3 black box (SB Basics) on Dimming Expansion
DmnYnkee
Post by DmnYnkee »
I have ordered both the dimming expansion, and (3) SB ReefLights basic black boxes. I am upgrading from a 2 channel T5 fixture. My tank is 150 gallon mixed reef, 5x2x2 .
Currently:
I have my Blues turning on/off with local sunrise/sunset, with an hour later offset for better viewing time. My whites are on a 195 minute offset from the actinics. My current moonlights are run by a cheap Walmart timer as I don't have any ports available. I am not addressing moonlights at this time, but will in the future.
What I am wanting to do:
I will have my 3 black boxes running off the dimming expansion. I know I will need to slowly acclimate my tank to these new lights, and I am fine with having to adjust max and reload code as I ramp up intensity over time
Ch0 = Left Blue
Ch1 = Left White
Ch2 = Center Blue
Ch3 = Center White
Ch4 = Right Blue
Ch5 = Right White
I will use Parabolas for all 6 channels, but will want left to start first, then center (30 minutes later?), then right (30 minutes after center?). An East to West effect is what I am going for, the delay time may need to be tweaked and I welcome input here.
I would like clouds to "move" across all 3 lights, but random (selected daily) on left to right, or right to left. To clarify, today all clouds will move east to west, but tomorrow they could move west to east all day. I will also want the variable degree of lightning effects, with the ability to call storms on demand (can this be done with the iPhone app).
I know a lot, if not all of this work has already been done, and I am just starting to work on my code so it will be ready once my lights arrive, and I finish hacking them to work with the dimming expansion. I have been going through the various threads on this subject, but have not found (yet) where someone has applied the logic for 3 lights. I am still very much a novice when it comes to coding.
Any insight is appreciated. Thanks!
Current code below for reference:
#include <SunLocation.h>
#include <Tide.h>
#include <Moon.h>
#include <WiFiAlert.h>
  SunLocation sl;
  int avgph[10];
    unsigned long totalavgph=0;
    byte avgindex=0;
      byte x;
      byte y = 2;
      char text[7];
      // *********** CHANGE TEMP READOUT COLOR DEPENDENT ON FAN AND HEATER STATUS ***********
      int TempColor;                                    // Color for drawing temperature
      boolean HeatOn = ReefAngel.Relay.Status(Port6);   // Get the status of the heater relay
      if (HeatOn)
        TempColor = COLOR_NAVY;                         // Blue text, too cold, heater is on
      if (!HeatOn)
          TempColor = COLOR_GREEN;                      // Green text, no fan or heater on
             int pHColor;                                 // Color for drawing pH
      boolean LowpH = (ReefAngel.Params.PH < 780) ;     // Check for Low pH Value
      boolean HighpH = (ReefAngel.Params.PH > 850);     // Check for High pH Value
      if (LowpH)
        pHColor = COLOR_NAVY;                          // Blue text, Low pH value
      if (HighpH)
        pHColor = COLOR_RED;                           // Red text, High pH value
      if (!LowpH && !HighpH)
        pHColor = COLOR_GREEN;                         // Green text, pH acceptable
      ReefAngel.LCD.DrawLargeText(COLOR_DARKSLATEBLUE,DefaultBGColor, 6, 3, " Thunder Reef",Font8x8);   // Put a banner at the top
      ReefAngel.LCD.DrawDate(6, 119);        // Put the date and time at the bottom
      ReefAngel.LCD.Clear(COLOR_BLACK, 1, 12, 132, 12);                                                 // Draw a black line under the banner
      x = 6;
      y += MENU_START_ROW*1.4;        // MENU_START_ROW is 10, according to globals.h, so y=2+10+1=13
      ReefAngel.LCD.DrawLargeText(COLOR_BLUE, COLOR_WHITE, x, y+1, " Temp      pH");
      ConvertNumToString(text, ReefAngel.Params.Temp[T1_PROBE], 10);                                    // Get T1 temp and convert
      x = 2;
      y += MENU_START_ROW*1.6;
      ReefAngel.LCD.DrawHugeNumbers(COLOR_BLACK, TempColor, x, y, text);                                // Draw the temperature, white numbers on a colored background
      ConvertNumToString(text, ReefAngel.Params.PH, 100);                                               // Get pH reading and convert
      x = 2;
      y = MENU_START_ROW*2.6;
      ReefAngel.LCD.DrawHugeNumbers(COLOR_YELLOW, pHColor, x+65, y+6, text);                            // Put pH on the screen
      x += 6;
      y += MENU_START_ROW*3.3;
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,25,y,"Sump Level",Font8x8);      // Draw the Sump Float switch status
  {ReefAngel.LCD.FillCircle(15,y+3,7,COLOR_RED);
