Mike's RSM 500 Code
Re: Mike's RSM 500 Code
It has to go more than 82F and stay there for at least 3 seconds to be considered overheat.
modulok
Ok it's working, sorry for the false alarm. Just never had it sit right at 82 for awhile.
I moved the ph probe gettin the sump to the DT and the ph reading hasn't changed much.
Sent from my HTC One_M8 using Tapatalk
modulok
pH was reading under 7 for the past two nights...doing the calibration again. Now its around 7.5, but its still way lower than it was at 8.5. Do I need a new probe?
modulok
So I recently ditched my T5 lights for the RSM S Series LEDs. I also did some wiring cleanup, added a skimmate container using High ATO, and just got an Avast Swabbie retrofit.
During the last few days I have been playing around with the Swabbie code. Not using timing in the memory I could get the port to switch on at 4am, but that was the only time (it wasn't running every 4 hours).
So I tried adding lnevo's code for the Swabbie. Compiles fine, but the relay does not run.
When I read the custom memory location of 100 & 101, both result in 255. So I am assuming the memory locations aren't being written. Also when I manually changed the memory from 255 to 6 or 1 the relay has not turned on every six or one hours.
I am guessing maybe it has to do with this line which I do not have. I am not sure how to update it to write the memory for the Swabbie.
#define Mem_B_SwabbieRepeat 100
#define Mem_B_SwabbieTime 101
void init_memory() {
InternalMemory.write(Mem_B_SwabbieRepeat,6);
InternalMemory.write(Mem_B_SwabbieTime,1);
// Define Named Relay Ports
#define FlowPumps 1
#define Lights 2
#define Return 3
#define VortechL 4
#define VortechR 5
#define Skimmer 6
#define FanSump 7
#define HeaterSump 8
#define Reactor Box1_Port1
#define Swabbie Box1_Port2
#define Unused Box1_Port3
#define Unused Box1_Port4
#define Unused Box1_Port5
#define WCMix Box1_Port6
#define WCFlow Box1_Port7
#define WCHeater Box1_Port8
////// Setup Begin (on controller startup/reset)
// Define labels for LCD screen
ReefAngel.CustomLabels[0]="Flow Pumps";
ReefAngel.CustomLabels[1]="Lights";
ReefAngel.CustomLabels[2]="Return";
ReefAngel.CustomLabels[3]="Vortech L";
ReefAngel.CustomLabels[4]="Vortech R";
ReefAngel.CustomLabels[5]="Skimmer";
ReefAngel.CustomLabels[6]="Fan";
ReefAngel.CustomLabels[7]="Heater";
ReefAngel.CustomLabels[Box1_Port1Label] = "Reactor";
ReefAngel.CustomLabels[Box1_Port2Label] = "Swabbie";
ReefAngel.CustomLabels[Box1_Port3Label] = "";
ReefAngel.CustomLabels[Box1_Port4Label] = "";
ReefAngel.CustomLabels[Box1_Port5Label] = "";
ReefAngel.CustomLabels[Box1_Port6Label] = "WCMix";
ReefAngel.CustomLabels[Box1_Port7Label] = "WCFlow";
ReefAngel.CustomLabels[Box1_Port8Label] = "WCHeater";
ReefAngel.FeedingModePortsE[0] = Port3Bit | Port4Bit | Port5Bit; //Unused ports for testing RF module and random feedmode
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port6Bit | Port7Bit | Port8Bit; // Flowpumps,Return,VortechL,Skimmer,Fan,HeaterSump
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit ; //Reactor,Swabbie
ReefAngel.LightsOnPorts = Port6Bit; //Lights
ReefAngel.OverheatShutoffPorts = Port8Bit; //HeaterSump
// Ports that default on
ReefAngel.Relay.On( FlowPumps );
ReefAngel.Relay.On( Return );
ReefAngel.Relay.On( VortechL );
ReefAngel.Relay.On( VortechR );
// Ports that default off
ReefAngel.Relay.Off( Unused );
ReefAngel.Relay.Off( Swabbie );
ReefAngel.Relay.Off( WCMix );
ReefAngel.Relay.Off( WCFlow );
ReefAngel.Relay.Off( WCHeater );
//5 second timer for power outage detection
