Wifi not working today
Not sure what's going on but I can't connect to my reef angel from the app. I tried unplugging the wireless adapter from the reef angel and unplugged my modem still getting the unable to process controller data. Usually I can just unplug and reconnect and it starts working again but not this time. It has the one blinking green light. I'm trying to do a water change but I'm unable to turn relays on or off for my mixing pump.
Re: Wifi not working today
If it is just blinking green, it is connected to your WiFi network.
Check on the router. It may have changed the ip address.
I can get through the portal just not the app.
Why would I be able to access it through the web portal but not the app? I I can pull up the web portal and toggle things on and off yet when I pull up the app it won't load. I haven't changed anything on either the app or the portal.
Ok figured it out. Had use a different IP address. Looked at the one on the portal and plugged that in and it started working. Not sure why it changed I had it set up as a web address type IP address.
