Here is my code:
//#include <Salinity.h>
//#include <RF.h>
//#include <ORP.h>
//#include <WaterLevel.h>
//#include <Humidity.h>
//#include <PAR.h>
#define Mem_B_MoonOffset 100
#define Mem_B_Vacation 101
#define Mem_B_AutoFeed 102
#define Mem_B_AutoFeedPress 103
#define Mem_B_AutoFeedRepeat 104
#define Mem_B_AutoFeedOffset 105
#define Mem_I_WCFillTime 106
byte wc_status = 0;
time_t ato_endfill;
byte ato_topping = 0;
void init_memory() {
InternalMemory.write(Mem_B_Vacation,false);
InternalMemory.write(Mem_B_AutoFeed,true);
InternalMemory.write(Mem_B_AutoFeedPress,2);
InternalMemory.write(Mem_B_AutoFeedRepeat,4);
InternalMemory.write(Mem_B_AutoFeedOffset,3);
InternalMemory.write_int(Mem_I_WCFillTime,1200 ); //How long topoff is allowed to run
// Define Relay Ports by Name
#define Daylight 1
#define LEDLights 2
#define ATODrain 3
#define Feeder 4
#define Mixer 5
#define Topoff 6
#define Ferts 7
#define Filter 8
ReefAngel.Relay.Auto(Filter);
ato_endfill = now()+15; //add delay to ato startup
// Ports that default off
ReefAngel.Relay.Off(Topoff);
ReefAngel.Relay.Off(ATODrain);
ReefAngel.Relay.Off(Feeder);
ReefAngel.Relay.Off(Mixer);
ReefAngel.CustomLabels[0]="Daylight";
ReefAngel.CustomLabels[1]="LED";
ReefAngel.CustomLabels[2]="Drain";
ReefAngel.CustomLabels[3]="Feeder";
ReefAngel.CustomLabels[4]="Mixer";
ReefAngel.CustomLabels[5]="Topoff";
ReefAngel.CustomLabels[6]="Ferts";
ReefAngel.CustomLabels[7]="Filter";
ReefAngel.Relay.On(Filter);
ReefAngel.StandardLights( LEDLights,9,0,21,0 );
ReefAngel.StandardLights( Daylight,10,30,20,30 );
ReefAngel.PWM.SetActinic( PWMSlope(9,0,20,0,15,100,60,15) );
//Automation
//RunFeeder();
//RUN ONCE A DAY AT 7 AM FOR 40 MIN
ReefAngel.DosingPumpRepeat(ATODrain,660,1440,2400 );
//Water Change
if (ReefAngel.Relay.Status(ATODrain) ){
wc_status = 1;
if (wc_status > 0 ){
AutoWaterChange();
//Keep Water topped off
AutoTopOff();
ReefAngel.Portal( "diverjoe" );
ReefAngel.DDNS("75");
void AutoTopOff(){
//run for 15 sec any time float valve is turned on and WC drain is not active
if (ato_endfill < now() && wc_status != 1 && ato_topping){
ReefAngel.Relay.On(Topoff);
else{
ato_topping = 0;
if ( ReefAngel.HighATO.IsActive() && !ato_topping){
ato_endfill = now() + 15;
ato_topping = 1;
void RunFeeder() {
boolean autoFeed;
static time_t t;
int press, repeat, offset;
autoFeed=InternalMemory.read(Mem_B_AutoFeed);
press=InternalMemory.read(Mem_B_AutoFeedPress);
repeat=InternalMemory.read(Mem_B_AutoFeedRepeat)*SECS_PER_HOUR;
offset=InternalMemory.read(Mem_B_AutoFeedOffset)*SECS_PER_HOUR;
ReefAngel.Relay.Set(Feeder, autoFeed);
if (ReefAngel.Relay.Status(Feeder)!=autoFeed) {
autoFeed=ReefAngel.Relay.Status(Feeder);
InternalMemory.write(Mem_B_AutoFeed, autoFeed);
ReefAngel.Relay.Auto(Feeder);
if (autoFeed) {
if (((hour() > 9 && hour() < 20)) && (now()+offset)%repeat==0) {
t=now();
if (ReefAngel.Relay.isMaskOn(Feeder)) {
t=now()-now()%20; // One feeding has already happened.
// Press the button once every 20 seconds
if (now()-t < press*20) {
ReefAngel.Relay.Set(Feeder,now()%20==0);
} else {
void AutoWaterChange() {
int NowMins;
static time_t t;
if (wc_status == 1) {
ReefAngel.Relay.Override(Topoff,0);
//ReefAngel.Relay.Override(Filter,0);
ReefAngel.Relay.Off(Filter);
t = now();
if(ReefAngel.LowATO.IsActive() && wc_status == 1)
wc_status = 2; //Enter Mix mode
ReefAngel.Relay.Auto(ATODrain);
ReefAngel.Relay.On(Mixer);
ReefAngel.Relay.Auto(Topoff);
//ReefAngel.Relay.On(Topoff);
t = now();
//Ferts Mode
if ( wc_status == 2){
if (now() - t > SECS_PER_MIN * 6){
wc_status = 3; //enter Ferts mode
ReefAngel.Relay.On(Ferts);
t = now();
//ferts Mode
if ( wc_status == 3){
if (now() - t > 15){
ReefAngel.Relay.Off(Ferts);
wc_status = 0;
// Disable masks for things that should not be turned on by mistake
void LockPorts() {
ReefAngel.AddPortOverrides();
