This is using Win10 on a MacPro. I tried uploading code using my laptop and can't. I am at my ends with it.The following features were automatically added:
Watchdog Timer
Version Menu
Dimming Signal
Wifi Attachment
Relay Expansion Module
Dimming Expansion Module
2014 Main Screen
Extra Font - Medium Size (8x8 pixels)
Number of Relay Expansion Modules: 1
Simple Menu
Binary sketch size: 62,832 bytes (of a 258,048 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM4 -b115200 -D -V -Uflash:w:C:\Users\LR\AppData\Local\Temp\build2484501780751041399.tmp\sketch_01_19_2015internalmem.cpp.hex:i
Using Port : \\.\COM4
Using Programmer : stk500v2
Overriding Baud Rate : 115200
avrdude: Recv:
avrdude done. Thank you.
I can't even...
- Rodasphoto
- Contact:
I can't even...
This is the error I am getting when trying to upload
Re: I can't even...
Has it ever worked on this machine? It sounds like a driver or serial port issue.
- Rodasphoto
- Contact:
Re: I can't even...
No. But I tried on my laptop on El Capitan and it did not work.
Re: I can't even...
sounds like maybe a bad serial cable then is all I can think of. I would contact roberto and ask for an rma unless he has another suggestion.
