#include <RA_TS.h>
#include <RA_TouchLCD.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <RA_Wiznet5100.h>
#include <SD.h>
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetDHCP.h>
#include <PubSubClient.h>
#include <RA_CustomLabels.h>
#include <SoftwareSerial.h>
int DaylightPWMValue=0; // For cloud code
ReefAngel.Star();
//ReefAngel.AddStandardMenu();
//ReefAngel.Use2014Screen(); // Let's use 2014 Screen
//ReefAngel.AddRANet(); // RANet Add-On Module
// Ports turned off when Leak is detected
ReefAngel.LeakShutoffPorts = 0;
InternalMemory.OverheatTemp_write( 300 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port7 );
ReefAngel.Portal("Xender","$$$$$");
//ReefAngel.Network.WifiAuthentication("Xender:$$$$$$");
//ReefAngel.LeakShutoffPorts = Box1_Port3;
ReefAngel.StandardLights( Port1,8,0,23,0 );
ReefAngel.StandardLights( Port2,8,0,23,0 );
ReefAngel.PWM.SetDaylight( PWMSlope( 9,0,23,0,15,70,60,0 ) );
ReefAngel.PWM.SetActinic( PWMSlope( 9,0,23,0,15,70,60,0 ) );
ReefAngel.PWM.SetDaylight2( PWMSlope( 9,0,23,0,15,70,60,0 ) );
ReefAngel.PWM.SetActinic2( PWMSlope( 9,0,23,0,15,70,60,0 ) );
ReefAngel.PWM.SetChannel( 0,PWMSlope( 9,0,23,0,15,70,60,0 ) );
ReefAngel.PWM.SetChannel( 1,PWMSlope( 9,0,23,0,15,70,60,0 ) );
ReefAngel.PWM.SetChannel( 2,PWMSlope( 9,0,23,0,15,70,60,0 ) );
ReefAngel.PWM.SetChannel( 3,PWMSlope( 9,0,23,0,15,70,60,0 ) );
ReefAngel.PWM.SetChannel( 4,PWMSlope( 9,0,23,0,15,70,60,0 ) );
//Cloud
DaylightPWMValue=PWMSlopeHighRes(10,30,22,0,0,85,60,0);
CheckCloud();
ReefAngel.PWM.SetChannelRaw(1,DaylightPWMValue);
boolean buzzer=false;
if ( ReefAngel.isOverheat() ) buzzer=true;
//CO2
// if ( ReefAngel.Params.PH <= 600 )
//ReefAngel.Relay.Off(Box1_Port5);
//if ( ReefAngel.Params.PH >= 700 )
//ReefAngel.Relay.On(Box1_Port5);
//Week days light ON/OFF
InternalMemory.write(0, 17);
InternalMemory.write(1, 00);
InternalMemory.write(2, 00);
InternalMemory.write(3, 00);
InternalMemory.write(4, 17);
InternalMemory.write(5, 00);
InternalMemory.write(6, 00);
InternalMemory.write(7, 00);
// if ( (weekday() == 1) || (weekday() == 7) ) // Sunday or Saturday
// // 0 - on hour, 1 - on minute, 2 - off hour, 3 - off minute
// // 4 - on hour, 5 - on minute, 6 - off hour, 7 - off minute
// ReefAngel.StandardLights(Box1_Port1, InternalMemory.read(0), InternalMemory.read(1), InternalMemory.read(2), InternalMemory.read(3)); // Weekend schedule
// ReefAngel.StandardLights(Box1_Port2, InternalMemory.read(4), InternalMemory.read(5), InternalMemory.read(6), InternalMemory.read(7)); // Weekend schedule
// } else
// ReefAngel.StandardLights(Box1_Port1,17,0,23,0 ); // Weekday schedule (use standard internal memory values)
// ReefAngel.StandardLights(Box1_Port2,17,0,23,0 ); // Weekday schedule (use standard internal memory values)
ReefAngel.Network.Cloud();
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 7
#define Min_Clouds_per_Day 1
#define Max_Clouds_per_Day 2
// In this example, start cloud after noon
#define Start_Cloud_After NumMins(12,00)
#define End_Cloud_Before NumMins(21,00)
// Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes
// of effects or unforseen result could happen.