ReefAngel.Timer[1].SetInterval( 5 );
////// Setup End
////// Loop Begin
ReefAngel.Relay.On(Reactor);
ReefAngel.StandardHeater( HeaterSump );
ReefAngel.StandardFan( FanSump );
ReefAngel.StandardLights( Lights );
//HighATO=on, delay start Skimmer | HighATO=off, Skimmer shuts off
ReefAngel.Relay.DelayedOn( Skimmer );
ReefAngel.Relay.Off( Skimmer );
// Vortech MP40 | Constant | Lagoon | ReefCrest | ShortWave 1=10ms | LongWave 1=1s | NutrientTransport 1=10ms | TidalSwell
if ( ReefAngel.DisplayedMenu != FEEDING_MODE || ReefAngel.DisplayedMenu != WATERCHANGE_MODE ) {
if ( hour() >= 16 && hour() <= 20 ) {
ReefAngel.RF.SetMode( LongWave, 70, 30 );
} else if ( hour() >= 20 || hour() < 7 ) {
ReefAngel.RF.SetMode( ReefCrest, 40, 0 );
} else {
// ReefAngel.StandardHeater( HeaterWC, 775, 778 );
// Turn off Skimmer & FanSump & Reactor if Return Pump is off
if ( !ReefAngel.Relay.Status( Return ) ) {
ReefAngel.Relay.Override( Skimmer, 0 );
ReefAngel.Relay.Override( FanSump, 0 );
ReefAngel.Relay.Override( Reactor, 0 );
// Check the power here, the function is defined below
CheckPower();
ReefAngel.Portal( "****", "****" );
////// Custom Function
void RunSwabbie() {
int repeat=InternalMemory.read(Mem_B_SwabbieRepeat)*60;
int runtime=InternalMemory.read(Mem_B_SwabbieTime)*60;
static time_t t;
// Manual mode
if (ReefAngel.Relay.isMaskOn(Swabbie)) {
ReefAngel.Relay.Auto(Swabbie);
t=now();
if (now()-t < runtime) {
ReefAngel.Relay.On(Swabbie);
} else {
ReefAngel.DosingPumpRepeat(Swabbie,0,repeat,runtime);
void CheckPower()
static boolean PowerOutage = false;
static boolean DelayedPowerOutage = false;
// Power Outage - Leave Only Vortech Pumps active
if ( !ReefAngel.Relay.IsRelayPresent( EXP1_RELAY ) ) {
PowerOutage = true; //Expansion Relay 1 has lost power
if ( !PowerOutage ) {
ReefAngel.Timer[1].Start();
if ( ReefAngel.Timer[1].IsTriggered() ) {
DelayedPowerOutage = true;
if ( DelayedPowerOutage ) {
ReefAngel.Relay.Off ( FlowPumps );
ReefAngel.Relay.Off ( Return );
ReefAngel.Relay.Off ( Skimmer );
ReefAngel.Relay.Off ( Lights );
ReefAngel.Relay.Off ( FanSump);
ReefAngel.Relay.Off ( HeaterSump);
//set vortechs to long wave? something that ripples surface
// Power Restored
if ( PowerOutage && ReefAngel.Relay.IsRelayPresent( EXP1_RELAY ) ) {
LastStart = now();
////// Custom Function End
InternalMemory.write(Mem_B_ResetMemory,false);- lnevo
Ignore the init_memory function, it doesnt always work right. but please manually set both memory locations. One needs the runtime and the other gets the repeat value. Runtime should be 1 for one minute and repeat should be 6 for one hour.
modulok
You mean 6 for six hours, right?
So remove init_memory lines and set manually...do I need to update the controller in order to see the swabbie port activate?
I set 100 to 6, and 101 to 1...
You will not see it in the portal if thats what your looking for.
modulok
The memory values or the relay switching on? I do see the relay switch at 4am.
Sent from my A0001 using Tapatalk
You won't reliably see the port in the portal for relay activity.
You also need to call RunSwabbie(); in your loop. I don see it there which means its never getting called.
modulok
Haha OK..guess I missed it from yours...I'll give it a shot
modulok
Yup adding run swabbie worked... Thanks Lee!
modulok
So I have my Swabbie installed and working, can't wait to see the skimmer in a few days.
I've updated a few things, curiosity of Lee's code.
I tested the ATO high, when the skimmate container is full, and the skimmer went off and sent me the alert.
Tomorrow I will have to test a few more things.