  ReefAngel.LCD.FillCircle(15,y+3,7,COLOR_GREEN);
  x += 6;
  y += MENU_START_ROW*2.0;
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,25,y,"Skimmer Cup",Font8x8);     // Draw the Skimmer Cup Float switch status
  if (ReefAngel.HighATO.IsActive()) {ReefAngel.LCD.FillCircle(15,y+3,7,COLOR_GREEN);
      byte TempRelay = ReefAngel.Relay.RelayData;                                          // Code for drawing the relay box
      ReefAngel.LCD.DrawOutletBox(12, 100, TempRelay);
unsigned long LastUpdate1=0;    // For virtual dosing pumps
    ReefAngel.Init();        //Initialize controller
    ReefAngel.Use2014Screen();                                                               // Let's use 2014 Screen
    ReefAngel.FeedingModePorts = Port7Bit;                                                   // Ports toggled in Feeding Mode
    ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;       // Ports toggled in Water Change Mode
    ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit;                                // Ports toggled when Lights On / Off menu entry selected
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit | Port6Bit | Port7Bit;   // Ports turned off when Overheat temperature exceeded
    ReefAngel.TempProbe = T1_PROBE;                                                          // Use T1 probe as temperature and overheat functions
    InternalMemory.OverheatTemp_write( 830 );                                                // Set the Overheat temperature setting
    // Delayed start for skimmer to allow sump level to return to normal after water change or feed mode
    ReefAngel.Relay.DelayedOn( Port7,4 );
    sl.Init(28.5708, -81.6995);    // Lat/long for Clermont, FL
    sl.SetOffset(-3,0,-3,0);       // rise_hour, rise_seconds, set_hour, set_seconds (set 1 hr later for better viewing time)
    randomSeed(now()%SECS_PER_DAY);
      //Custom Variable [0] =  Month/Season
    ReefAngel.CustomLabels[0]="Return";
    ReefAngel.CustomLabels[1]="Daylights";
    ReefAngel.CustomLabels[2]="Actinics";
    ReefAngel.CustomLabels[3]="Fuge Light";
    ReefAngel.CustomLabels[4]="Kalk Dosing";
    ReefAngel.CustomLabels[5]="Heater";
    ReefAngel.CustomLabels[6]="Skimmer";
    ReefAngel.CustomLabels[7]="ATO RoDi";
    // seasonal temperatures
    SeasonalTemps();
    ReefAngel.DayLights( Port2 );             // ATI DayLights (White+Purple)  On 195 min after sunrise, off 195 min before sunset.
    ReefAngel.ActinicLights( Port3 );         // ATI Actinic+ Lights (Blues).   On at sunrise, off at sunset.
    ReefAngel.MoonLights( Port4 );            // Refugium light.  On 195 min before sunset, off 195 min after sunrise.
    ReefAngel.DosingPumpRepeat( Port5,0,10,22 );
// Kalk Dosing (2 tsp per gal), Port 5.  Between 8pm & 11am, Every 10 minutes run for 22 seconds.
if (hour()>=11 && hour()<20) ReefAngel.Relay.Off(Port5);
// WP-25 powerheads schedule
if (hour()>=9 && hour()<13)
 ReefAngel.PWM.SetDaylight( ReefCrestMode(52,12,true) ); // reefcrest at 55% +/- 12% on sync mode       (Day Mode)
 ReefAngel.PWM.SetActinic( ReefCrestMode(52,12,false) ); // reefcrest at 55% +/- 12% on Anti-sync mode  (Day mode)
else if (hour()>=13 && hour()<18)
 ReefAngel.PWM.SetDaylight( ShortPulseMode(0,68,408,true) ); // Short pulse at 68% with 408ms pulse on sync mode (3/4" surface wave)
 ReefAngel.PWM.SetActinic( ShortPulseMode(0,68,408,false) ); // Short pulse at 68% with 408ms pulse on Anti-sync mode (3/4" surface wave)
else if (hour()>=18 && hour()<19)
 ReefAngel.PWM.SetDaylight( LongPulseMode(35,70,2,true) ); // Long Pulse 35% ramping up to 70% for 2 seconds on sync mode (nutrient transport)
 ReefAngel.PWM.SetActinic( LongPulseMode(35,70,2,false) ); // Long Pulse 35% ramping up to 70% for 2 seconds on Anti-sync mode  (nutrient transport)
else if (hour()>=19 && hour()<20)
 ReefAngel.PWM.SetDaylight( ReefCrestMode(48,8,true) ); // reefcrest at 48% +/- 8% on sync mode       (night Mode)
 ReefAngel.PWM.SetActinic( ReefCrestMode(48,8,false) ); // reefcrest at 48% +/- 8% on Anti-sync mode  (night mode)
if( ReefAngel.DisplayedMenu==FEEDING_MODE )
 ReefAngel.PWM.SetActinic( LongPulseMode(0,37,1,true) );
 ReefAngel.PWM.SetDaylight( LongPulseMode(0,37,1,true) );
if( ReefAngel.DisplayedMenu==WATERCHANGE_MODE )
 ReefAngel.PWM.SetActinic(35);
 ReefAngel.PWM.SetDaylight(35);
// enter feeding mode at 11am & 5pm
 if ( (hour()==11 && minute()==0 && second()==0))
 ReefAngel.FeedingModeStart(); // turn on feeding mode
  if ( (hour()==17 && minute()==0 && second()==0))
if(ReefAngel.HighATO.IsActive())           //  Float switch in Skimmer Locker
 ReefAngel.Relay.Off(Port7);               //  Turn off Skimmer when locker full.