// In our example, we have 510 minutes between Start_Cloud_After and End_Cloud_Before, so double the
// 250 minutes (or 500 minutes) can fit in that 510 minutes window.
// Add Random Lightning modes
#define Calm 0 // No lightning
#define Slow 1 // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
#define Fast 2 // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
#define Mega 3 // Lightning throughout the cloud, higher chance as it gets darker
#define Mega2 4 // Like Mega, but with more lightning
// Example: { Calm, Fast, Mega, Mega2 } to randomize all four modes.
// { Mega2 } for just Mega2. { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
byte LightningModes[] = {Mega2,Mega,Mega};
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
static byte lightningMode=0;
static time_t DelayCounter=millis(); // Variable for lightning timing.
static int DelayTime=random(1000); // Variable for lightning timimg.
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
randomSeed(millis()); // Seed the random number generator
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue/40.95,0,180)*40.95;
if (chooseLightning)
chooseLightning=false;
switch (lightningMode)
case Calm:
break;
case Mega:
// Lightning chance from beginning of cloud through the end. Chance increases with darkness of cloud.
// Send the trigger
Strike();
DelayCounter=millis(); // If we just had a round of flashes, then lets put in a longer delay
DelayTime=random(1000); // of up to a second for dramatic effect before we do another round.
break;
case Mega2:
// Higher lightning chance from beginning of cloud through the end. Chance increases with darkness of cloud.
Strike();
break;
case Fast:
Strike();
break;
case Slow:
// Slow lightning for 5 seconds in the middle of the cloud. Suitable for slower ELN style drivers
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=4095;
DaylightPWMValue=0;
delay(1);
break;
default:
break;
cloudindex++;
if (cloudindex < numclouds)
/*ReefAngel.LCD.Clear(255,0,120,132,132);
ReefAngel.LCD.DrawText(0,255,51,120,"00:00"); */
int x=0;
else x=17;
//ReefAngel.LCD.DrawText(0,255,x,120,(cloudstart/60));
ReefAngel.CustomVar[3]=cloudstart/60; // Write the hour of the next cloud to custom variable for Portal reporting
else x=35;
//ReefAngel.LCD.DrawText(0,255,x,120,(cloudstart%60));
ReefAngel.CustomVar[4]=cloudstart%60; // Write the minute of the next cloud to custom variable for Portal reporting
//ReefAngel.LCD.DrawText(0,255,90,120,cloudduration);
ReefAngel.CustomVar[7]=(cloudduration); // Put the duration of the next cloud in a custom var for the portal
if (lightningchance)
int x=0;
if (((cloudstart+(cloudduration/2))/60)>=10) x=51;
else x=57;
//ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))/60));
ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60; // Write the hour of the next lightning to a custom variable for the Portal
if (((cloudstart+(cloudduration/2))%60)>=10) x=69;
else x=75;
//ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60)); // Write the minute of the next lightning to a custom variable for the Portal
ReefAngel.CustomVar[6]=(cloudstart+(cloudduration/2))%60;
void Strike()
int a=random(1,5); // Pick a number of consecutive flashes from 1 to 4.
for (int i=0; i<a; i++)
// Flash on
int newdata=4095;
Wire.beginTransmission(0x40); // Address of the dimming expansion module
Wire.write(0x8+(4*1)); // 0x8 is channel 0, 0x12 is channel 1, etc. I'm using channel 1.
Wire.write(newdata&0xff); // Send the data 8 bits at a time. This sends the LSB
Wire.write(newdata>>8); // This sends the MSB
Wire.endTransmission();
int randy=random(20,80); // Random number for a delay
if (randy>71) randy=((randy-70)/2)*100; // Small chance of a longer delay
delay(randy); // Wait from 20 to 69 ms, or 100-400 ms
// Flash off. Return to baseline.
newdata=ReefAngel.PWM.GetChannelValueRaw(1); // Use the channel number you're flashing here
Wire.beginTransmission(0x40); // Same as above
delay(random(30,50)); // Wait from 30 to 49 ms
wdt_reset(); // Reset watchdog timer to avoid re-boots
cstart*=60;
cend*=60;
if (n>cend) return (int) PWMStart;
// RA_STRING1=$$$$
// RA_STRING2=null
// RA_STRING3=null
