use float switch to turn skimmer off and add clouds
Ask in here.
CBRpilot
Post by CBRpilot »
I have a RA plus with wifi and salinity.
I have had it running very well for a little better than a year, now I wanted to start playing with it. I'm trying to add code for clouds with standard dimming (pretty easy for you pros)
also would like to use the float switches to turn skimmer off (skimmate locker) or turn GFO reactor off when activated (have a container under it so float switch activated would indicate a leak) both are on port 2.
i'll try and post the code I'm working on in next post. it has skimmer and ATO delayed and feeding at 7pm, otherwise pretty basic.
Thanks for the help in advance.
[quote]
#include <Globals.h>
#include <RA_Wifi.h>
#include <[color=#CC6600]Wire[/color].h>
#include <[color=#CC6600]OneWire[/color].h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <[color=#006699]LED[/color].h>
#include <RA_TempSensor.h>
#include <[color=#006699]Relay[/color].h>
#include <RA_PWM.h>
#include <[color=#006699]Timer[/color].h>
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <[color=#006699]Salinity[/color].h>
#include <[color=#006699]RF[/color].h>
#include <[color=#006699]IO[/color].h>
#include <[color=#006699]ORP[/color].h>
#include <[color=#006699]AI[/color].h>
#include <[color=#006699]PH[/color].h>
#include <[color=#006699]WaterLevel[/color].h>
#include <[color=#006699]Humidity[/color].h>
#include <[color=#006699]DCPump[/color].h>
#include <[color=#006699]PAR[/color].h>
#include <[color=#CC6600]ReefAngel[/color].h>
[color=#7E7E7E]////// Place global variable code below here[/color]
[color=#7E7E7E]////// Place global variable code above here[/color]
[color=#CC6600]void[/color] [color=#CC6600][b]setup[/b][/color]()
    [color=#7E7E7E]// This must be the first line[/color]
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]Init[/color]();  [color=#7E7E7E]//Initialize controller[/color]
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]Use2014Screen[/color]();  [color=#7E7E7E]// Let's use 2014 Screen [/color]
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]AddSalinityExpansion[/color]();  [color=#7E7E7E]// Salinity Expansion Module[/color]
    [color=#7E7E7E]// Ports toggled in Feeding Mode[/color]
    [color=#CC6600]ReefAngel[/color].[color=#006699]FeedingModePorts[/color] = [color=#006699]Port1Bit[/color] | [color=#006699]Port2Bit[/color] | [color=#006699]Port7Bit[/color];
    [color=#7E7E7E]// Ports toggled in Water Change Mode[/color]
    [color=#CC6600]ReefAngel[/color].[color=#006699]WaterChangePorts[/color] = [color=#006699]Port1Bit[/color] | [color=#006699]Port2Bit[/color] | [color=#006699]Port7Bit[/color];
    [color=#7E7E7E]// Ports toggled when Lights On / Off menu entry selected[/color]
    [color=#CC6600]ReefAngel[/color].[color=#006699]LightsOnPorts[/color] = [color=#006699]Port3Bit[/color] | [color=#006699]Port4Bit[/color];
    [color=#7E7E7E]// Ports turned off when Overheat temperature exceeded[/color]
    [color=#CC6600]ReefAngel[/color].[color=#006699]OverheatShutoffPorts[/color] = [color=#006699]Port5Bit[/color];
    [color=#7E7E7E]// Use T1 probe as temperature and overheat functions[/color]
    [color=#CC6600]ReefAngel[/color].[color=#006699]TempProbe[/color] = [color=#006699]T1_PROBE[/color];
    [color=#CC6600]ReefAngel[/color].[color=#006699]OverheatProbe[/color] = [color=#006699]T1_PROBE[/color];
    [color=#7E7E7E]// Ports that are always on[/color]
    [color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]On[/color]( [color=#006699]Port1[/color] );
    [color=#7E7E7E]////// Place additional initialization code below here[/color]
    [color=#7E7E7E]////// Place additional initialization code above here[/color]
[color=#CC6600]void[/color] [color=#CC6600]loop[/color]()
    [color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]DelayedOn[/color]( [color=#006699]Port2[/color] );
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]DayLights[/color]( [color=#006699]Port3[/color] );
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]ActinicLights[/color]( [color=#006699]Port4[/color] );
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]StandardHeater[/color]( [color=#006699]Port5[/color] );
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]Wavemaker1[/color]( [color=#006699]Port6[/color] );
    [color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]DelayedOn[/color]( [color=#006699]Port7[/color] );
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]MoonLights[/color]( [color=#006699]Port8[/color] );
    [color=#CC6600]ReefAngel[/color].[color=#006699]PWM[/color].[color=#CC6600]DaylightPWMParabola[/color]();
    [color=#CC6600]ReefAngel[/color].[color=#006699]PWM[/color].[color=#CC6600]ActinicPWMParabola[/color]();
    [color=#7E7E7E]////// Place your custom code below here[/color]
    [color=#7E7E7E]////// Place your custom code above here[/color]
[color=#CC6600]if[/color]([color=#CC6600]hour[/color]()==19 && [color=#CC6600]minute[/color]()==0 && [color=#CC6600]second[/color]()==0) [color=#CC6600]ReefAngel[/color].[color=#CC6600]FeedingModeStart[/color]();
    [color=#7E7E7E]// This should always be the last line[/color]
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]Portal[/color]( [color=#006699]"CBRpilot"[/color] );
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]DDNS[/color]( [color=#006699]"mccurryair.mynetgear.com"[/color] ); [color=#7E7E7E]// Your DDNS is CBRpilot-mccurryair.mynetgear.com.myreefangel.com[/color]
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]ShowInterface[/color]();
[/quote]
CBRpilot
Re: use float switch to turn skimmer off and add clouds
Post by CBRpilot »
how does this code look? will my delay on startup/feeding and water change still be in effect? it has everything but clouds....I'm still searching for that code
[/quote][/code]
    ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port6Bit | Port7Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port7Bit;
    ReefAngel.LightsOnPorts = Port3Bit | Port4Bit | Port6Bit;
    ReefAngel.DayLights( Port3 );
    ReefAngel.DayLights( Port4 );
    ReefAngel.StandardHeater( Port5 );
    ReefAngel.Relay.DelayedOn( Port7 );
    ReefAngel.MoonLights( Port8 );
ReefAngel.Relay.Set(Port2, ReefAngel.LowATO.IsActive() && ReefAngel.HighATO.IsActive());
if(hour()==19 && minute()==0 && second()==0) ReefAngel.FeedingModeStart();
    ReefAngel.Portal( "CBRpilot" );
    ReefAngel.DDNS( "mccurryair.mynetgear.com" ); // Your DDNS is CBRpilot-mccurryair.mynetgear.com.myreefangel.com
Your delayed start will be overwritten by this line:
Which if I'm understanding right, needs to be changed. You want either to turn off the relay, correct? Should be something like this.
ReefAngel.Relay.Set(Port2, ReefAngel.LowATO.IsActive() || ReefAngel.HighATO.IsActive());
Float switch logic always confuses me. You may have to flip the logic by changing it to !ReefAngel.HighATO.IsActive().
CBRpilot
Post by CBRpilot »
I may have to figure something else out then, I have to have delayed start or I'm sure the skimmer will be skimming way too wet (I haven't had an issue with overflowing skimmate locker but I had an extra float switch). I may have to find another port for the reactor, maybe do away with the fuge light as my macro hasn't really been growing anyway. back to the drawing boards,
thanks for the help Colin! i'll have time to play with it later this week, i'll let you know how it goes.
You could always use a regular old timer plugged into a power strip for the fuge light. :D
