Adding memory settings?
Ask in here.
troylong45
Post by troylong45 »
Currently I would like to add internal memory to be able to edit sync and antisync for dc pump
And I'll probably have later request's later for other plans
    #include <SunLocation.h>
    #include <Tide.h>
    #include <WiFiAlert.h>
    // Won't compile without this...
    // ReefAngel.DCPump.UseMemory=true;
    // Custom menus
    #include <avr/pgmspace.h>
    prog_char menu1_label[] PROGMEM = "Feeding Mode";
    prog_char menu6_label[] PROGMEM = "Date / Time";
    menu4_label, menu5_label, menu6_label
    #define Mem_I_Latitude        108
    #define Mem_I_Longitude       110
    #define Mem_B_AcclRiseOffset  112
    #define Mem_B_AcclSetOffset   113
    #define Mem_B_AcclDay         114
    #define Mem_B_LightMode       160
    #define Mem_B_LightOffset     161
    #define Mem_I_RiseOffset      162
    #define Mem_I_SetOffset       164
    #define Mem_B_AcclActinicOffset     166
    #define Mem_B_AcclDaylightOffset    167
    #define Mem_B_LightsOffPerc   171
    #define Mem_B_PrintDebug      198
    #define Mem_B_ResetMemory     199
    void init_memory() {
      InternalMemory.write_int(Mem_I_Latitude,-21);
      InternalMemory.write_int(Mem_I_Longitude,-147);
      InternalMemory.write(Mem_B_AcclRiseOffset,12);
      InternalMemory.write(Mem_B_AcclSetOffset,13);
      InternalMemory.write(Mem_B_AcclDay,0);
      InternalMemory.write(Mem_B_LightOffset,10);
      InternalMemory.write(Mem_B_LightMode,1);
      InternalMemory.write_int(Mem_I_RiseOffset,21);
      InternalMemory.write_int(Mem_I_SetOffset,21);
      InternalMemory.write(Mem_B_AcclActinicOffset,250);
      InternalMemory.write(Mem_B_AcclDaylightOffset,125);
      InternalMemory.write(Mem_B_LightsOffPerc,1);
      InternalMemory.write(Mem_B_ResetMemory,false);
    #define NUMBERS_8x16
    // Define Relay Ports by Name
    #define Return             1
    #define Heater             2
    #define WhiteLeft          3
    #define BlueLeft           4
    #define WhiteRight         5
    #define BlueRight          6
    #define Autotopoff         7
    #define Skimmer            8
    // Custom classes
    SunLocation sun;
    Tide tide;
    // For Cloud and preset code
    int DaylightPWMValue=0;
    int ActinicPWMValue=0;
    int DaylightPWMValue0=0;        // For cloud code, channel 0
    int DaylightPWMValue2=0;        // For cloud code, chennel 2
    int ActinicPWMValue1=0;        // For cloud code, channel 0
    int ActinicPWMValue3=0;        // For cloud code, chennel 2
    // Needs to be global for DrawCustomGraph()
    int ScreenID=1;
    // Setup on controller startup/reset
      ReefAngel.InitMenu(pgm_read_word(&(menu_items[0])),SIZE(menu_items)); // Initialize Menu
      ReefAngel.FeedingModePorts = Port1Bit | Port2Bit ;
      ReefAngel.WaterChangePorts = Port1Bit | Port2Bit  | Port7Bit  | Port8Bit;
      ReefAngel.LightsOnPorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit;
    ReefAngel.Relay.On( Port1 ); // Return Pump
      if (InternalMemory.read(Mem_B_ResetMemory))
        init_memory();
    ReefAngel.Relay.DelayedOn( Port1 ); // Return Pump
    ReefAngel.SingleATO(true, Port7, InternalMemory.ATOExtendedTimeout_read(), 3); // ato cycle once every 3 hour
    ReefAngel.Relay.Set(Port8, ReefAngel.HighATO.IsActive()); // Skimmer no time out
    ReefAngel.DCPump.ExpansionChannel[4] = Sync; // Left Jebao RW4
    ReefAngel.DCPump.ExpansionChannel[5] = Sync; // Right jebao rw4
      // Lighting and Flow
      SetSun();               // Setup Sun rise/set lighting
      AcclimateLED();         // Apply acclimation dimming
      LEDPresets();
      CheckCloud();           //  Check for cloud and lightning.
