Wifi will not connect after firmware update
Re: Wifi will not connect after firmware update
They usually are.
I just want to make sure you don't have one that got missed.
I have tried all of the above and still the wifi device will not connect. Any other suggestions?
Can you post the log of what you got on tera term screen?
Just tried to use the script again, the following was shown on the screen.
à`Pqpàp >xðÀ 0 y`Ã}_~¹ý:þ÷þ EÜ(?ø>?Ѿû ýøÈþàwôô¾ÿÎ0¿?ðÿÿð
þð
þð
You are probably not choosing the correct baud rate.
Please follow the instructions carefully.
Try using 57600 baud as mentioned in the instruction.
Changing the baud rate to 57600 did not change anything. Still will not work with the wifi utility.
Are you talking about wifi utility or Tera term. Two different ways of setting it up.
Can you post the log you get with 57600 baud?
Everything loads with terterm. When the script is complete, I then try the wifi utility and it gives me an error, no blinking lights. The wifi screen says, Please wait, attempting to communicate with the Reef Angel wifi attachment.
"Error" Please disconnect and then reconnect the Reef Angel wifi attachment from the USB ttl cable and try again.
If you use tera term and it is successful, the wifi attachment should already be configured and you don't need the wifi utility anymore.
If the wifi attachment has no blinking lights, it is probably not working and it shouldn't be able to accept the script from tera term.
Can you please post the log of tera term?
The characters listed below are the only things printed on the teraterm screen.
Ðþÿþ
Ðþÿþ
That means the macro never ran correctly.
Is the green LED blinking? How about blue?
If you want to send it back to have it checked out, send me a PM.
is this all we need to change in the ttl file?rimai wrote:sendln 'set wlan ssid testing'
sendln 'set wlan pass a01b02c03d'
hi @rimai please can you assist i followed the steps after making error of update copied and pasted earlier post of steps...
1. I updated firmware and then was trying every method for connection with no results.
2. I tried then to revert firmware via Macro suggested by 'Rimai' but was automatically changing to baud rate of 57600 (I thought I was supposed to do that)
did exactly this then:
Tried with default Baud of 9600 but no luck. blue lights are still flashing
any further advice?
any further advice?
sorry double post
CMD
factory RESET
Set Factory Defaults
<4.41> reboot
*Reboot*CMD
set ftp address 198.175.253.161
AOK
<4.41> save
Storing in config
<4.41> set wlan ssid Pretty-Fly-forset wlan pass Khe
AOK
<4.41> set option deviceid ReefAngelWifi
AOK
<4.41> set w j 1
AOK
<4.41> set c c 0
AOK
<4.41> set c r 0
AOK
<4.41> set c o 0
AOK
<4.41> set i d 1
AOK
<4.41> set c i 3
AOK
<4.41> set dns name http://www(.)reefangel(.)com
AOK
<4.41> set i h 23.24.193.9
AOK
<4.41> set i r 80
AOK
<4.41> set i f 0x06
AOK
<4.41> set s t 0x10
AOK
<4.41> set u m 2
AOK
<4.41> set i p 2
AOK
<4.41> set u b 57600
AOK
<4.41> set s p 0
AOK
<4.41> set c s 1420
AOK
<4.41> save
Storing in config
<4.41> save user
Storing in user
<4.41> reboot
*Reboot*
edited passphrase
edited brackets into url
also full name of my ssid is Pretty-Fly-for-a-Wi-Fi and is entered as such into Tll file
factory RESET
<4.41> reboot
*Reboot*CMD
AOK
<4.41> save
Storing in config
AOK
AOK
<4.41> set w j 1
AOK
<4.41> set c c 0
AOK
<4.41> set c r 0
AOK
<4.41> set c o 0
AOK
<4.41> set i d 1
AOK
<4.41> set c i 3
AOK
AOK
AOK
<4.41> set i r 80
AOK
<4.41> set i f 0x06
AOK
<4.41> set s t 0x10
AOK
<4.41> set u m 2
AOK
<4.41> set i p 2
AOK
AOK
<4.41> set s p 0
AOK
<4.41> set c s 1420
AOK
<4.41> save
Storing in config
<4.41> save user
Storing in user
<4.41> reboot
*Reboot*
edited passphrase
I'm not so sure that it will take those dashes.