// ATO, Port 8 is ATO using Clear RoDi
 ReefAngel.SingleATO(true,Port8,400,0);   //  Sump switch.  If ATO/RoDi runs for 400 seconds, then shut off and send alert.
    sl.CheckAndUpdate();  // handle updating sunrise and sunset values
    ReefAngel.Portal( "DmnYnkee" );
 void SeasonalTemps ()
  static int heatArray[][2] = { {796,800},                  // default in case of error in month=0 (June)
                    {781,785},//January (winter)            // 78.3
                    {784,788},//February (winter)           // 78.6
                    {787,791},//March (early spring)        // 78.9
                    {790,794},//April (spring)              // 79.2
                    {793,797},//May (spring)                // 79.5
                    {796,800},//June (early summer)         // 79.8
                    {799,803},//July (summer)               // 80.1
                    {802,806},//August (summer)             // 80.4
                    {798,802},//September (early fall)      // 80.0
                    {794,798},//October (fall)              // 79.6
                    {790,794},//November (fall)             // 79.2
                    {786,790} };//December (early winter)   // 78.8
  ReefAngel.StandardHeater( Port6,heatArray[month()][0],heatArray[month()][1]);
 }//end seasonalTemps
Re: 3 black box (SB Basics) on Dimming Expansion
I'm doing east to west effects today with two lights. Wouldn't be that hard to do with 3 (maybe even easier actually in a for loop). Al you need to do is bump the offset for the third light.
I also have a relay bar (virtual only, no actual bar) with presets for different lighting settings and one of those triggers cloud/lightning mode. I do have issues with the current cloud functionality but I havent had time to debug it yet. But everything you've described is in my code.
DmnYnkee
Post by DmnYnkee »
My lights haven't shipped yet, but my dimming expansion should be here Thursday. I am going to get supplies for hacking the lights for RA dimming tomorrow.
Lee, you had mentioned once before about an upgrade that would allow the lights to dim to 0/off, which would free up 2 ports. Do you have any more info on this?
Chris
Are you on Facebook. I can make the introduction online easier...
DmnYnkee
Post by DmnYnkee »
Ok, Let me break this into pieces.
Can someone help me with code for this part?
Ch0 = Left Blue
Ch1 = Left White
Ch2 = Center Blue
Ch3 = Center White
Ch4 = Right Blue
Ch5 = Right White
Relays
(port3) // (blues) will turn on at sunrise
(port2) // (Whites) will turn on 150 minutes after sunrise
Dimming Expansion
Ch0 to start parabola (5%-40%) at sunrise, and end 1 hour before sunset
Ch2 to start parabola (5%-40%) 30 minutes after sunrise, and end 30 minutes before sunset
Ch4 to start parabola (5%-40%) 1 hour after sunrise, and end at sunset
Ch1 to start parabola (5%-18%) 150 minutes after sunrise, and end 210 minutes before sunset
Ch3 to start parabola (5%-18%) 180 minutes after sunrise, and end 180 minutes before sunset
Ch5 to start parabola (5%-18%) 210 minutes after sunrise, and end 150 minutes before sunset
I can work on the weather portion later, but this will get me started. Thank you very much in advance! :)
Ok, go into the portal and make sure a few things are set in the Internal Memory section.
First go into the first section for Time Schedule and make sure that your Start and End times match the Sunrise/Sunet you are looking for. This should be getting set by the SunLocation if you're using it.
Lastly go to the Dimming Expansion screen and in there you can set the start and end % for each channel that you want. You can adjust this as you see fit without having to reload your code :)
ReefAngel.PWM.Channel0PWMParabola(0,60); // Actinic Left
ReefAngel.PWM.Channel2PWMParabola(30,30); // Actinic Center
ReefAngel.PWM.Channel4PWMParabola(60,0); // Actinic Center
ReefAngel.PWM.Channel1PWMParabola(150,210); // Daylight Left
ReefAngel.PWM.Channel3PWMParabola(180,180); // Daylight Center
ReefAngel.PWM.Channel5PWMParabola(210,150); // Daylight Center
// Turn Actinic outlet on if any % is >= 10
(ReefAngel.PWM.GetChannelValue(0)>=10 || ReefAngel.PWM.GetChannelValue(2)>=10 || ReefAngel.PWM.GetChannelValue(4)>=10) ?  ReefAngel.Relay.On(WhiteLED) :  ReefAngel.Relay.Off(WhiteLED);
// Turn Daylight outlet on if any % is >=10
(ReefAngel.PWM.GetChannelValue(1)>=10 || ReefAngel.PWM.GetChannelValue(3)>=10 || ReefAngel.PWM.GetChannelValue(5)>=10) ?  ReefAngel.Relay.On(BlueLED) : ReefAngel.Relay.Off(BlueLED);
DmnYnkee
Post by DmnYnkee »
Do I leave this portion in my code, or will the new code replace it?
