Right now I have my RA set up to turn off my port when a certain temp is reached.
Is there sample code / examples that turns on / off the port in a range? Hopefully I'm asking it correctly but what I'd like to be able to do is limit the plug / power to the heater only when needed. As opposed to it always being on now. It may toggle the port on/off more so maybe not a good idea?
Or maybe a second question is how do you all usually manage heaters? I have not typically run them in the past but for some reason my 40 breeder here was dipping down to 73 degrees
