Reef angel plus wont upload code
ecam
Post by ecam »
It will start and then freeze in middle (solid red light) and then reboot itslef. FYI it also does this when I stick the usb end into my computer initially. I have the cord correct with the green cord starting from the left to right and the black cord being flush to right of the box....
Using Port : \\.\COM5
Using Programmer : stk500v2
Overriding Baud Rate : 115200
avrdude: Recv: . [ff]
avrdude: Recv: . [12]
avrdude: Recv: . [00]
avrdude: Recv: . [02]
avrdude: Recv: . [0c]
avrdude: Recv: . [04]
avrdude: Recv: . [1e]
avrdude: Recv: [20]
avrdude: Recv: ` [60]
avrdude: Recv:
avrdude done. Thank you.
ecam
Re: Reef angel plus wont upload code
Post by ecam »
bump
can you verify that arduino is using the proper comm port?
also, if the comm port is correct, try to power cycle the reefangel. (unplug it, wait a couple seconds and then plug it back in).
ecam
Post by ecam »
Hey curt.
I did those steps already. Same thing happens for the last few days.
ecam
Post by ecam »
So i power cycled.... rebooted.... confirmed the com 5 is correct..... to no avail
it dies at receiving that last line 60. has to mean something. Im getting ready to go on vacation and i need this new upload to maintain tank.
Can anyone please help me on this......
You mentioned having another one.
Does the other one program fine with same com port?
Try the other programming cable. It should give a different com port though.
ecam
Post by ecam »
That is what started everything. I used the spare one that I found and it attached as com 3.... and then started doing this stuff.
When I try to use the cord I've been using the all time for both controllers.
COM3 doesn't work at all (never did)
COM5 gives me that error posted.
I uploaded to the RAplus in the Display and it works just fine. when I plug in same cord it immeidately reboots controller and then freezes on that line
ecam
Post by ecam »
Can I please get any guidance on this from the guru. I have a calcium reactor that really needs to be under ph control. But I can't update any code. I'm concerned about wiping out and re installing because the install on my other computers refuse to recognize or install the driver for the time cord
There is only two components in the equation.
Head unit and programming cable.
If you know for sure that your cable is good, the only thing left is your head unit and vice versa.
Unless you are not picking the correct com port or choosing the wrong board, which it seems you are not.
ecam
Post by ecam »
How would I choose the wrong board. its always been set to reef angel plus.... and the cord works fine on that setting with my Display reef angel.
Like said.... I found the a ttl cord laying around (from the previous owner). so I figured I didn't need to keep swapping cords... so plugged in the new cord and all this stuff started happening. just on the frag tank reef angel.
So I guess I need another RMA? for it...
can you also point me to a file that I can use to load the reef angel to another computer. whenever I try it keeps failing when it comes to the part that says "please insert ttl to computer".
it can never find the drivers. I've tried on two pcs and one Mac
http://www.reefangel.com/download.html for the Reef Angel Installer.
What do you mean failing?
ecam
Post by ecam »
It won't upload the driver. It just sits on that and if I bypass it. It won't recognize anything com port at all. It just grayed out
Try the drivers from manufacturer:
http://www.ftdichip.com/Drivers/VCP.htm
