No Graph information
My reef angel is still functioning properly and I can connect to it through the portal and ios app, but it has stopped recording any graph data or sending me email notifications. In the portal and the app when I try to graph anything it just says no data to display. I havent changed or touched anything in the code in months, so any suggestions is appreciated.
Re: No Graph information
Update the settings on the wifi attachment with this macro:
More info:
http://forum.reefangel.com/viewtopic.php?f=15&t=6337
More info:
Ill give it a shot thanks!
So I gave it a shot and its still a no go, but now its worse because I cant connect to it at all anymore. It is connected to the internet though.
this is the response from terra term
ERR: ?-Cmd
<4.00> get e
wifly-GSX Ver 4.00.1, Apr 19 2013 11:48:31 on RN-131
Beacon=102
Reboot=0
IF=UP
DHCP=ON
IP=192.168.1.2:2000
NM=255.255.255.0
GW=192.168.1.1
HOST=104.36.18.155:80
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1420
MatchChar=0
FlushTimer=5
IdleTimer=3
CmdChar=$
DNS=192.168.1.1
Name=www.reefangel.com
Backup=rn.microchip.com
Lease=86400
FTP=198.175.253.161:21
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=XXXXXXX
Chan=0
ExtAnt=0
Join=1
Auth=OPEN
Mask=0x1fff
Rate=12, 24 Mb
Linkmon-Infra=5
Linkmon-AP=3600
Passphrase=XXXXXXXX
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x10
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
TIMEADR=64.90.182.55:123
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x2
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
DeviceId=ReefAngelWifi
Password=
Format=0x0
Signal=0
Average=5
BCAST=255.255.255.255:55555
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
<4.00>
Looks good.
IP address is 192.168.1.2
Is it the IP address you are trying to connect?
Yep, It seems to be connecting to the internet fine, I logged into my router and it shows it on the wifi, but I just cant communicate with it through the portal or my app.
Did you check if the port forwarding is setup and pointing to that IP address?
Yes i did and it still is. The thing thats odd is it hadent updated since december 23 or so on the portal but it shows it updated yesterday when i was running the terra term
I just checked it on the multimeter cable it seems ok.
Tagging along, because I am having the same problem (i.e. not creating graphs from the mobile app or the web portal).
I am also using the wifisendalert to send SMS text messages to my phone
viewtopic.php?f=12&t=2373&p=18083&hilit=wifisendalert#p18083
Which does not work any more either (I'm not sure whether it is related but I thought it was worth mentioning). I received my last notice via text from info@reefangel.com on December 11th, 2016.
I am running the Reef Angel version 1.1.3 library.
Also I just connected through the app while im on my home network. I just changed the ip address in the app to 192.168.1.2 port 2000 and it works fine.
Did you try the first suggestions he responded to me with? From what I understand is the servers were changed and the wifi attachment needs to know where to look now.
Not yet. I will try it. Thanks.
well I didn't get mine working so don't thank me just yet lol
It worked for me. I can now see the graphs in the portal and on the iOS app. My text alerts are working now too. Thanks.
If that works fine inside your own network, the problem is related to the port forwarding.fckgravity wrote:Also I just connected through the app while im on my home network. I just changed the ip address in the app to 192.168.1.2 port 2000 and it works fine.
Are you sure you have it pointing to the correct IP address 192.168.1.2?
Im pretty sure its right at least as far as I can tell, It worked for over a year and I didn't change anything in the router after I did the terra term thing.
I did change it in the router last night though, I removed it and reinstalled it on that port. It does update every 5 minutes on the portal now but it still says unreachable address.
I noticed this yesterday actually. I no longer see the graphs for PWMA/B oddly enough. IP for the wireless adapter is still the same and I can see portal activity. Also have port forwarding.
Read a few more posts and see that some changes happened back in December. I updated macro and ran it, seems to have worked. Thanks.