    ReefAngel.DayLights( Port2 );  // (Whites)  On 150 min after sunrise, off 150 min before sunset.
    ReefAngel.ActinicLights( Port3 );  // (Blues) On at sunrise, off at sunset.
    ReefAngel.MoonLights( Port4 );  // Refugium light.  Opposite Whites.
DmnYnkee
Post by DmnYnkee »
I think I answered my own question. Is 10% the lowest the SB Light will actually dim to? I can raise my lights from 3" to 16" above water level. I am planning on initially setting them around 14". What ramping schedule has been working, 5% increase a week until you find the sweet spot?
Here is my code as modified.
#include <Tide.h>
#include <Moon.h>
  SunLocation sl;
  int avgph[10];
    byte avgindex=0;
      byte x;
      byte y = 2;
      char text[7];
      if (HeatOn)
      if (!HeatOn)
      if (LowpH)
      if (HighpH)
      x = 6;
      x = 2;
      x = 2;
      x += 6;
  x += 6;
    ReefAngel.CustomLabels[4]="Alk Dosing";
    SeasonalTemps();
ReefAngel.PWM.Channel4PWMParabola(60,0);     // Actinic Right
ReefAngel.PWM.Channel5PWMParabola(210,150);  // Daylight Right
(ReefAngel.PWM.GetChannelValue(0)>=10 || ReefAngel.PWM.GetChannelValue(2)>=10 || ReefAngel.PWM.GetChannelValue(4)>=10) ?  ReefAngel.Relay.On(Port2) :  ReefAngel.Relay.Off(Port2);
(ReefAngel.PWM.GetChannelValue(1)>=10 || ReefAngel.PWM.GetChannelValue(3)>=10 || ReefAngel.PWM.GetChannelValue(5)>=10) ?  ReefAngel.Relay.On(Port3) : ReefAngel.Relay.Off(Port3);
ReefAngel.DosingPumpRepeat( Port5,0,10,17 );
// Kalk Dosing (2 tsp per gal), Port 5.  Between 9pm & 9am, Every 10 minutes run for 17 seconds.
if (hour()>=9 && hour()<21) ReefAngel.Relay.Off(Port5);
Few % a week is good. There's recommendation in the files section. Set the height for best coverage and then use % to get right levels. YMMV on the dimming but I was able to get measurable par down to 7% on the analog ones and the pwm shut off between 10-15% but I heard thats tuneable..gotta try
And yes you can remove the Daylight Ports. The nice thing with the code I gave to turn the relays on, if you override dimming when lights are out they will come on :)
DmnYnkee
Post by DmnYnkee »
So I finished my wiring, got everything hung, loaded the code, and fired them up. To my delight, they are working, which means I didn't screw anything up, haha. Now, keeping in mind I just got them going about an hour ago, around 5 pm est, I am finding the parabolas are way off from where they should be. Could that be because I need to give it a day to reset overnight and correct itself?
Also, right now, the lefts are higher % than the rights. I know the wiring is correct, so will that correct itself overnight, or is the issue in the code?
Pretty happy so far though! Thank you Lee!!! I set the lights at 12", but I think I may need to lower them 3-4 inches. The tank is euro braced, and I believe I am getting some shadowing around the sides being up that high.
DmnYnkee
Post by DmnYnkee »
Ok, I figured out the issue. Adjust the code you supplied a bit. First, I changed my offsets from 30 minutes down to 15 minutes, so ignore the changes in values in that respect, but, I needed to make some of the values negative.
Here is the modified section.
ReefAngel.PWM.Channel0PWMParabola(0,-30);     // Actinic Left
ReefAngel.PWM.Channel2PWMParabola(15,-15);    // Actinic Center
ReefAngel.PWM.Channel4PWMParabola(30,0);     // Actinic Right
ReefAngel.PWM.Channel1PWMParabola(150,-180);  // Daylight Left
ReefAngel.PWM.Channel3PWMParabola(165,-165);  // Daylight Center
ReefAngel.PWM.Channel5PWMParabola(180,-150);  // Daylight Right
I think this is now working as I intended. The other question that has me baffled is that overnight, the actinics set themselves all to 100%. Is this a function of the moonlights somehow? Where would that value have come from?
Set them to 0 before your logic. Its taking a default somewhere. Sorry about the negatives.
DmnYnkee
Post by DmnYnkee »
Not sure how/where to do this.
No worries on the negatives. I am still far ahead of where I would be without your assistance.
ReefAngel.PWM.SetChannel(0,0);
First arg is channel. Do that for each before the calls to parabola.