EDIT: Although my ATO High is set for 'On" now and I am getting emails. I did a controller restart and it's not making a difference.
Maybe I am getting many emails because I do not have this line in?
- Although when I return the float switch down, I got a Power Restored email?!?!
- Also the skimmer does not go back to Auto when the float switch is back down. I got a fewDo I need to clear ATO for it to return to Auto?
- But I also got the Power Restored email.
- And when I manually turned on the ports, I got an email saying Skimmer Container full (maybe just a coincidence from testing ATO High).
skimmerAlert.SetDelay(3600); Code: Select all
#include <WiFiAlert.h>
#define FlowPumps 1
#define Lights 2
#define Return 3
#define VortechL 4
#define VortechR 5
#define Skimmer 6
#define FanSump 7
// Place global variable code below here
// Place global variable code above here
// #################### Setup (controller starting) ####################
ReefAngel.FeedingModePortsE[0] = Port3Bit | Port4Bit | Port5Bit; //Unused ports for testing random feeding
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit; // Flowpumps,Return
ReefAngel.LightsOnPorts = Port2Bit; //Lights
ReefAngel.OverheatShutoffPorts = Port2Bit | Port8Bit; //Lights,HeaterSump
// ON by default
ReefAngel.Relay.On(FlowPumps);
ReefAngel.Relay.On(Return);
ReefAngel.Relay.On(VortechL);
ReefAngel.Relay.On(VortechR);
// OFF by default
ReefAngel.Relay.Off(Unused);
ReefAngel.Relay.Off(Swabbie);
ReefAngel.Relay.Off(WCMix);
ReefAngel.Relay.Off(WCFlow);
ReefAngel.Relay.Off(WCHeater);
// ##### Place additional initialization code below here #####
ReefAngel.CustomLabels[Box1_Port3Label] = "Unused";
ReefAngel.CustomLabels[Box1_Port4Label] = "Unused";
ReefAngel.CustomLabels[Box1_Port5Label] = "Unused";
// 5 second timer for power outage detection
// #################### Loop ####################
ReefAngel.Relay.On( Reactor );
// ##### Place your custom code below here #####
RunSwabbie(); // Skimmer neck cleaner
SetRF(); // Set Vortech modes
CheckPower(); // Monitor for power loss
CheckSwitches(); // Monitor Float switches
if (ReefAngel.DisplayedMenu = WATERCHANGE_MODE) {
WaterchangeHeater( HeaterWC, 775, 778 );
// ##### Place your custom code above here #####
ReefAngel.Portal("modulok");
// #################### Custom Function ####################
void CheckSwitches() {
static boolean returnOverride=true;
static WiFiAlert skimmerAlert, atoAlert;
if (ReefAngel.DisplayedMenu==FEEDING_MODE || ReefAngel.DisplayedMenu==WATERCHANGE_MODE)
// HighATO=on, delay start Skimmer | HighATO=off, Skimmer shuts off
ReefAngel.Relay.Override(Skimmer,0);
skimmerAlert.Send("Skimmate+container+full!+Skimmer+shutoff.");
// If Return pump is off, kill power to others
if (!ReefAngel.Relay.Status(Return)) {
ReefAngel.Relay.Override(FanSump,0);
ReefAngel.Relay.Override(Reactor,0);
ReefAngel.Relay.Override(HeaterSump,0);
// Alert if ATO timeput flag
if (bitRead(ReefAngel.AlertFlags,ATOTimeOutFlag))
atoAlert.Send("ATO+timeout!+ATO+disabled.");
void SetRF() {
else {
void RunSwabbie() {
static time_t t;
// Manual mode
t=now();
else {
void CheckPower()
static boolean powerOutage = false;
static WiFiAlert powerAlert;
static boolean delayedPowerOutage = false;
powerOutage = true; //Expansion Relay 1 has lost power
if ( !powerOutage ) {
delayedPowerOutage = true;
if (delayedPowerOutage) {
ReefAngel.Relay.Off(FlowPumps);
ReefAngel.Relay.Off(Return);
ReefAngel.Relay.Off(Skimmer);
ReefAngel.Relay.Off(Lights);
ReefAngel.Relay.Off(FanSump);
ReefAngel.Relay.Off(HeaterSump);
ReefAngel.RF.SetMode(Constant,70,0);
powerAlert.Send("Power+lost!");
// Power Restored - return equipment back to normal power state
if ( powerOutage && ReefAngel.Relay.IsRelayPresent( EXP1_RELAY ) ) {
LastStart = now();
powerAlert.Send("Power+restored.",true);
void WaterchangeHeater(byte HeaterRelay, int LowTemp, int HighTemp)
if (ReefAngel.Params.Temp[T3_PROBE] == 0) return; // Don't turn the heater on if the temp is reading 0
if (ReefAngel.Params.Temp[T3_PROBE] <= LowTemp && ReefAngel.Params.Temp[T3_PROBE] > 0) ReefAngel.Relay.On(WCHeater);
if (ReefAngel.Params.Temp[T3_PROBE] >= HighTemp) ReefAngel.Relay.Off(WCHeater);
// #################### Custom Function End ####################
I'll take a look at your code later this week. The way my code is written it sets the override when these conditions occur so you just have to reset the ports to auto.
