Delay Port restart after feeding/water change
Please let me know how to delay a port restart (if it was ON) after entering feeding/ water change mode.
This is my code, if port 5 was on before feeding/water change, I'd like to delay it for 1 min, until the water level in the sump gets back to normal high. Right now, this command does nothing, no effect: ReefAngel.Relay.DelayedOn( Port5,1 );
Also, I'd like to know how to prevent the lcd from entering a weird blinking loop mode after the wifi module is connected.
#include <RA_Colors.h>q
InternalMemory.LCDID_write(255);
InternalMemory.HeaterTempOn_write(760);
InternalMemory.HeaterTempOff_write(780);
InternalMemory.OverheatTemp_write(815);
InternalMemory.IMCheck_write(0xCF06A31E);
ReefAngel.Use2014Screen();
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit | Port5Bit |Port7Bit | Port8Bit;
ReefAngel.Relay.On( Port1 ); // main pump
ReefAngel.Relay.On( Port6 ); // reserved
ReefAngel.StandardLights( Port2,11,0,18,0 ); // wavemaker
ReefAngel.StandardLights( Port3,18,0,22,0 ); //algae farm blue leds
ReefAngel.StandardLights( Port4,20,0,11,0 ); //algae farm red leds
ReefAngel.StandardLights( Port5,11,0,20,0 ); // skimmer
ReefAngel.StandardHeater( Port7,760,780 ); // heater
ReefAngel.StandardLights( Port8,11,0,20,0 ); // circulation pump
ReefAngel.Portal( "d0lph1n","****" );
Re: Delay Port restart after feeding/water change
The issue is because you have this line after overriding the DelayedOn.
I would remove that and wrap the delayed on with a time check
if (hour() >= 11 && hour()<20) ReefAngel.Relay.DelayedOn(Port5,1);
Thanks, it worked.
Any idea about my 2nd question, when the lcd reboots itself, it goes from normal, blank, blank & line... etc when the wifi module is connected?
I'm not sure on that one. Sounds like maybe a loose signal somewhere with the LCD or the connectors to the TTY
It's not doing it when i connect the usb cable. I have the feeling it has to do with wifi module; it is preventing the lcd from going in standby, some incompatibity between my old RA+ and the newer firmware.
One important detail, it's doesn't do it if the screen is already in standby and the wifi module is connected, only when the screen is on, it triggers the rebooting chaoslnevo wrote:I'm not sure on that one. Sounds like maybe a loose signal somewhere with the LCD or the connectors to the TTY
As i mentioned, the command works, i mean, the port is delayed but the skimmer is not turned off after 20:00. Please advise. Thanks.lnevo wrote:The issue is because you have this line after overriding the DelayedOn.I would remove that and wrap the delayed on with a time checkCode: Select all
Yeah sounds like a loose connection being rocked. I always have temp sensor issues when jiggling things. If the monitor is off it won't cut out and initialize badly
Few years ago, I started with RA..I added a 2nd relay unit, later, I upgraded the board to a RA+. Now, the 2nd relay unit is not connected anymore, and I don't remember if I moved any jumper(s) or not. Is it possible that an incorrect jumper setting on the RA+ board might affect the way the LCD behaves when the WIFI module is connected?lnevo wrote:Yeah sounds like a loose connection being rocked. I always have temp sensor issues when jiggling things. If the monitor is off it won't cut out and initialize badly