Can you try changing your said and pass tobe alpha numeric only?
i will, just so you know, it makes me sad. i was quite proud of that name lol
still no luck, blue lights still flashing
MD
factory RESET
<4.41> reboot
*Reboot*CMD
AOK
<4.41> save
Storing in config
<4.41> set wlan ssid PrettyFlyForAWset wlan pass Khan87home
AOK
AOK
<4.41> set w j 1
AOK
<4.41> set c c 0
AOK
<4.41> set c r 0
AOK
<4.41> set c o 0
AOK
<4.41> set i d 1
AOK
<4.41> set c i 3
AOK
<4.41> set dns name www.reefangel.com
AOK
AOK
<4.41> set i r 80
AOK
<4.41> set i f 0x06
AOK
<4.41> set s t 0x10
AOK
<4.41> set u m 2
AOK
<4.41> set i p 2
AOK
AOK
<4.41> set s p 0
AOK
<4.41> set c s 1420
AOK
<4.41> save
Storing in config
<4.41> save user
Storing in user
<4.41> reboot
*Reboot*
MD
factory RESET
<4.41> reboot
*Reboot*CMD
AOK
<4.41> save
Storing in config
AOK
AOK
<4.41> set w j 1
AOK
<4.41> set c c 0
AOK
<4.41> set c r 0
AOK
<4.41> set c o 0
AOK
<4.41> set i d 1
AOK
<4.41> set c i 3
AOK
AOK
AOK
<4.41> set i r 80
AOK
<4.41> set i f 0x06
AOK
<4.41> set s t 0x10
AOK
<4.41> set u m 2
AOK
<4.41> set i p 2
AOK
AOK
<4.41> set s p 0
AOK
<4.41> set c s 1420
AOK
<4.41> save
Storing in config
<4.41> save user
Storing in user
<4.41> reboot
*Reboot*
nevermind, shortened SSId and Success! thank you
Is this still the updated macro? I'm not sure what host is the right one.
HOST=104.36.18.155:80
EDIT: Looks like this host is working. My portal began updating. It won't work in Chrome for some reason though. Whole page goes blank.
-You had me at PWM
i went through as advised. it says ERR on the log. doesnt seem like i can get any charts to come up though, still.
AOK
<4.41> save
Storing in config
<4.41> Monroe
ERR: ?-Cmd
<4.41> 3612129248
ERR: ?-Cmd
AOK
<4.41> set w j 1
AOK
<4.41> set c c 0
AOK
<4.41> set c r 0
AOK
<4.41> set c o 0
AOK
<4.41> set i d 1
AOK
<4.41> set c i 3
AOK
AOK
<4.41> set i h 104.36.18.155
AOK
<4.41> set i r 80
AOK
<4.41> set i f 0x06
AOK
<4.41> set s t 0x10
AOK
<4.41> set u m 2
AOK
<4.41> set i p 2
AOK
AOK
<4.41> set s p 0
AOK
<4.41> set c s 1420
AOK
<4.41> save
Storing in config
<4.41> save user
Storing in user
<4.41> reboot
*Reboot*
AOK
<4.41> save
Storing in config
<4.41> Monroe
ERR: ?-Cmd
<4.41> 3612129248
ERR: ?-Cmd
AOK
<4.41> set w j 1
AOK
<4.41> set c c 0
AOK
<4.41> set c r 0
AOK
<4.41> set c o 0
AOK
<4.41> set i d 1
AOK
<4.41> set c i 3
AOK
AOK
AOK
<4.41> set i r 80
AOK
<4.41> set i f 0x06
AOK
<4.41> set s t 0x10
AOK
<4.41> set u m 2
AOK
<4.41> set i p 2
AOK
AOK
<4.41> set s p 0
AOK
<4.41> set c s 1420
AOK
<4.41> save
Storing in config
<4.41> save user
Storing in user
<4.41> reboot
*Reboot*
You edited the file incorrectly.
