RA all setup, working great. Wifi set up, working sometime. Goes back and forth between green flashing slowly meaning ip address ok, but not solid green meaning connected.
And sometimes it goes back and forth between flashing green and slow flashing blue.
What can I do to improve performance.
question about wifi behavior
rossbryant1956
Re: question about wifi behavior
Try relocating the router or the wifi attachment to a better position.
You also may mod the attachment with an external antenna.
Some users have done it with success.
There is no solid green. It should be always blinking green.
The blinking blue means it got disconnected.
