Problem with multi-channel water level expansion
dedvalson
Post by dedvalson »
I have the 4 channel water level expansion on my system, it has been there for over a year, probably close to 2.
It has had a problem off and on that seems to be getting worse recently. Occasionally all 4 channels will read 0%. This will usually happen at a random time and it will last anywhere from a few seconds to as long as 20 minutes. Then suddenly everything comes back to normal.
Any suggestions?
Don
Re: Problem with multi-channel water level expansion
Strange.
Did you try using a different port on the hub?
Does it cause a bus lock when they report zeros?
dedvalson
Post by dedvalson »
It does not cause a bus lock, all the other devices keep working fine.
I will try another hub port.
Don
Smotz
Post by Smotz »
i had this too. To mitigate, i put code in there to ignore the '0' water level reading. Also, i think changing the usb port helped a bit.
what version of the libraries? I know there have been improvements with the water level functionality in the latest.
