RA portal charts does not have new data
Re: RA portal charts does not have new data
Click Options
Choose the serial port connected to your wifi attachment
Choose 57600 baud rate
Click Ok
Click Connect
Type $$$
Click Ok
Click Connect
Type $$$
Reefology
this is what I got after following your steps
<4.41>
not sure how to upload screenshots or pics, I'm a computer knob
<4.41>
There you go. you are in command mode.
Now type the other commands
Reefology
the following is what I got. now what?
Disconn from Joshua2001,LOST-AP
Auto-Assoc Joshua2001 chan=6 mode=MIXED SCAN OK
Joining Joshua2001 now..
Associated!
DHCP: Start
DHCP in 1798ms, lease=604800s
IF=UP
DHCP=ON
IP=192.168.0.34:2000
NM=255.255.255.0
GW=192.168.0.1
Associated!
DHCP: Start
IF=UP
DHCP=ON
NM=255.255.255.0
GW=192.168.0.1
Reefology
thanks Roberto but the portal still has dec 23rd as the last data for relays and web charts?
Then something went wrong.
Connect to the module again and send "get e" command.
Paste the response
Paste the response
Reefology
I typed "get e" and this was the response
<h1>Bad Request</h1><h1>Bad Request (Invalid URL)</h1>
You didn't enter cmd mode.
You need to type $$$ to enter command mode or no command will be accepted
Reefology
heres what I got
CMD
get e
wifly-GSX Ver: 4.41 Build: r1057, Jan 17 2014 10:26:29 on RN-131
SSID=WiFly-GSX-db
Pass=
Linkmon=3600
Beacon=102
Reboot=0
IF=UP
DHCP=ON
NM=255.255.255.0
GW=192.168.0.1
HOST=198.171.134.6:80
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1420
MatchChar=0
FlushTimer=5
IdleTimer=3
CmdChar=$
DNS=192.168.0.1
Name=www.reefangel.com
Backup=rn.microchip.com
Lease=86400
FTP=198.175.253.161:21
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=Joshua2001
Chan=0
ExtAnt=0
Join=1
Auth=OPEN
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=5
Passphrase=Tes
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x10
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
TIMEADR=64.90.182.55:123
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x2
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
DeviceId=ReefAngelWifi
Password=
Format=0x0
Signal=0
Average=5
BCAST=255.255.255.255:55555
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
<4.41>
CMD
get e
SSID=WiFly-GSX-db
Pass=
Linkmon=3600
Beacon=102
Reboot=0
IF=UP
DHCP=ON
NM=255.255.255.0
GW=192.168.0.1
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1420
MatchChar=0
FlushTimer=5
IdleTimer=3
CmdChar=$
DNS=192.168.0.1
Lease=86400
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=Joshua2001
Chan=0
ExtAnt=0
Join=1
Auth=OPEN
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=5
Passphrase=Tes
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x10
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x2
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
Password=
Format=0x0
Signal=0
Average=5
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
<4.41>
You didn't do it correctly.
The host is still the old one:
After entering command mode you need to enter these three commands:
Copy and paste the whole log when you do it just so we can see what went wrong.
set i h 104.36.18.155
save
reboot
Reefology
sure I did something wrong but heres what I got.
‰ñúã6‘;öÇfiûÊÊ9ßã˝ª+
î˝¥lú>i.‘fi.¥—∆ãn˝ÏˆúãN‘;9&)Ê.»˝ßɲ{+.¨ˇ.|ú$$$
ERR: ?-Cmd
<4.41>
AOK
<4.41>
save
Storing in config
<4.41>
reboot
*Reboot*.HTTP/1.1 400 Bad Request
Content-Type: text/html; charset=us-ascii
Server: Microsoft-HTTPAPI/2.0
Date: Fri, 30 Dec 2016 03:06:32 GMT
Connection: close
Content-Length: 311
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN""http://www.w3.org/TR/html4/strict.dtd">
<HTML><HEAD><TITLE>Bad Request</TITLE>
<META HTTP-EQUIV="Content-Type" Content="text/html; charset=us-ascii"></HEAD>
<BODY><h2>Bad Request</h2>
<hr><p>HTTP Error 400. The request is badly formed.</p>
</BODY></HTML>
ERR: ?-Cmd
<4.41>
AOK
<4.41>
save
Storing in config
<4.41>
reboot
Connection: close
Content-Length: 311
</BODY></HTML>
Reefology
CMD
AOK
<4.41>
save
Storing in config
<4.41>
reboot
*Reboot*.
I tried it again and now got this which looks right to me...which means absolutely nothing
AOK
<4.41>
save
Storing in config
<4.41>
reboot
*Reboot*.
Reefology
ok, got the new host
ERR: ?-Cmd
<4.41>
get e
SSID=WiFly-GSX-db
Pass=
Linkmon=3600
Beacon=102
Reboot=0
IF=UP
DHCP=ON
NM=255.255.255.0
GW=192.168.0.1
HOST=104.36.18.155:80
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1420
MatchChar=0
FlushTimer=5
IdleTimer=3
CmdChar=$
DNS=192.168.0.1
Lease=86400
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=Joshua2001
Chan=0
ExtAnt=0
Join=1
Auth=OPEN
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=5
Passphrase=Tes
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x10
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x2
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
Password=
Format=0x0
Signal=0
Average=5
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
<4.41>
ERR: ?-Cmd
<4.41>
get e
SSID=WiFly-GSX-db
Pass=
Linkmon=3600
Beacon=102
Reboot=0
IF=UP
DHCP=ON
NM=255.255.255.0
GW=192.168.0.1
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1420
MatchChar=0
FlushTimer=5
IdleTimer=3
CmdChar=$
DNS=192.168.0.1
Lease=86400
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=Joshua2001
Chan=0
ExtAnt=0
Join=1
Auth=OPEN
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=5
Passphrase=Tes
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x10
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x2
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
Password=
Format=0x0
Signal=0
Average=5
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
<4.41>
Reefology
It shows data to me.
The controller only sends data every 5 minutes. You just needed to wait.
Reefology
slm222
The macro that Rimai directs everyone to try was posted in 2014. If the servers were changed would something need to be changed to point to the new servers?
No.
Although the post is old. The attachment is new and updated.
slm222
Thank you for the quick reply. I appreciate your helpful and promptness.
