I finally got my wifi attachment working but really liked the graph and relay status in the RA client. Can the RA client v3.0 still be used while running the wifi attachment?
I played with the RA client wifi listener settings but was unable to connect to the portal and I know my portal ID and portal key are correct. I get an error message of:
- unable to retrieve wifi url and port from portal. Make sure the forum ID and password provided are correct and that you have a url and port set on the portal.
The web chart on the portal shows nothing and the relay activity says no data. Also my dashboard main relay box is not synced with what is actually on/off at the time.
RA client with wifi?
Re: RA client with wifi?
Anyone? Bueller?
I think that you're wifi is not working then. Did you update your code to support the wifi yet? There's a line that's needed which sends the data to the portal. If that's not there then the portal doesn't yet know about your RA.
I can see data on the portal, just seems to be missing some. I can see my temps and PH and that is about it. My relay buttons work to pumps on/off, but show all off when I look at the portal. Also my banner is blank.
ReefAngel.AddWifi();
ReefAngel.WaterChangePorts = Port2Bit | Port3Bit | Port4Bit;
ReefAngel.LightsOnPorts = Port7Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port8Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardHeater( Port1,775,780 );
ReefAngel.StandardLights( Port5,11,0,21,0 );
ReefAngel.StandardLights( Port7,21,0,9,0 );
ReefAngel.Relay.Set(Port3, ReefAngel.LowATO.IsActive() && ReefAngel.HighATO.IsActive());
ReefAngel.Portal("UID","PWD");
Inevo, can you check out my code for issues?
Assuming UID and PWD are your actual numbers then there's no issue in the code. Is the PWD set in Portal Settings?
yes the UID and the PWD are setup. I used UID/PWD to cover the real ID and Password. Yes the password is set in portal settings.
So how is the username and key supposed to be entered? With the parentheses or commas?
reefangel.portal("djbm3:sharkbait");
or
reefangel.portal("djbm3":"sharkbait");
or
reefangel.portal("djbm3","sharkbait");
or
or
thank you!!
