ATO Reservoir refill every few days
Is there a way to run an ATO reservoir fill cycle every few days instead of based on float switches? How can I run it like every 3 days? Is there a way to do that?
I currently run it manually with a 12V solenoid, but I want to automate it. I mean that is the purpose of my tank computer, right?
Re: ATO Reservoir refill every few days
Yes I just shared my function with someone else in this thread.
http://forum.reefangel.com/viewtopic.php?t=5896#p51479
It relies on the water level sensor to know when to fill and when to stop. Without float switches how will you know? You could rely on a float valve to stop your RO/DI and just go for a specific time. Let me know, we can modify that code pretty easily.
Yes that's my current set up. I have a float valve on the feed line to my reservoir. Right now I turn on the RO/DI port ,it fills and after a few hours, or days, whenever I remember to shut it off,I shut it off.
I was just thinking fill the tank every 3 days. Just run the RO/DI for X hours then wait another 3 days and refill again.
Yeah that works. What time do you want it to kick in? You gonna manually turn it off still or do you want it to turn off after a set time?
Edit: nvm you said x hours.
This should do it.
Let us know how it goes.
// Set this to the port your solenoid is on.
#define ROSolenoid Port5
void RefillATO() {
static boolean refillActive=false; // Flag to determine if we've initiated the refill.
static time_t startedAt=0;
byte startAt=23;
byte runFor=6;
byte runEvery=3;
if ( now()+(startAt*SECS_PER_HOUR) % (runEvery*SECS_PER_DAY)==0 ) {
ReefAngel.Relay.Override(ROSolenoid,1); // We turn on the solenoid port.
startedAt=now();
refillActive=true;
if ( now()-startedAt == runFor*SECS_PER_HOUR && refillActive) {
ReefAngel.Relay.Override(ROSolenoid,0); // Back to automatic mode
refillActive=true;
startedAt=0;
Ok, I really appreciate the help, but I need a little bit more. I'm not sure where to put the code into my code.
So, here's my code.
Thanks in advance.
So, here's my code.
Thanks in advance.
ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.FeedingModePortsE[0] = Port3Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port3Bit;
ReefAngel.LightsOnPortsE[0] = Port1Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.Relay.On( Port3 ); //Sump Powerhead. Main Relay Port 3
ReefAngel.Relay.On( Port4 );//Display Lights
ReefAngel.Relay.On( Port5 ); //Display Tank Power Heads MaiRelay Port 5
ReefAngel.Relay.On( Port8 ); //Return Pump Relay 1 Port 8
ReefAngel.Relay.On( Box1_Port1 ); //ATS Air Pump. Relay 2 Port 1
ReefAngel.Relay.On( Box1_Port2 ); //Media Reactor. Relay 2 Port 2
ReefAngel.Relay.On( Box1_Port3 ); //Aqualifter. Relay 2 Port 3
ReefAngel.Relay.Off( Box2_Port8 );//Referencing Relay 3
ReefAngel.Relay.DelayedOn( Port7 ); //Skimmer Relay 1 Port 7
ReefAngel.MHLights( Box1_Port4 ); //ATS Light Relay 2 Port 4
ReefAngel.DCPump.UseMemory = true; //ignore programming and use memory locations
if ((now()%SECS_PER_DAY==31320)) //if it is 8:42 AM
{ReefAngel.FeedingModeStart();} //START FEEDING MODE
if ((now()%SECS_PER_DAY==67320)) //if it is 6:42 PM
if (hour()>=22 || hour()<9)
{ // Sleep mode - slow things down
ReefAngel.DCPump.SetMode( ReefCrest,25,10 );
// Normal power
ReefAngel.DCPump.SetMode( ReefCrest,50,10 );
ReefAngel.Portal( "spotted" );
ReefAngel.DDNS( "7730.homeip.net:2000" ); // Your DDNS is spotted-7730.homeip.net:2000.myreefangel.com
Put all of it after the last } in your code. Then in the part at the current bottom where it says place your custom code below here put the following line to activate the function
RefillATO();
RefillATO();
Is this correct?
// Normal power
RefillATO();
void RefillATO() {
byte startAt=23;
byte runFor=6;
byte runEvery=3;
startedAt=now();
refillActive=true;
refillActive=true;
startedAt=0;
Ok, so after a really long trip out of town, I have returned!
It would appear that the code for the ATO reservoir refill does not function as hoped. Actually it does nothing. Can someone please take a look at it and tell me what needs to be done to fix it?