Bump, someone else was looking for the same code
DmnYnkee
Post by DmnYnkee »
I am ready to work on my weather modes, but need a lot of help. I am currently using sunrise/sunset, and have not found where clouds and lightning have been incorporated with this, yet.
I also had 1 attempt at using a virtual port to perform a temporary override of the normal light schedule. But it did not work. I have that function commented out in my current code.
Here is my current code:
#include <Tide.h>
#include <Moon.h>
  SunLocation sl;
  int avgph[10];
    byte avgindex=0;
      byte x;
      byte y = 2;
      char text[7];
      if (HeatOn)
      if (!HeatOn)
      if (LowpH)
      if (HighpH)
      x = 6;
      x = 2;
      x = 2;
      x += 6;
  x += 6;
    ReefAngel.WaterChangePorts = Port1Bit | Port6Bit | Port7Bit | Port8Bit;                  // Ports toggled in Water Change Mode
    InternalMemory.OverheatTemp_write( 820 );                                                // Set the Overheat temperature setting
    // Virtual Ports that are always off
    ReefAngel.Relay.Off( Box1_Port1);
    ReefAngel.Relay.Off( Box1_Port2);
    ReefAngel.Relay.Off( Box1_Port3);
    ReefAngel.Relay.Off( Box1_Port4);
    ReefAngel.Relay.Off( Box1_Port5);
    ReefAngel.Relay.Off( Box1_Port6);
    ReefAngel.Relay.Off( Box1_Port7);
    ReefAngel.Relay.Off( Box1_Port8);
    sl.Init(28.5700, -81.6800);    // Lat/long for Clermont, FL
    sl.SetOffset(-2,0,-2,0);       // rise_hour, rise_seconds, set_hour, set_seconds (set 2 hrs later for better viewing time (-4 offset = actual time))
    ReefAngel.CustomLabels[4]="Dosing Pumps";
    // Virtual Ports reserved for custom lighting functions and effects
    ReefAngel.CustomLabels[8]="Lights 60/40";
    ReefAngel.CustomLabels[9]="Not Used";
    ReefAngel.CustomLabels[10]="Not Used";
    ReefAngel.CustomLabels[11]="Not Used";
    ReefAngel.CustomLabels[12]="Weather";
    ReefAngel.CustomLabels[13]="Weather";
    ReefAngel.CustomLabels[14]="Weather";
    ReefAngel.CustomLabels[15]="Weather";
    SeasonalTemps();
// Lights on Dimming Expansion. (Left=East, Right=West)
ReefAngel.PWM.Channel0PWMParabola(0,-30);     // Actinic Left     - Starts at Sunrise, ends 30 minutes before Sunset
ReefAngel.PWM.Channel2PWMParabola(-15,-15);   // Actinic Center   - Starts 15 minute after Sunrise,  ends 15 minutes before Sunset
ReefAngel.PWM.Channel4PWMParabola(-30,0);     // Actinic Right    - Starts 30 minutes after Sunrise, ends at Sunset
ReefAngel.PWM.Channel1PWMParabola(-90,-120);  // Daylight Left   - Starts 90 minutes after Sunrise, ends 120 minutes before Sunset
ReefAngel.PWM.Channel3PWMParabola(-105,-105);  // Daylight Center - Starts 105 minutes after Sunrise, ends 105 minutes before Sunset
ReefAngel.PWM.Channel5PWMParabola(-120,-90);  // Daylight Right  - Starts 120 minutes after Sunrise, ends 90 minutes before Sunset
// Turn Actinic outlet on if any % is >= 2
(ReefAngel.PWM.GetChannelValue(0)>=2 || ReefAngel.PWM.GetChannelValue(2)>=2 || ReefAngel.PWM.GetChannelValue(4)>=2) ?  ReefAngel.Relay.On( Port3 ) :  ReefAngel.Relay.Off( Port3 );
// Turn Daylight outlet on if any % is >=2
(ReefAngel.PWM.GetChannelValue(1)>=2 || ReefAngel.PWM.GetChannelValue(3)>=2 || ReefAngel.PWM.GetChannelValue(5)>=2) ?  ReefAngel.Relay.On( Port2 ) : ReefAngel.Relay.Off( Port2 );
ReefAngel.Relay.Set(Port4, !ReefAngel.Relay.Status(Port2));  // Refugium light.  Opposite Whites.