      UpdateLED();
       ReefAngel.Portal( "troylong45" );
    ReefAngel.DDNS( "1" ); // Your DDNS is troylong45-1.myreefangel.com
    void SetSun() {
      // Start acclimation routine
      int acclRiseOffset=InternalMemory.read(Mem_B_AcclRiseOffset)*60;
      int acclSetOffset=InternalMemory.read(Mem_B_AcclSetOffset)*60;
      byte acclDay=InternalMemory.read(Mem_B_AcclDay);
      // See if we are acclimating corals and decrease the countdown each day
      static boolean acclCounterReady=false;
      if (now()%SECS_PER_DAY!=0) acclCounterReady=true;
      if (now()%SECS_PER_DAY==0 && acclCounterReady && acclDay>0) {
        acclDay--;
        InternalMemory.write(Mem_B_AcclDay,acclDay);
      // End acclimation
      // Add some customizable offsets
      sun.Init(InternalMemory.read_int(Mem_I_Latitude), InternalMemory.read_int(Mem_I_Longitude));
      int riseOffset=InternalMemory.read_int(Mem_I_RiseOffset);
      int setOffset=InternalMemory.read_int(Mem_I_SetOffset);
      sun.SetOffset(riseOffset,(acclDay*acclRiseOffset),setOffset,(-acclDay*acclSetOffset)); // Bahamas
      sun.CheckAndUpdate(); // Calculate today's Sunrise / Sunset
      byte lightOffset=InternalMemory.read(Mem_B_LightOffset); // left right separation
      byte actinicOffset=InternalMemory.ActinicOffset_read();
      // Make sure light resets to zero at night.
      for(int i=0;i<4;i++) { ReefAngel.PWM.SetChannel(i,0); }
      switch(InternalMemory.read(Mem_B_LightMode)) {
        case 0: {
          // Daylights
          ReefAngel.PWM.Channel0PWMSlope(lightOffset,0);
          ReefAngel.PWM.Channel2PWMSlope(0,lightOffset);
          // Actinics
          ReefAngel.PWM.Channel1PWMSlope(actinicOffset+lightOffset,actinicOffset);
          ReefAngel.PWM.Channel3PWMSlope(actinicOffset,actinicOffset+lightOffset);
          break;
        case 1: {
          // Daylights
          ReefAngel.PWM.Channel0PWMParabola(lightOffset,0);
          ReefAngel.PWM.Channel2PWMParabola(0,lightOffset);
          // Actinics
          ReefAngel.PWM.Channel1PWMParabola(actinicOffset+lightOffset,actinicOffset);
          ReefAngel.PWM.Channel3PWMParabola(actinicOffset,actinicOffset+lightOffset);
          break;
      case 2: {
          // Daylights
          ReefAngel.PWM.Channel0PWMSmoothRamp(lightOffset,0);
          ReefAngel.PWM.Channel2PWMSmoothRamp(0,lightOffset);
          // Actinics
          ReefAngel.PWM.Channel1PWMSmoothRamp(actinicOffset+lightOffset,actinicOffset);
          ReefAngel.PWM.Channel3PWMSmoothRamp(actinicOffset,actinicOffset+lightOffset);
          break;
      case 3: {
          // Daylights
          ReefAngel.PWM.Channel0PWMSigmoid(lightOffset,0);
          ReefAngel.PWM.Channel2PWMSigmoid(0,lightOffset);
          // Actinics
          ReefAngel.PWM.Channel1PWMSigmoid(actinicOffset+lightOffset,actinicOffset);
          ReefAngel.PWM.Channel3PWMSigmoid(actinicOffset,actinicOffset+lightOffset);
          break;
      case 4: { // Reverse the actinics in the morning
          // Daylights
          ReefAngel.PWM.Channel0PWMParabola(lightOffset+actinicOffset,0);
          ReefAngel.PWM.Channel2PWMParabola(actinicOffset,lightOffset);
          // Actinics
          ReefAngel.PWM.Channel1PWMParabola(lightOffset,actinicOffset);
          ReefAngel.PWM.Channel3PWMParabola(0,actinicOffset+lightOffset);
          break;
    void AcclimateLED() {
      if (acclDay > 0) {
        float acclActinicOffset=acclDay*(40.95*(((float)InternalMemory.read(Mem_B_AcclActinicOffset)/100)));