I really appreciate all your help on this.
I think it would be easier to just do this:
I have not tested, but it may be worth a try.
129600=number of seconds in 3 days
10800=number of seconds in 3 hours
It will turn on for 10800 seconds every 129600 seconds.
It will always turn on starting at midnight.
ReefAngel.Relay.Set(Port1,(now%129600)<10800));
Ok, so remove this
And make it look like this
and is that new code in the right place? The line right above
Or should it go above this line:
#define ROSolenoid Box2_Port6
void RefillATO() {
byte startAt=23;
byte runFor=6;
byte runEvery=3;
startedAt=now();
refillActive=true;
refillActive=true;
startedAt=0;
ReefAngel.Relay.Set(Box1_Port6,(now%129600)<10800));
ReefAngel.DCPump.UseMemory = false; //ignore programming and use memory locations if true
ReefAngel.DCPump.SetMode( Lagoon,40,66 );
// Normal power
ReefAngel.DCPump.SetMode( Constant,70,10 );
It has to be on loop section or it will only work at boot and never again.
setup() section only happens on boot and loop() section happens all the time.
Ok I tried this and got an error mesage. Here's the code and I hope it's in the correct place.
Here's my error:
Watchdog Timer
Version Menu
Wifi Attachment
Relay Expansion Module
DC Pump Control (Jebao/Tunze)
Dimming Signal
2014 Main Screen
Extra Font - Medium Size (8x8 pixels)
Metal Halide Setup
Number of Relay Expansion Modules: 2
Simple Menu
sketch_jun26.cpp: In function 'void loop()':
sketch_jun26:87: error: invalid operands of types 'time_t ()()' and 'long int' to binary 'operator%'
sketch_jun26:87: error: expected `;' before ')' token
Help please!
ReefAngel.Relay.Set(Box2_Port6,(now%129600)<10800));
// Normal power
Watchdog Timer
Version Menu
Wifi Attachment
Dimming Signal
2014 Main Screen
Metal Halide Setup
Simple Menu
Help please!
Sorry, I forgot the parenthesis.
Try this:
Try this:
ReefAngel.Relay.Set(Box2_Port6,((now()%129600)<10800));
Hi Roberto, I'm trying to check if this change is working, but I get no info on the relay activity in the portal. It says that there is no data.
The portal itself shows current data, but nothing in relay activity or in web chart.
Can you point me in the right direction?
You may need to update the firmware of wifi attachment:
Ok, I ran the ttl file to make sure all was good, but I still cant get any data on the web portal for relay activity or for web chart.
Here they are:
CMD
get w
SSID=Fish
Chan=0
ExtAnt=0
Join=1
Auth=WPA2
Mask=0x1fff
Rate=12, 24 Mb
Linkmon-Infra=30
Linkmon-AP=3600
Passphrase=FishfisH
EAP_Id=userid
EAP_User=peap-user
<4.00>
get i
IF=UP
DHCP=ON
IP=192.168.1.200:2000
NM=255.255.255.0
GW=192.168.1.1
HOST=104.36.18.155:80
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
<4.00>
CMD
get w
SSID=Fish
Chan=0
ExtAnt=0
Join=1
Auth=WPA2
Mask=0x1fff
Rate=12, 24 Mb
Linkmon-Infra=30
Linkmon-AP=3600
Passphrase=FishfisH
EAP_Id=userid
EAP_User=peap-user
<4.00>
get i
IF=UP
DHCP=ON
NM=255.255.255.0
GW=192.168.1.1
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
<4.00>
Looks correct.
Are you sure your code has the correct forum username?
It is. Does the forum name matter for the rest of the web portal? I am able to see all the items. I can control the relays and get updates on my parameters. The only 2 things I can't get are the relay activity and the web chart.
The Relay Activity says no data and the web chart is just blank..
Here's the code, is there a problem with it somewhere maybe?
ReefAngel.Relay.Set(Box1_Port6,((now()%259200)<3600));
// Normal power
ReefAngel.Portal( "Spotted" );
It is probably the DDNS line.
Remove it and see if it works.
Ok, that did it.
Another question. I am running both my Jebao pumps on one side of my tank now, kind of like a gyre configuration. They are of course run by my RA. There are a couple lines in the code that looks like they define Sync and AntiSync. I assume that on is for on channel ,the other is the opposite channel. Is it possible to change one line so both say Sync or AntiSync and they both act as one pump even though they are on different dimming channels?
Thanks again.
Thanks again.
