- 1. Clarification that the Timeout (sec) option shuts down the pump after running that many seconds.
2. Assuming #1 is correct, how long does that timeout last by default?
Wizard clarification for Water Level ATO
jcjrogers
Questions regarding Water Level ATO in the Wizard:
Re: Wizard clarification for Water Level ATO
The ATO timeout is permanent until you clear it through the joystick or using any app.
jcjrogers
Ok so my idea won't work... at least not the way I envisioned. I guess I can either try to program it as a dosing pump or just let it run with a long enough timeout to where if triggered, there has to be a problem. It shouldn't be an issue as the Spectrapure dosing pump I'm using is really designed for this application (at least it is marketed that way).rimai wrote:The ATO timeout is permanent until you clear it through the joystick or using any app.
You can always code it to reset the ATO timeout after a certain period of time