        float acclDaylightOffset=acclDay*(40.95*((float)InternalMemory.read(Mem_B_AcclDaylightOffset)/100));
        float endPerc;
        endPerc=40.95*InternalMemory.PWMSlopeEnd1_read();
        ReefAngel.PWM.SetChannelRaw(1,map(ReefAngel.PWM.GetChannelValueRaw(1),0,endPerc,0,endPerc-acclActinicOffset));
        endPerc=40.95*InternalMemory.PWMSlopeEnd3_read();
        ReefAngel.PWM.SetChannelRaw(3,map(ReefAngel.PWM.GetChannelValueRaw(3),0,endPerc,0,endPerc-acclActinicOffset));
        endPerc=40.95*InternalMemory.PWMSlopeEnd0_read();
        ReefAngel.PWM.SetChannelRaw(0,map(ReefAngel.PWM.GetChannelValueRaw(0),0,endPerc,0,endPerc-acclDaylightOffset));
        endPerc=40.95*InternalMemory.PWMSlopeEnd2_read();
        ReefAngel.PWM.SetChannelRaw(2,map(ReefAngel.PWM.GetChannelValueRaw(2),0,endPerc,0,endPerc-acclDaylightOffset));
    #define LED_1to1  Box1_Port1
    #define LED_2to1  Box1_Port2
    #define LED_3to1  Box1_Port3
    #define LED_4to1  Box1_Port4
    #define LED_BLUE  Box1_Port5
    #define LED_WHITE Box1_Port6
    #define LED_STORM Box1_Port8
    void resetRelayBox(byte ID) {
      // toggle all relays except for the one selected
      for (int i=Box1_Port1;i<=Box1_Port4;i++) {
        if (i!=ID) ReefAngel.Relay.Auto(i);
    void LEDPresets() {
      static byte lastPreset=0;
      DaylightPWMValue0=ReefAngel.PWM.GetChannelValueRaw(0);
      ActinicPWMValue1=ReefAngel.PWM.GetChannelValueRaw(1);
      DaylightPWMValue2=ReefAngel.PWM.GetChannelValueRaw(2);
      ActinicPWMValue3=ReefAngel.PWM.GetChannelValueRaw(3);
      DaylightPWMValue=ReefAngel.PWM.GetDaylightValueRaw();
      ActinicPWMValue=ReefAngel.PWM.GetActinicValueRaw();
      if (ReefAngel.Relay.isMaskOn(LED_1to1)) {
        if (lastPreset!=1) resetRelayBox(LED_1to1);
        DaylightPWMValue0=90*40.95;
        ActinicPWMValue1=10*40.95;
        DaylightPWMValue2=90*40.95;
        ActinicPWMValue3=10*40.95;
        lastPreset=1;
      if (ReefAngel.Relay.isMaskOff(LED_1to1)) {
        if (lastPreset!=2) resetRelayBox(LED_1to1);
        DaylightPWMValue0=10*40.95;
        ActinicPWMValue1=90*40.95;
        DaylightPWMValue2=10*40.95;
        ActinicPWMValue3=90*40.95;
        lastPreset=2;
      if (ReefAngel.Relay.isMaskOn(LED_2to1)) {
        if (lastPreset!=3) resetRelayBox(LED_2to1);
        DaylightPWMValue0=60*40.95;
        ActinicPWMValue1=40*40.95;
        DaylightPWMValue2=60*40.95;
        ActinicPWMValue3=40*40.95;
        lastPreset=3;
      if (ReefAngel.Relay.isMaskOff(LED_2to1)) {
        if (lastPreset!=4) resetRelayBox(LED_2to1);
        DaylightPWMValue0=40*40.95;
        ActinicPWMValue1=60*40.95;
        DaylightPWMValue2=40*40.95;
        ActinicPWMValue3=60*40.95;
        lastPreset=4;
      if (ReefAngel.Relay.isMaskOn(LED_3to1)) {
        if (lastPreset!=5) resetRelayBox(LED_3to1);
        DaylightPWMValue0=75*40.95;
        ActinicPWMValue1=25*40.95;
        DaylightPWMValue2=75*40.95;
        ActinicPWMValue3=25*40.95;
        lastPreset=5;
      if (ReefAngel.Relay.isMaskOff(LED_3to1)) {
        if (lastPreset!=6) resetRelayBox(LED_3to1);
        DaylightPWMValue0=25*40.95;
        ActinicPWMValue1=75*40.95;
        DaylightPWMValue2=25*40.95;
        ActinicPWMValue3=75*40.95;
        lastPreset=6;
      if (ReefAngel.Relay.isMaskOn(LED_4to1)) {
        if (lastPreset!=7) resetRelayBox(LED_4to1);
        DaylightPWMValue0=80*40.95;
        ActinicPWMValue1=20*40.95;
