I've been reading a LOT about the ATO function but can only find information about the Standard ATO setup. I'm currently just wanting to setup my single ATO switch (for low) for 30s timeout and to check every 2 hours. When using RAGen I selected the option and chose 30s (timeout) 2h (interval).
Q1) I couldn't find where this "coding" was added, so I could potentially alter it in the future. I tried the internal memory file, .pde, .h, .cpp, etc. Where is it located?
Q2)I did however find two ways of addressing this, I think. What's the difference between these two setups, and which should i use? (I found these in the forums).
[Example 1]
...void loop()
// Specific functions
ReefAngel.SingleATOLow(Port2);
// ATO available 6 times per day - 00:00 to 01:00, 04:00 to 05:00, 08:00 to 09:00, 12:00 to 13:00, 16:00 to 17:00, 20:00 to 21:00,
if (hour() % 4 == 0 && ReefAngel.LowATO.IsActive()) //Rev made 19/11/11
ReefAngel.Relay.On(Port2);
ReefAngel.Relay.Off(Port2);
[Example 2]
ReefAngel.SingleATO(bool bLow, byte ATORelay, byte byteTimeout, byte byteHrInterval);
// Autogenerated file by RAGen (v1.1.0.126), (01/13/2012 14:29)
// RA_011312_1429.pde
#define DisplayImages
#define WavemakerSetup
#define DateTimeSetup
#define VersionMenu
#define ATOSetup
#define SingleATOSetup
#define StandardLightSetup
#define ENABLE_ATO_LOGGING
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#define LightFront 1
#define LightBack 2
#define Moonlight 3
#define Refugium 4
#define Return 5
#define FlowPump 6
#define AutoTopOff 7
//#define Port8 8
ReefAngel.LCD.SetContrast(60); // Set contrast to 60
ReefAngel.Relay.On(Return); //Turn Return on at startup
ReefAngel.FeedingModePorts = B00110000;
ReefAngel.WaterChangePorts = B01110000;
ReefAngel.OverheatShutoffPorts = B00000011;
ReefAngel.LightsOnPorts = B00001111;
ReefAngel.Relay.On(Port8);
//ReefAngel.StandardGUI(); //-HAVING TROUBLE WITH THIS- Dont know if I need it, but just realized it never compiles properly even when using basic code.
//ReefAngel.SingleATO(bool bLow, byte ATORelay, byte byteTimeout, byte byteHrInterval); //Setup AutoTopOff as Auto Top-Off function with 30s timeout, and check every 2 hours.
ReefAngel.StandardLights(LightFront, 7, 30, 17, 30); //T5 Front schedule 7:30am - 5:30pm
ReefAngel.StandardLights(LightBack, 9, 30, 19, 30); //T5 Back schedule 9:30am - 7:30pm
ReefAngel.StandardLights(Moonlight, 6, 30, 20, 30); //Moonlight schedule 6:30am - 8:30am
ReefAngel.StandardLights(Moonlight, 18, 30, 20, 30); //Moonlight schedule 6:30pm - 8:30pm
ReefAngel.StandardLights(Refugium, 19, 30, 7, 0); //Refugium schedule 7:30am - 7:00pm
ReefAngel.Wavemaker1(Return); //Return Pump
ReefAngel.Wavemaker2(FlowPump); //Flow Pump
//ReefAngel.StandardHeater(Heater,785,810); // Setup Heater to turn on at 78.5F and off at 81.0F -NOT IN USE-
//ReefAngel.StandardFan(Chiller,810,785); // Setup Chiller to turn on at 81.0F and off at 78.5F -NOT IN USE-
ReefAngel.Relay.Write(); // Make relay changes effective
}Chris Schneider