modulok
I modified the code a bit and not am not getting skimmate full emails. But for some reason I have power restored emails.
#define FlowPumps 1
#define Lights 2
#define Return 3
#define VortechL 4
#define VortechR 5
#define Skimmer 6
#define FanSump 7
// ON by default
// OFF by default
ReefAngel.StandardHeater(HeaterSump);
ReefAngel.StandardFan(FanSump);
ReefAngel.StandardLights(Lights);
CheckSwitches(); // Monitor float switches
atoAlert.SetDelay(3600);
// HighATO=off, Skimmer shuts off
if (!ReefAngel.HighATO.IsActive()) {
skimmerAlert.Send("Skimmate+container+is+full!+Skimmer+has+been+shutoff.");
// Alert if ATO timeout flag
void SetRF() {
else {
void RunSwabbie() {
static time_t t;
// Manual mode
t=now();
else {
void CheckPower()
LastStart = now();
I updated my code the other day. I'm using a different mechanism to delay the power outage. I dont recommend the way you are doing it with the Timer class. I'm not sire whats happening but clearly you are falsely triggering the power outage and this could cause robertos code to not send you the right alert.
Does the skimmer turn off when your float switch changes? If so the code to send the skimmer full alarm should be fine.
modulok
OK, I see you include a delay in the poweroutage code, cool! I will give it a shot and update my code later tonight.
The skimmer does shutoff when the float switch is up, and I got the email. So that seems to be working well. I am waiting for the container to actually fill up for a real test. (It might be two months unless I change to a wetter skimmate)
modulok
Not sure why, but the checkpower function isn't working right.
When I kill power to exp relay box only the return shuts off like it should. Lights stay on, skimmer, fan, heater, reactor shut off due to return being off. No email from Power Lost.
After power is returned I get emails every few minutes for Power Restored, and I hear relays but do not see anything switching on or off. The Return does not come back on (waited 5 minutes). Also the ports that shut off when return is off do not reset to auto.
I am curious what this line does. Wait for 300 seconds to signal poweroutage?
if (now()-powerOutage > 300) {
ReefAngel.Relay.Set(Return, now()%3600<300);
}Code: Select all
#define FlowPumps 1
#define Lights 2
#define Return 3
#define VortechL 4
#define VortechR 5
#define Skimmer 6
#define FanSump 7
// Vortech Variables
byte vtMode, vtSpeed, vtDuration;
// ON by default
// OFF by default
void SetRF() {
else {
void RunSwabbie() {
static time_t t;
// Manual mode
t=now();
else {
void CheckPower() {
static time_t powerOutage=false;
if (!ReefAngel.Relay.IsRelayPresent(EXP1_RELAY) && !powerOutage) //Relay Expansion NOT detected
powerOutage=now();
if (now()-powerOutage > 10) { // Wait 10 seconds before sending to avoid false alarms
if (powerOutage && ReefAngel.Relay.IsRelayPresent( EXP1_RELAY ) )
powerOutage=0;
LastStart=now();
ReefAngel.RF.SetMode(vtMode,vtSpeed,vtDuration);
// #################### Custom Function End ####################- lnevo
That line says after the power is out for 5 minutes, run the return pump for 5 minutes each hour. This way my UPS conserves power to run the mp40s
You aren't turning anything back on when the power comes up. You can either explicitly add it, or move all your on statements from setup() into loop()
modulok
Hmm ok, I will have to look into it later. Not sure I need my return pump running. I will need to do a test and see how much it uses up battery life.
