Thanks Roberto. This has been killing me this weekend
unsigned long LastUpdate1=0; // For virtual Vinegar dosing pumps
unsigned long LastUpdate2=0; // For virtual Magnesium dosing pumps
unsigned long LastUpdate3=0; // For virtual ATO dosing pump
unsigned long LastUpdate4=0; // For virtual VODKA dosing pump
ReefAngel.FeedingModePortsE[0] = Port1Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port3Bit | Port5Bit | Port7Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port5 );
ReefAngel.StandardHeater( Port7,750,755 );
ReefAngel.StandardFan( Port8,760,800 );
ReefAngel.Relay.DelayedOn( Box1_Port1,15);
ReefAngel.StandardLights( Box1_Port3,20,0,8,0 );
//ReefAngel.WaterLevelATO( Box1_Port7,60,48,50 );
ReefAngel.RF.SetMode(Constant,75,1);
//Use salinity compensation
ReefAngel.Salinity.SetCompensation(0);
//Only use the ATO when no one is in house and there is water in reservior - taken out so runs 24/7
//Use Channel 4&2 as Redundant Controls.
// Take out ATO tank check 05.02.16
//if (ReefAngel.WaterLevel.GetLevel(4)<= 25 && ReefAngel.WaterLevel.GetLevel(1)>0) ReefAngel.Relay.On(Box1_Port7);
if (ReefAngel.WaterLevel.GetLevel(4)<=25)
}else if (ReefAngel.WaterLevel.GetLevel(4)>30){
//Turn-off Skimmer whhen skimmer tank is full
if (ReefAngel.WaterLevel.GetLevel(3)>=90)
}else{
//How about some WaveMotion with the Vortech
static time_t feeding;
// Time schedule first
//Wave PatternslseDuration, boolean PulseSync);
//byte GyreMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync);
//byte SineMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync);
//byte ReefCrestMode(byte WaveSpeed, byte WaveOffset, boolean PulseSync);
//byte NutrientTransportMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync);
//byte TidalSwellMode(byte WaveMaxSpeed, boolean PulseSync);
//byte TideMode(byte WaveSpeed, byte minOffset, byte maxOffset);
//byte ElseMode(byte midPoint, byte offset, boolean waveSync);
if (hour()>=6 && hour()<7) {
ReefAngel.PWM.SetDaylight( LongPulseMode(35,100,5,true) ); // Long pulse hi/low 50%20% 10s pulse on sync mode
ReefAngel.PWM.SetActinic( LongPulseMode(35,100,5,false) ); // Long pulse hi/low 50%20% 10s pulse on anti-sync mode
} else if (hour()>=7 && hour()<8) {
ReefAngel.PWM.SetDaylight ( ElseMode(80,20, true) ); // Short pulse at 60% with 200m
ReefAngel.PWM.SetActinic( ElseMode(80,20,false) ); // Short pulse at 60% with 200ms pulse on anti-sync mode
} else if (hour()>=8 && hour()<9) {
ReefAngel.PWM.SetDaylight( SineMode(35,100,180,true)); //Ramp up to 100% in 3mins in sync mode
ReefAngel.PWM.SetActinic( SineMode(35,100,180,true)); //Ramp up to 100% in 3mins in sync mode
} else if (hour()>=9 && hour()<10) {
ReefAngel.PWM.SetDaylight( TidalSwellMode(100,true)); //Ramp up to 100% in 3mins in sync mode
ReefAngel.PWM.SetActinic( TidalSwellMode(100,false)); //Ramp up to 100% in 3mins in sync mode
} else if (hour()>=10 && hour()<11) {
ReefAngel.PWM.SetDaylight( ShortPulseMode(35,100,2000,true) ); // Short pulse at 30% - 100% with 2000ms pulse on sync mode
ReefAngel.PWM.SetActinic( ShortPulseMode(35,100,2000,false) ); // Short pulse at 30% - 100% with 2000ms pulse on anti-sync mode
} else if ( (hour()>=11 && hour()<12) && (now()-feeding > SECS_PER_DAY) ) { // We haven't fed today
ReefAngel.PWM.SetDaylight( NutrientTransportMode(35,100,5000,true) );
ReefAngel.PWM.SetActinic( NutrientTransportMode(35,100,5000,false) );
