Day night mode for wave maker
Ferdi
Post by Ferdi »
Hi there,
I want to let my wave maker go slower at night.
Is there any coding that can let it flow normaly during the day and slower at night?
Thank you in advance.
Re: Day night mode for wave maker
I'm assuming you are talking about Jebao, right?
Can you post your code?
Ferdi
Post by Ferdi »
Hi Roberto,
Yes i am.
I'm looking for the code. Hehe 8-)
Ferdi
Post by Ferdi »
rimai wrote:I'm assuming you are talking about Jebao, right?
ReefAngel.FeedingModePorts = Port2Bit | Port3Bit | Port5Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit | Port6Bit;
InternalMemory.OverheatTemp_write( 290 );
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port4 );
ReefAngel.CustomLabels[0]="Heater";
ReefAngel.CustomLabels[1]="Wave Maker";
ReefAngel.CustomLabels[2]="Skimmer";
ReefAngel.CustomLabels[3]="Reactor";
ReefAngel.CustomLabels[4]="ATO";
ReefAngel.CustomLabels[5]="Lights";
ReefAngel.CustomLabels[6]="Chiller";
ReefAngel.CustomLabels[7]="ReturnPump";
ReefAngel.StandardHeater( Port1,265,270 );
ReefAngel.Relay.DelayedOn( Port3,4 );
ReefAngel.SingleATO( true,Port5,60,0 );
ReefAngel.StandardFan( Port7,270,275 );
ReefAngel.DCPump.SetMode( ShortPulse,40,40 );
ReefAngel.Portal( "Ferdi" );
Try this:
  if (hour()>=8 && hour()<18) // Day mode between 8am and 6pm
    ReefAngel.DCPump.SetMode( Constant,30,0 );
Ferdi
Post by Ferdi »
Thank you Roberto. Works perfectly
GreenVF
Post by GreenVF »
With this code can you adjust the wave makers from the portal or is it just hard coded?
I would like to have night mode and day mode with Jeboa wave makers.
Is someone able to post code on how this is done. Thanks
This is hard coded. The best way to do this is to wrape the whole section that is setting the different modes with an if that checks the mode setting in memory and only runs the schedule if the mode is Custom. If not it will use settings in memory.