// Virtual Port Functions
//if (ReefAngel.Relay.Status( Box1_Port1 )); // Set Lights 60/40
//ReefAngel.PWM.SetChannel(0,60);  // Actinic Left
//ReefAngel.PWM.SetChannel(2,60);  // Actinic Center
//ReefAngel.PWM.SetChannel(4,60);  // Actinic Right
//ReefAngel.PWM.SetChannel(1,40);  // Daylight Left
//ReefAngel.PWM.SetChannel(3,40);  // Daylight Center
//ReefAngel.PWM.SetChannel(5,40);  // Daylight Right
 ReefAngel.PWM.SetDaylight( ReefCrestMode(55,15,true) ); // reefcrest at 55% +/- 15% on sync mode       (Day Mode)
 ReefAngel.PWM.SetActinic( ReefCrestMode(55,15,false) ); // reefcrest at 55% +/- 15% on Anti-sync mode  (Day mode)
 ReefAngel.PWM.SetDaylight( ShortPulseMode(1,75,408,true) ); // Short pulse at 75% with 408ms pulse on sync mode (3/4" surface wave)
 ReefAngel.PWM.SetActinic( ShortPulseMode(1,75,408,false) ); // Short pulse at 75% with 408ms pulse on Anti-sync mode (3/4" surface wave)
 ReefAngel.PWM.SetDaylight( LongPulseMode(35,80,2,true) ); // Long Pulse 35% ramping up to 80% for 2 seconds on sync mode (nutrient transport)
 ReefAngel.PWM.SetActinic( LongPulseMode(35,80,2,false) ); // Long Pulse 35% ramping up to 80% for 2 seconds on Anti-sync mode  (nutrient transport)
 ReefAngel.PWM.SetDaylight( ReefCrestMode(50,10,true) ); // reefcrest at 50% +/- 10% on sync mode       (night Mode)
 ReefAngel.PWM.SetActinic( ReefCrestMode(50,10,false) ); // reefcrest at 50% +/- 10% on Anti-sync mode  (night mode)
 ReefAngel.PWM.SetActinic( LongPulseMode(1,40,1,true) );
 ReefAngel.PWM.SetDaylight( LongPulseMode(1,40,1,true) );
  static int heatArray[][2] = { {786,790},                  // default in case of error in month=0 (June)
                    {774,778},//January (winter)            // 77.6
                    {776,780},//February (winter)           // 77.8
                    {778,782},//March (early spring)        // 78.0
                    {780,784},//April (spring)              // 78.2
                    {782,786},//May (spring)                // 78.4
                    {786,790},//June (early summer)         // 78.8
                    {790,794},//July (summer)               // 79.2
                    {794,798},//August (summer)             // 79.6
                    {790,794},//September (early fall)      // 79.2
                    {786,790},//October (fall)              // 78.8
                    {782,786},//November (fall)             // 78.4
                    {778,782} };//December (early winter)   // 78.0
DmnYnkee
Post by DmnYnkee »
Lee, and Colin, or anyone else that may want to chime in.
I have this breathing now, and have it close to where I want it.
I no longer have my lights working with sunset/sunrise, but would like to incorporate this back in at some point. I also no longer can adjust light percentages through the portal, and I really liked having that ability.
Issues that I would like to fix at this point are:
1.) I want to raise my actinics up about 20% as a cloud starts dimming the whites. (I think Lee did some work on this)
2.) I need the whites to go no lower than 2% for the duration of the cloud and/or lightning. I have tried several different ways to accomplish this, and none of them have worked, as they still went to 0.
3.) I would like the clouds to dim from left to right (maybe a 10-20 second delay to each channel), and right now, all 3 dim at the same time.
4.) Break the 3 channels out during "Mega", similar to how I have "Slow" set up now. (borrowed this from Lee to get to this point)
5.) I would like to add a basic "storm mode" for my wave makers. Just a higher than normal % short pulse mode that reverts back at end of cloud. These are on my standard actinic/daylight dimming channels.
Here is where my code is now:
#include <Tide.h>
#include <Moon.h>
  SunLocation sl;
  int avgph[10];
    byte avgindex=0;
      byte x;
      byte y = 2;
      char text[7];
      if (HeatOn)
      if (!HeatOn)
      if (LowpH)
      if (HighpH)
      x = 6;
      x = 2;
      x = 2;
      x += 6;
  x += 6;
int DaylightPWMValue1=0;        // For cloud code, channel 1
int DaylightPWMValue3=0;        // For cloud code, chennel 3
int DaylightPWMValue5=0;        // For cloud code, chennel 5
    ReefAngel.CustomLabels[8]="Lights:  B60/W40";
    ReefAngel.CustomLabels[9]="Lighta: Whites 40";
    ReefAngel.CustomLabels[10]="Lights: Blues 60";
    ReefAngel.CustomLabels[12]="Storm";
    SeasonalTemps();
// Lights on Dimming Expansion. (Left=East, Center=Center, Right=West)
// Default lighting program
ReefAngel.PWM.SetChannelRaw( 0, PWMSlopeHighRes(9,30,21,30,1,65,120,0) );  // Schedule for blues
ReefAngel.PWM.SetChannelRaw( 2, PWMSlopeHighRes(9,45,21,45,1,65,120,0) );
ReefAngel.PWM.SetChannelRaw( 4, PWMSlopeHighRes(10,00,22,0,1,65,120,0) );
DaylightPWMValue1=PWMSlopeHighRes(10,30,20,30,1,25,90,0);    //  Default for whites
DaylightPWMValue3=PWMSlopeHighRes(10,45,20,45,1,25,90,0);
DaylightPWMValue5=PWMSlopeHighRes(11,00,21,0,1,25,90,0);
CheckCloud();    //  Check for cloud and slow lightning.