        DaylightPWMValue2=80*40.95;
        ActinicPWMValue3=20*40.95;
        lastPreset=7;
      if (ReefAngel.Relay.isMaskOff(LED_4to1)) {
        if (lastPreset!=8) resetRelayBox(LED_4to1);
        DaylightPWMValue0=20*40.95;
        ActinicPWMValue1=80*40.95;
        DaylightPWMValue2=20*40.95;
        ActinicPWMValue3=80*40.95;
        lastPreset=8;
      if (ReefAngel.Relay.isMaskOn(LED_BLUE)) {
        if (lastPreset!=9) resetRelayBox(LED_BLUE);
        lastPreset=9;
      if (ReefAngel.Relay.isMaskOff(LED_BLUE)) {
        if (lastPreset!=10) resetRelayBox(LED_BLUE);
        ActinicPWMValue1=0;
        ActinicPWMValue3=0;
        lastPreset=10;
      if (ReefAngel.Relay.isMaskOn(LED_WHITE)) {
        if (lastPreset!=11) resetRelayBox(LED_WHITE);
        ActinicPWMValue1=0;
        ActinicPWMValue3=0;
        lastPreset=11;
      if (ReefAngel.Relay.isMaskOff(LED_WHITE)) {
        if (lastPreset!=12) resetRelayBox(LED_WHITE);
        lastPreset=12;
    // Write updated values to the channels
    void UpdateLED() {
      ReefAngel.PWM.SetChannelRaw(0,DaylightPWMValue0);
      ReefAngel.PWM.SetChannelRaw(1,ActinicPWMValue1);
      ReefAngel.PWM.SetChannelRaw(2,DaylightPWMValue2);
      ReefAngel.PWM.SetChannelRaw(3,ActinicPWMValue3);
      ReefAngel.PWM.SetDaylightRaw(DaylightPWMValue);
      ReefAngel.PWM.SetActinicRaw(ActinicPWMValue);
      byte LightsOffPerc=40.95*InternalMemory.read(Mem_B_LightsOffPerc);
      if (ReefAngel.PWM.GetChannelValueRaw(0)>=LightsOffPerc) ReefAngel.Relay.On(WhiteLeft); else ReefAngel.Relay.Off(WhiteLeft);
      if (ReefAngel.PWM.GetChannelValueRaw(1)>=LightsOffPerc) ReefAngel.Relay.On(BlueLeft); else ReefAngel.Relay.Off(BlueLeft);
      if (ReefAngel.PWM.GetChannelValueRaw(2)>=LightsOffPerc) ReefAngel.Relay.On(WhiteRight); else ReefAngel.Relay.Off(WhiteRight);
      if (ReefAngel.PWM.GetChannelValueRaw(3)>=LightsOffPerc) ReefAngel.Relay.On(BlueRight); else ReefAngel.Relay.Off(BlueRight);
    // Menu Code
    void MenuEntry1() {
      ReefAngel.FeedingModeStart();
    void MenuEntry2() {
    void MenuEntry3() {
      ReefAngel.ATOClear();
    void MenuEntry4() {
      ReefAngel.OverheatClear();
    void MenuEntry5() {
      ReefAngel.SetupCalibratePH();
    void MenuEntry6() {
      ReefAngel.SetupDateTime();
    // Custom Main Screen
    void DrawCustomMain() {
      const int NumScreens=4;
      static boolean drawGraph=true;
      // Main Header
      // ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 35, 2,"Troy's Reef");
      ReefAngel.LCD.DrawDate(5,2);
      ReefAngel.LCD.Clear(COLOR_BLACK, 1, 11, 128, 11);
      // Param Header
      DrawParams(5,14);
      switch (ScreenID) {
        case 0:
          if (drawGraph) { ReefAngel.LCD.DrawGraph(5,40); drawGraph=false; }
          break;
        case 1: { DrawStatus(5,40); break; }
        case 2: { DrawSunMoon(5,40); break; }
      // Draw Relays
      DrawRelays(12,94);
      // Date+Time
      // ReefAngel.LCD.DrawDate(5,122);
      if (ReefAngel.Joystick.IsLeft()) {
        ScreenID--; drawGraph=true;
      if (ReefAngel.Joystick.IsRight()) {
        ScreenID++; drawGraph=true;
      if (ScreenID<0) ScreenID=NumScreens-1;
    void DrawCustomGraph() {
      if (ScreenID==0)
        ReefAngel.LCD.DrawGraph(5, 40);
    void DrawParams(int x, int y) {
      char buf[16];
      // Temp and PH
      y+=2;
      ConvertNumToString(buf, ReefAngel.Params.Temp[T2_PROBE], 10);
      ReefAngel.LCD.DrawText(T2TempColor, DefaultBGColor, x+45, y, buf);
