed by 10
     forward_speed = ShortPulseMode(35+10, 60+10,ReefAngel.DCPump.Duration,true);
   } else {
     // while we are going forward set speed to 25-40 to keep
     // from blowing corals off the rocks
     forward_speed = ShortPulseMode(35,70, ReefAngel.DCPump.Duration, true);
  if (PulseSync) {
    return forward_speed;
  } else {
    return reverse_speed;
Ismaclst
Re: AWC Code
Post by Ismaclst »
I'm using port 8 for the AWC pump.
Ismaclst
Re: AWC Code
Post by Ismaclst »
Anyone?
Re: AWC Code
Why would you expect water in the bucket?
There is nothing that triggers anything in your code.
What is your trigger?
Ismaclst
Re: AWC Code
Post by Ismaclst »
I thought this triggered port 8?
Ismaclst
Re: AWC Code
Post by Ismaclst »
I put that line in the void setup but should it go in the void loop instead?
Re: AWC Code
Sorry. Didn't see that because it was in the wrong section.
setup() only runs at the initialization of the controller.
It should be in the loop() section.
Ismaclst
Re: AWC Code
Post by Ismaclst »
Thanks, hopefully that fixes it.
Ismaclst
Re: AWC Code
Post by Ismaclst »
I think something is wrong with that line of code. I needed it to run for 30 minutes every 6 hours. Right now its turning off and on about every 6 seconds.
Re: AWC Code
I think you need to some parenthesis to isolate the math.
You have to think it just like you would interpret it. If you have doubts, so does the controller.
So, now()%6*SECS_PER_HOUR<30*SECS_PER_MIN would be read like this:
now() modulo 6 * 3600 < 30 * 60
the first calculation is now() modulo 6. The result is multiplied by 3600. The result is checked if it is less than 30 and then the result is multiplied by 60.
Definitely not what you want.
Just like regular math, parenthesis is very important.
You math should be:
(now()%(6*SECS_PER_HOUR))<(30*SECS_PER_MIN)
Ismaclst
Re: AWC Code
Post by Ismaclst »
Thanks, Roberto. I have a hard time understanding the code.
Ismaclst
Re: AWC Code
Post by Ismaclst »
Sorry to keep asking questions but when I went to verify the new code it had some errors. Not sure if I missed something or what.
#include <Tide.h>
Tide tide;
  ReefAngel.Relay.Set(Port8, (now()%(6*SECS_PER_HOUR))<(30*SECS_PER_MIN);
   } else {
  if (PulseSync) {
  } else {
Re: AWC Code
Copy and paste in place of the other one. You are missing one parenthesis.
It's just like when you did math in high school. One opening parenthesis needs to have its corresponding closing parenthesis to complete the formula.
Ismaclst
Re: AWC Code
Post by Ismaclst »
Ok, I see. I forgot the second parenthesis at the end.