} else if (hour()>=11 && hour()<12) {
ReefAngel.PWM.SetDaylight( ReefCrestMode(80,20,true) ); // ReefCrest at 70% +/- 20% on sync mode
ReefAngel.PWM.SetActinic( ReefCrestMode(80,20,false) ); // ReefCrest at 70% +/- 20% on anti-sync mode
} else if (hour()>=12 && hour ()<13) {
ReefAngel.PWM.SetDaylight( ShortPulseMode(35,100,500,true) ); // Short pulse at 60% with 200ms pulse on sync mode
ReefAngel.PWM.SetActinic( ShortPulseMode(35,90,500,false) ); // Short pulse at 60% with 200ms pulse on anti-sync mode
} else if (hour()>=13 && hour ()<14) {
} else if (hour()>=14 && hour()<15) {
//ReefAngel.PWM.SetDaylight ( ElseMode( 80,20, true) ); // Short pulse at 60% with 200m
//ReefAngel.PWM.SetActinic( ElseMode(80,20,false) ); // Short pulse at 60% with 200ms pulse on anti-sync mode
ReefAngel.PWM.SetDaylight ( GyreMode( 35, 100, 10, true) ); // Short pulse at 60% with 200m
ReefAngel.PWM.SetActinic( GyreMode(35,100, 10, true) ); // Short pulse at 60% with 200ms pulse on anti-sync mode
} else if (hour()>=15 && hour()<16) {
ReefAngel.PWM.SetDaylight( SineMode(35,100,30,true)); //Ramp up to 70% in 10mins in sync mode
ReefAngel.PWM.SetActinic( SineMode(35,100,30,true)); //Ramp up to 70% in 10mins in sync mode
} else if (hour()>=16 && hour()<17) {
ReefAngel.PWM.SetDaylight( NutrientTransportMode(30,100,250,true) );
ReefAngel.PWM.SetActinic( NutrientTransportMode(30,100,250,false) );
} else if (hour()>=17 && hour ()<18) {
ReefAngel.PWM.SetDaylight( SineMode(35,100,20, true)); //Ramp up to 70% in 10mins in sync mode
ReefAngel.PWM.SetActinic( SineMode(35,100,20, false)); //Ramp up to 70% in 10mins in sync mode
} else if (hour()>=18 && hour ()<19) {
} else if (hour()>=19 && hour ()<20) {
ReefAngel.PWM.SetDaylight( GyreMode(35,100, 10, true)); //Ramp up to 70% in 10mins in sync mode
ReefAngel.PWM.SetActinic( GyreMode(35,100, 10, false)); //Ramp up to 70% in 10mins in sync mode
} else if (hour()>=20 && hour ()<21) {
ReefAngel.PWM.SetDaylight( GyreMode(35,100, 120, true)); //Ramp up to 70% in 10mins in sync mode
ReefAngel.PWM.SetActinic( GyreMode(35,100, 120, false)); //Ramp up to 70% in 10mins in sync mode
} else {
ReefAngel.PWM.SetDaylight( SineMode(35,100,5,true)); //Ramp up to 70% in 10mins in sync mode
ReefAngel.PWM.SetActinic( SineMode(35,100,5,true)); //Ramp up to 70% in 10mins in sync mode
// If we are feeding override the schedule
ReefAngel.PWM.SetDaylight(35);
ReefAngel.PWM.SetActinic(35);
//Vortech
ReefAngel.RF.SetMode( Constant,50,100 );
feeding=now();
// If we have finished feeding, start NTM for 3 hours
if (now()-feeding < 3*SECS_PER_HOUR)
ReefAngel.PWM.SetDaylight( NutrientTransportMode(35,100,500,true) );
ReefAngel.PWM.SetActinic( NutrientTransportMode(35,100,500,false) );
//vortech
ReefAngel.RF.SetMode(Smart_NTM,100,10);
//Do not use the memory bits inside the Vortech
//Time based Vortech Schedule
/*Used by the RF Expansion Module
Vortech Modes
Constant 0
Lagoon 1
ReefCrest 2
ShortPulse 3
LongPulse 4
mart_NTM 5 // Nutrient Transport Mode
Smart_TSM 6 // Tidal Swell Mode
Storm 10
Custom 11
The function is SetMode(Mode,Speed,Duration) and the parameter are:
Mode can be one of the following modes:
* Constant
* Random1 (Lagoonal)
* Random2 (Reef Crest)
* ShortWave (Short Pulse)
* LongWave (Long Pulse)
* Smart_NTM (Nutrient Transport Mode)
* Smart_TSM (Tidal Swell Mode)
* Storm (will only be available on the upcoming Dev libraries update or by using 10 instead of Storm)