ReefAngel.PWM.SetChannelRaw(1,DaylightPWMValue1);  //  Write values for either default or cloud/slow
ReefAngel.PWM.SetChannelRaw(3,DaylightPWMValue3);  //  lightning if it's time.
ReefAngel.PWM.SetChannelRaw(5,DaylightPWMValue5);  //  lightning if it's time.
 byte random_speed=60;
 if (now()%5==1) random_speed=random(58,78);
 ReefAngel.PWM.SetDaylight( ShortPulseMode(1,random_speed,408,true) ); // Short pulse at 58%-78% with 408ms pulse on sync mode (surface wave)
 ReefAngel.PWM.SetActinic( ShortPulseMode(1,random_speed,408,false) ); // Short pulse at 58%-78%% with 408ms pulse on Anti-sync mode (surface wave)
 byte random_speed=65;
 if (now()%5==1) random_speed=random(65,80);
 byte random_duration=2;
 if (now()%5==1) random_duration=random(2,5);
 ReefAngel.PWM.SetDaylight( LongPulseMode(35,random_speed,random_duration,true) ); // Long Pulse 35% ramping up to 65%-80% for 2-5 seconds on sync mode (nutrient transport)
 ReefAngel.PWM.SetActinic( LongPulseMode(35,random_speed,random_duration,false) ); // Long Pulse 35% ramping up to 65%-80% for 2-5 seconds on Anti-sync mode  (nutrient transport)
 ReefAngel.PWM.SetActinic(1);
 ReefAngel.PWM.SetDaylight(1);
// enter feeding mode at 5:30pm
if ( (hour()==17 && minute()==30 && second()==0))
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static byte lightningMode=0;
void CheckCloud()
#define Clouds_Every_X_Days 1
  // Minimum number of minutes for cloud duration.  Don't use min duration of less than 6
#define Min_Cloud_Duration 6
#define Max_Cloud_Duration 12
#define Min_Clouds_per_Day 1
#define Max_Clouds_per_Day 4
  // In this example, start cloud after noon
#define Start_Cloud_After NumMins(12,00)
#define End_Cloud_Before NumMins(21,00)
  // Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes
  // of effects or unforseen result could happen.
  // In our example, we have 510 minutes between Start_Cloud_After and End_Cloud_Before, so double the
  // 250 minutes (or 500 minutes) can fit in that 510 minutes window.
  // Add Random Lightning modes
#define Calm 0    // No lightning
#define Slow 1    // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
#define Fast 2    // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
#define Mega 3    // Lightning throughout the cloud, higher chance as it gets darker
#define Mega2 4   // Like Mega, but with more lightning
  // Example:  { Calm, Fast, Mega, Mega2 } to randomize all four modes.
  // { Mega2 } for just Mega2.  { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
  byte LightningModes[] = { Calm, Slow, Mega, Mega };
  static time_t DelayCounter=millis();    // Variable for lightning timing.
  static int DelayTime=random(1000);      // Variable for lightning timimg.
#ifdef forcecloudcalculation
  if (cloudchance==255)
#else
#endif
      randomSeed(millis());    // Seed the random number generator
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  if (cloudchance)
    if (ReefAngel.Relay.isMaskOn(Box1_Port5))      // Change this to whatever port you want to use as a trigger.
      cloudstart = NumMins(hour(), minute());
      ReefAngel.Relay.Auto(Box1_Port5);    // Here, too.
    //is it time for cloud yet?
      // Increase Blue channel first for better effect and to compensate for drop in Whites
      //ActinicPWMValue1=ReversePWMSlopeHighRes(cloudstart,cloudstart+cloudduration,ActinicPWMValue1,ActinicPWMValue1+DaylightPWMValue0,180);
      //ActinicPWMValue3=ReversePWMSlopeHighRes(cloudstart,cloudstart+cloudduration,ActinicPWMValue3,ActinicPWMValue3+DaylightPWMValue2,180);
      //ActinicPWMValue3=ReversePWMSlopeHighRes(cloudstart,cloudstart+cloudduration,ActinicPWMValue3,ActinicPWMValue3+DaylightPWMValue4,180);
      DaylightPWMValue1=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue1,2,150);
      DaylightPWMValue3=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue3,2,150);
      DaylightPWMValue5=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue5,2,150);
      if (chooseLightning)
        chooseLightning=false;
      switch (lightningMode)
      case Calm:
        break;
      case Mega:
        // Lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
        if (lightningchance && random(ReversePWMSlope(cloudstart,cloudstart+cloudduration,100,2,150))<1 && (millis()-DelayCounter)>DelayTime)
          // Send the trigger
          Strike();
          DelayCounter=millis();    // If we just had a round of flashes, then lets put in a longer delay
          DelayTime=random(1000);   // of up to a second for dramatic effect before we do another round.