      y+=6;
      y+=5;
      ConvertNumToString(buf, ReefAngel.Params.Temp[T3_PROBE], 10);
      ReefAngel.LCD.DrawText(T3TempColor, DefaultBGColor, x+45, y, buf);
    void DrawStatus(int x, int y) {
      int t=x;
      ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,15,y,"High",Font8x16);
      ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,85,y,"Low",Font8x16);
      } else {
      } else {
      y+=12;
      // Display Acclimation timer
      if (acclDay > 0) {
        ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,x,y,"Acclimation Day:"); x+=100;
        ReefAngel.LCD.DrawSingleMonitor(acclDay,DefaultFGColor,x,y,1);
      } else {
        ReefAngel.LCD.Clear(DefaultBGColor,x,y,128,y+8);
    void DrawSunMoon(int x, int y) {
      char buf[16];
      int t=x;
      y+=2;
      /// Display Sunrise / Sunset
      sprintf(buf, "%02d:%02d", sun.GetRiseHour(), sun.GetRiseMinute());
      ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"Rise:"); x+=31;
      ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,x,y,buf);
      sprintf(buf, "%02d:%02d", sun.GetSetHour(), sun.GetSetMinute()); x+=36;
      ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"Set:"); x+=25;
      y+=15; x=t;
    void DrawRelays(int x, int y) {
      // Draw Relays
    void DelayedOnModes(byte relay) {
      static unsigned long startTime=now();
      if ( (startTime==LastStart) && ReefAngel.HighATO.IsActive()) {
        ReefAngel.Relay.On(relay);
      } else {
        ReefAngel.Relay.DelayedOn(relay);
     void CheckCloud()
        #define Clouds_Every_X_Days 1
        #define Cloud_Chance_per_Day 50
          // Minimum number of minutes for cloud duration.  Don't use max duration of less than 6
        #define Min_Cloud_Duration 6
        #define Max_Cloud_Duration 15
        #define Min_Clouds_per_Day 5
        #define Max_Clouds_per_Day 25
        #define Start_Cloud_After NumMins(9,00)
        #define End_Cloud_Before NumMins(18,00)
        #define Lightning_Change_per_Cloud 50
          // Add Random Lightning modes
        #define Calm 0    // No lightning
        #define Slow 1    // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
        #define Fast 2    // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
        #define Mega 3    // Lightning throughout the cloud, higher chance as it gets darker
        #define Mega2 4   // Like Mega, but with more lightning
          // Example:  { Calm, Fast, Mega, Mega2 } to randomize all four modes.
          // { Mega2 } for just Mega2.  { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
          byte LightningModes[] = { Slow };
          static byte cloudchance=255;
          static byte cloudduration=0;
          static int cloudstart=0;
          static byte numclouds=0;
          static byte cloudindex=0;
          static int LastNumMins=0;
          static byte lightningMode=0;
          static time_t DelayCounter=millis();    // Variable for lightning timing.
          static int DelayTime=random(1000);      // Variable for lightning timimg.
        #ifdef forcecloudcalculation
          if (cloudchance==255)
        #else
        #endif
              randomSeed(millis());    // Seed the random number generator
              cloudchance=random(100);
              // If we have cloud today
              if (cloudchance)
                lightningchance=random(100);
          if (cloudchance)
            //is it time for cloud yet?
              DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue/40.95,0,180)*40.95;
              if (chooseLightning)
                chooseLightning=false;
              switch (lightningMode)
              case Calm:
                break;
              case Mega:
                // Lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
                  // Send the trigger
                  Strike();
                  DelayCounter=millis();    // If we just had a round of flashes, then lets put in a longer delay
                  DelayTime=random(1000);   // of up to a second for dramatic effect before we do another round.
                break;
              case Mega2:
                // Higher lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
                  Strike();
                break;
              case Fast:
                  Strike();
                break;
              case Slow:
                // Slow lightning for 5 seconds in the middle of the cloud.  Suitable for slower ELN style drivers
                  else lightningstatus=0;
                  if (lightningstatus)
                    DaylightPWMValue=4095;
                    DaylightPWMValue=0;
                  delay(1);
                break;
              default:
                break;
              cloudindex++;
              if (cloudindex < numclouds)
            /*ReefAngel.LCD.Clear(255,0,120,132,132);
             ReefAngel.LCD.DrawText(0,255,51,120,"00:00"); */
              int x=0;
              else x=17;
              //ReefAngel.LCD.DrawText(0,255,x,120,(cloudstart/60));
              else x=35;
              //ReefAngel.LCD.DrawText(0,255,x,120,(cloudstart%60));
            //ReefAngel.LCD.DrawText(0,255,90,120,cloudduration);
            ReefAngel.CustomVar[7]=(cloudduration);    // Put the duration of the next cloud in a custom var for the portal
            if (lightningchance)
              int x=0;
              else x=57;
              //ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))/60));
              ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60;    // Write the hour of the next lightning to a custom variable for the Portal
              else x=75;
              //ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60)); // Write the minute of the next lightning to a custom variable for the Portal
        void Strike()
          int a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
          for (int i=0; i<a; i++)
            // Flash on
            int newdata=4095;
            Wire.beginTransmission(0x40);      // Address of the dimming expansion module
            Wire.write(0x8+(4*0));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 1.
            Wire.write(newdata&0xff);          // Send the data 8 bits at a time.  This sends the LSB
            Wire.write(newdata>>8);            // This sends the MSB
            Wire.endTransmission();
            Wire.write(0x8+(4*2));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 1.
            int randy=random(20,80);    // Random number for a delay
            if (randy>71) randy=((randy-70)/2)*100;    // Small chance of a longer delay
            delay(randy);                // Wait from 20 to 69 ms, or 100-400 ms
            // Flash off.  Return to baseline.
            newdata=ReefAngel.PWM.GetChannelValueRaw(0);   // Use the channel number you're flashing here
            Wire.beginTransmission(0x40);    // Same as above
            delay(random(30,50));                // Wait from 30 to 49 ms
            wdt_reset();    // Reset watchdog timer to avoid re-boots
          cstart*=60;
          cend*=60;
Re: Adding memory settings?
You just need to understand the concept. Memory settings are stored in a location. You can define that location as whatever name you want. For example
#define Mem_B_TroyLong 45
Now if I want to use that memory setting, I can read and write to that location.
So for example.
InternalMemory.write(Mem_B_TroyLong, 140);
byte troylong = InternalMemory.read(Mem_B_TroyLong);
which would be the same as InternalMemory.read(45); but you don't have to remember the number just it's name and you would get the value 140 in your variable.
Now if you want to update that number in memory
troylong=200;
InternalMemory.write(Mem_B_TroyLong, troylong);
and next time your controller reboots or reads from memory, it' will get 200 instead. The difference between this and a variable is that it's persistent if you're controller resets. Now if you want to use the standard memory locations for things like DosingPump1Repeat or use a simple DaylightPWMSlope(); function then you can remove most of the values from your function call and it should work. You can search the API too to find out what the functions can do. Usually it just involves removing the value, such as this..
ReefAngel.StandardHeater(T1_PROBE, Port1, 790, 810);
to ReefAngel.StandardHeater(Port1);
Hope this helps get you in the right direction.
Keep in mind that example is good for byte values. If you need a variable that will hold more data you will have to use read_int and write_int and the naming convention we use would change from Mem_B to Mem_I but you can use whatever name you want.
troylong45
i probly should have posted this instead of my code lol this was what i came up with befor this post was made
look ok im guessing the true and false wont work less i added somewhere for it to be defined as sync or antisync?
 #define Mem_B_SyncLPump       168
        #define Mem_B_SyncRPump       169
InternalMemory.write(Mem_B_SyncLPump,true);
          InternalMemory.write(Mem_B_SyncRPump,false);
ReefAngel.DCPump.ExpansionChannel[4] = InternalMemory.read(Mem_B_SyncLPump); // Left Jebao RW4
        ReefAngel.DCPump.ExpansionChannel[5] = InternalMemory.read(Mem_B_SyncRPump); // Right jebao rw4