You should only replace the testing2 and a01b02c03d and not the entire line.
sendln 'set wlan ssid testing2'
wait 'AOK'
wait 'AOK'
ahh. thank you. i fixed it.
Just how long should this process take? Is this how it ends? This is from the Tera Term window:
CMD
factory RESET
<4.00> reboot
*Reboot*CMD
AOK
<4.00> save
Storing in config
<4.00> set wlan ssid The Bat Cave
AOK
<4.00> set wlan pass Youshallnotpass
AOK
<4.00> set option deviceid ReefAngelWifi
AOK
<4.00> set w j 1
AOK
<4.00> set c c 0
AOK
<4.00> set c r 0
AOK
<4.00> set c o 0
AOK
<4.00> set i d 1
AOK
<4.00> set c i 3
AOK
<4.00> set dns name www.reefangel.com
AOK
<4.00> set i h 104.36.18.155
AOK
<4.00> set i r 80
AOK
<4.00> set i f 0x06
AOK
<4.00> set s t 0x10
AOK
<4.00> set u m 2
AOK
<4.00> set i p 2
AOK
<4.00> set u b 57600
AOK
<4.00> set s p 0
AOK
<4.00> set c s 1420
AOK
<4.00> save
Storing in config
<4.00> save user
Storing in user
<4.00> reboot
*Reboot*CMD
factory RESET
<4.00> reboot
*Reboot*CMD
AOK
<4.00> save
Storing in config
AOK
AOK
AOK
<4.00> set w j 1
AOK
<4.00> set c c 0
AOK
<4.00> set c r 0
AOK
<4.00> set c o 0
AOK
<4.00> set i d 1
AOK
<4.00> set c i 3
AOK
AOK
AOK
<4.00> set i r 80
AOK
<4.00> set i f 0x06
AOK
<4.00> set s t 0x10
AOK
<4.00> set u m 2
AOK
<4.00> set i p 2
AOK
AOK
<4.00> set s p 0
AOK
<4.00> set c s 1420
AOK
<4.00> save
Storing in config
<4.00> save user
Storing in user
<4.00> reboot
*Reboot*
CMD
factory RESET
<4.00> reboot
*Reboot*CMD
AOK
<4.00> save
Storing in config
AOK
AOK
AOK
<4.00> set w j 1
AOK
<4.00> set c c 0
AOK
<4.00> set c r 0
AOK
<4.00> set c o 0
AOK
<4.00> set i d 1
AOK
<4.00> set c i 3
AOK
AOK
AOK
<4.00> set i r 80
AOK
<4.00> set i f 0x06
AOK
<4.00> set s t 0x10
AOK
<4.00> set u m 2
AOK
<4.00> set i p 2
AOK
AOK
<4.00> set s p 0
AOK
<4.00> set c s 1420
AOK
<4.00> save
Storing in config
<4.00> save user
Storing in user
<4.00> reboot
*Reboot*CMD
factory RESET
<4.00> reboot
*Reboot*CMD
AOK
<4.00> save
Storing in config
AOK
AOK
AOK
<4.00> set w j 1
AOK
<4.00> set c c 0
AOK
<4.00> set c r 0
AOK
<4.00> set c o 0
AOK
<4.00> set i d 1
AOK
<4.00> set c i 3
AOK
AOK
AOK
<4.00> set i r 80
AOK
<4.00> set i f 0x06
AOK
<4.00> set s t 0x10
AOK
<4.00> set u m 2
AOK
<4.00> set i p 2
AOK
AOK
<4.00> set s p 0
AOK
<4.00> set c s 1420
AOK
<4.00> save
Storing in config
<4.00> save user
Storing in user
<4.00> reboot
*Reboot*
That should be it, except that SSID cannot have spaces.
You have to replace them with $, I think