        break;
      case Mega2:
        // Higher lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
        if (lightningchance && random(ReversePWMSlope(cloudstart,cloudstart+cloudduration,100,2,150))<2)
          Strike();
        break;
      case Fast:
          Strike();
        break;
      case Slow:
        // Slow lightning for 5 seconds in the middle of the cloud.  Suitable for slower ELN style drivers
        if (lightningchance && (NumMins(hour(),minute())>=(cloudstart+(cloudduration/3))) && second()<10)
          SlowStrike();
        break;
      default:
        break;
      cloudindex++;
      if (cloudindex < numclouds)
  // Cloud ON option - Clouds every minute
  if (ReefAngel.Relay.isMaskOff(Box1_Port5) && now()%60<10)
    SlowStrike();
void SlowStrike()
    int r = random(80);
    if (r<20) lightningstatus=1;
    else lightningstatus=0;
    if (lightningstatus)
      // Let's separate left, center, right, or All.
      if (r<10  ) {               // All 3
        DaylightPWMValue1=4095;
        DaylightPWMValue3=4095;
        DaylightPWMValue5=4095;
      } else if (r<12) {          // Left only
        DaylightPWMValue3=100;
        DaylightPWMValue5=100;
      } else if (r<14) {          // Center only
        DaylightPWMValue1=100;
      } else if (r<16) {          // Right only
      } else if (r<18) {          // Left & Center only
      } else {                    // Center & Right only
    delay(1);
void DrawClouds(int x, int y)
    ReefAngel.LCD.DrawText(0,255,x,y,"C"); x+=6;
    ReefAngel.LCD.DrawText(0,255,x,y,"00:00"); x+=34;
    ReefAngel.LCD.DrawText(0,255,x,y,"L"); x+=6;
    ReefAngel.LCD.DrawText(0,255,x,y,"00:00"); x=5;
      int x=0;
      else x=17;
      ReefAngel.LCD.DrawText(0,255,x,y,(cloudstart/60));
      //ReefAngel.CustomVar[3]=cloudstart/60; // Write the hour of the next cloud to custom variable for Portal reporting
      else x=35;
      ReefAngel.LCD.DrawText(0,255,x,y,(cloudstart%60));
      //ReefAngel.CustomVar[4]=cloudstart%60; // Write the minute of the next cloud to custom variable for Portal reporting
    ReefAngel.LCD.DrawText(0,255,x+85,y,cloudduration);
    //ReefAngel.CustomVar[7]=(cloudduration);    // Put the duration of the next cloud in a custom var for the portal
    if (lightningchance)
      int x=0;
      if (((cloudstart+(cloudduration/3))/60)>=10) x=51;
      else x=57;
      ReefAngel.LCD.DrawText(0,255,x,y,((cloudstart+(cloudduration/3))/60));
      //ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60;    // Write the hour of the next lightning to a custom variable for the Portal
      if (((cloudstart+(cloudduration/3))%60)>=10) x=69;
      else x=75;
        ReefAngel.LCD.DrawText(0,255,x,y,((cloudstart+(cloudduration/3))%60)); // Write the minute of the next lightning to a custom variable for the Portal
        //ReefAngel.CustomVar[6]=(cloudstart+(cloudduration/2))%60;
void Strike()
  int a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
  for (int i=0; i<a; i++)
    // Flash on
    int newdata=4095;
    Wire.beginTransmission(0x40);      // Address of the dimming expansion module
    Wire.write(0x8+(4*1));             // 0x8 is channel 0, 0x12 is channel 1, etc.  This is channel 1.
    Wire.write(newdata&0xff);          // Send the data 8 bits at a time.  This sends the LSB
    Wire.write(newdata>>8);            // This sends the MSB
    Wire.endTransmission();
    Wire.write(0x8+(4*3));             // 0x8 is channel 0, 0x12 is channel 1, etc.  This is channel 3.
    Wire.write(0x8+(4*5));             // 0x8 is channel 0, 0x12 is channel 1, etc.  This is channel 5.
    int randy=random(20,80);    // Random number for a delay
    if (randy>71) randy=((randy-70)/2)*100;    // Small chance of a longer delay
    delay(randy);                // Wait from 20 to 69 ms, or 100-400 ms
    // Flash off.  Return to baseline.
    newdata=ReefAngel.PWM.GetChannelValueRaw(1);   // Use the channel number you're flashing here
    Wire.beginTransmission(0x40);    // Same as above
    newdata=ReefAngel.PWM.GetChannelValueRaw(3);   // Use the channel number you're flashing here
    newdata=ReefAngel.PWM.GetChannelValueRaw(5);   // Use the channel number you're flashing here
    delay(random(30,50));                // Wait from 30 to 49 ms
    wdt_reset();    // Reset watchdog timer to avoid re-boots
  cstart*=60;
  cend*=60;
  if (n>cend) return (int) PWMStart;
int ReversePWMSlope(long cstart,long cend,int PWMStart,int PWMEnd, byte clength)
  cstart*=60;
  cend*=60;