* Custom (will only be available on the upcoming Dev libraries update or by using 11 instead of Custom)
Speed is a number from 0 through 100
Duration is only applicable to ShortWave, LongWave and Smart_NTM and represent the following:
ShortWave - tenths of a second
LongWave - seconds
Smart_NTM - tenths of a second
The function for Custom mode is SetMode(Mode,Speed,Channel) and the parameter are:
Mode: Custom
Channel:
0 - Sync
1- Anti-Sync
2- Back of Tank
ReefAngel.RF.SetMode(ReefCrest,100,10);
ReefAngel.RF.SetMode(Smart_TSM,100,0);
ReefAngel.RF.SetMode(ShortWave,100,100);
} else if (hour()>=12 && hour()<13) {
ReefAngel.RF.SetMode(Smart_NTM,100,100);
} else if (hour()>=13 && hour()<14) {
ReefAngel.RF.SetMode(Storm,100,1);;
} else if (hour()>=14 && hour()<15){
ReefAngel.RF.SetMode(LongWave,100,5);
ReefAngel.RF.SetMode(Smart_TSM,100,10);
} else if (hour()>=17 && hour()<18) {
ReefAngel.RF.SetMode(ShortWave,100,10);
} else if (hour()>=18 && hour()<19) {
} else if (hour()>=19 && hour()<20) {
ReefAngel.RF.SetMode(Storm,100,10);;
} else if (hour()>=20 && hour()<21){
ReefAngel.RF.SetMode(LongWave,100,7);
} else {
ReefAngel.RF.SetMode(Lagoon,75,10);
//ReefAngel.RF.SetMode(Storm,100,1);
//Code to make Vodka Dosing Work one time a day for 2 mins
//COmment our 05.02.16
//Turn on at 8:00 AM
/// ReefAngel.DosingPumpRepeat(Box1_Port6,480,1440,120);
///Code to make Vinegar Dosing Work 4 mins
///02.15.16 = Changed to dosing Amino Acid every 3 hrs for 2 mins, on top of hours
///02.2616 = Changed to dosing Amino Acid every 3 hrs for 4 mins, on 15 of hour
///05.02.16 = Changed to dosing Amino Acid every 3 hrs for 4 mins, on 15 of hour
///Start at 12:00AM
ReefAngel.DosingPumpRepeat(Box1_Port8,0,180,60);
///Do not turn on Vinegar if lights are off
///02-15-16 = Changed to Dosing AA throughout the day
/// if (hour()<=8 || hour()>21) {
/// ReefAngel.Relay.Off(Box1_Port8);
//Code to make Magnesium Dosing Work
///02.15.16 = Changed to dosing Amino Acid every 3 hrs for 2 mins, on 15 of hour
///05.02.16 = Changed to dosing Amino Acid every 3 hrs for 1 min, on 15 of hour
///Start at 12:15AM
ReefAngel.DosingPumpRepeat(Box1_Port4,15,180,60);
//Code to check that the dosing pumps are running
// ******************* Turn on imaginary relays for 5 minutes when dosing pumps activate so Portal can track them *******************
// Vinegar port
if (ReefAngel.Relay.Status(Box1_Port8) && LastUpdate1==0)
LastUpdate1 = now();
ReefAngel.Relay.On (Box2_Port1);
if (now() - LastUpdate1 >= 600 && LastUpdate1 != 0)
LastUpdate1 = 0;
ReefAngel.Relay.Off (Box2_Port1);
// Magnesium Port
if (ReefAngel.Relay.Status(Box1_Port4) && LastUpdate2==0)
LastUpdate2 = now();
ReefAngel.Relay.On (Box2_Port2);
if (now() - LastUpdate2 >= 600 && LastUpdate2 != 0)
LastUpdate2 = 0;
ReefAngel.Relay.Off (Box2_Port2);
// ATO Port
if (ReefAngel.Relay.Status(Box1_Port7) && LastUpdate3==0)
LastUpdate3 = now();
ReefAngel.Relay.On (Box2_Port3);
if (now() - LastUpdate3 >= 600 && LastUpdate3 != 0)
LastUpdate3 = 0;
ReefAngel.Relay.Off (Box2_Port3);
// Vodka Port
if (ReefAngel.Relay.Status(Box1_Port6) && LastUpdate4==0)
LastUpdate4 = now();
ReefAngel.Relay.On (Box2_Port4);
if (now() - LastUpdate4 >= 600 && LastUpdate4 != 0)
LastUpdate4 = 0;
ReefAngel.Relay.Off (Box2_Port4);
// This should always be the last line1
ReefAngel.Portal("Paul_Velasco");