On another note I woke up this am to find my tank in a power lost state...Temps dropped a few degrees. I also have a ton of power restored emails.
I uploaded my previous code for now, since I have to leave for work.
It sounds like your either having bus lock issues or you have some bad connections based on this and previous issue
modulok
modulok
It's been two months since I've updated the code, but I really need to figure out the power restored email thing. I have gotten so many over the last 18hrs (after water change). I will post my updated code tonight (going back to power outage delay timer) to see if the emails stop.
modulok
No change, still getting power restored emails every few minutes. Did a full controller reboot for good measure and no change.
Put Lee's check power code back in and did a power failure test. No power failure email. Relays did go off, but then came back on, while still on the ups battery! Now the flowpumps are in an off state (even after a full power reset on the UPS).
I am not sure what's going on here. Help!
void CheckPower() {
if (!ReefAngel.Relay.IsRelayPresent(EXP1_RELAY) && !powerOutage) // Expansion Relay NOT present
byte rfPowerOutageSpeed=InternalMemory.read(Mem_B_PowerOutageSpeed);
powerOutage=now();
ReefAngel.RF.SetMode(Constant,rfPowerOutageSpeed,0);
powerAlert.Send("Power+outage!");
if (powerOutage && ReefAngel.Relay.IsRelayPresent(EXP1_RELAY))
powerOutage=0;
LastStart=now();
modulok
Can anyone help me figure out why the power restore code is emailing me when there isn't any power change occurring?
modulok
So I was trying to get a second heater code in place that uses T3 probe, but I am getting this compile error below. I am stuck. Any suggestions?
sketch_rsms500:64: error: expected ',' or '...' before numeric constant
sketch_rsms500.cpp: In function 'void loop()':
sketch_rsms500:64: error: too few arguments to function 'void WaterchangeHeater(byte, int)'
sketch_rsms500:144: error: at this point in file
sketch_rsms500.cpp: At global scope:
sketch_rsms500:256: error: expected ',' or '...' before numeric constant
#define Mem_B_PowerOutageSpeed 102
#define Mem_I_WCHeaterLowTemp 103
#define Mem_I_WCHeaterHighTemp 105
#define FlowPumps 1
#define Lights 2
#define Return 3
#define VortechL 4
#define VortechR 5
#define Skimmer 6
#define FanSump 7
#define FugeLight Box1_Port3
#define WCMix Box1_Port5
#define WCFlow Box1_Port6
#define WCHeater Box1_Port7
#define Bad Box1_Port8
// Vortech Variables for PowerOutage
// byte vtMode, vtSpeed, vtDuration;
ReefAngel.FeedingModePortsE[0] = Port8Bit; //Unused port for testing random feeding
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port3Bit; // Reactor,FugeLight
// ON by default
// OFF by default
ReefAngel.Relay.Off(Bad);
ReefAngel.CustomLabels[Box1_Port3Label] = "Fuge Light";
ReefAngel.CustomLabels[Box1_Port5Label] = "WCMix";
ReefAngel.CustomLabels[Box1_Port6Label] = "WCFlow";
ReefAngel.CustomLabels[Box1_Port7Label] = "WCHeater";
ReefAngel.CustomLabels[Box1_Port8Label] = "Bad";
ReefAngel.StandardLights(FugeLight,22,0,6,0);
WaterchangeHeater(); // Heater control for Waterchange Heater
void CheckPower()
LastStart = now();
// If Return pump is off, kill power to Skimmer
void SetRF() {
else {
void RunSwabbie() {
static time_t t;
// Manual mode
t=now();
else {
void WaterchangeHeater(byte WCHeaterRelay, int Mem_I_WCHeaterLowTemp, int Mem_I_WCHeaterHighTemp)
if (ReefAngel.Params.Temp[T3_PROBE] <= Mem_I_WCHeaterLowTemp && ReefAngel.Params.Temp[T3_PROBE] > 0) ReefAngel.Relay.On(WCHeater); // If sensor temperature <= LowTemp - turn on heater
if (ReefAngel.Params.Temp[T3_PROBE] >= Mem_I_WCHeaterHighTemp) ReefAngel.Relay.Off(WCHeater); // If sensor temperature >= HighTemp - turn off heater
