Gentlemen,
Has anyone run a WP40 (sync) on a dimming channel on the relay box and another as anti-sync on an ATO port?
I did try searching the forum but didn't find anything definitive. Sounds like people are using ATO ports, but not sure if you can blend them with the relay.
I want to continue to use the internal memory instead of code so I can change things on the fly with my phone, laptop, or portal instead of reloading code all the time.
And, can I use either ATO port for the WP40 control? I'm already using ATOLow for my dimmable moonlight.
My current config is:
Relay Daylight Channel = Dimmer for Apollo LEDs, both (Daylight and Actinic) LED channels on one.
Relay Actinic Channel = WP40 DCPump control
ATOLow = Dimmable Moonlight
ATOHigh = open
Maybe there's a better way of arranging things for a second DCPump control that I haven't thought of?
Just wanted to ask the group to make sure I'm on the right path before I ordered the special ATO version Jebao cord.
Thanks in advance!
WP40 ATO Control
- cosmith71
Re: WP40 ATO Control
If you use the ATO port make sure you modify the cable.
- hous0067
Thanks guys!
I think Roberto fixed the cable for me...how do I code it?
//WP40 Moonlight Output
pinMode(highATOPin,OUTPUT)
analogWrite(highATOPin, ????)
-Ken
Just need to set the channel with
ReefAngel.DCPump.LowATOChannel = AntiSync;
- hous0067
lol, well, that's simple.
Things just get easier and easier with the new libraries. I like it.
-Ken
