ATO High and Black Screen
dhave
Post by dhave »
I've problem since two week with RA.
I'm monitoring two level woth two probe.
The first probe show the sump water level and contro refill pump (60 sec time out).
The second probe show the re-fill tank water level and the refill pump (timeout disable).
When the ATO High (second probe) turn on, some time the controller show black screen, but keep working. I've to turn it off and start it again.
Thi is the program i'm using now:
/ Autogenerated file by RAGen (v1.1.0.126), (01/15/2012 16:39)
// Memory_011512_1639.pde
#include <Phillips6610LCDInv.h>
#include <avr/pgmspace.h>
#include <ReefAngel_EEPROM.h>
Phillips6610LCDInv e;
    e.lcd_init();
    e.lcd_clear(COLOR_WHITE,0,0,132,132);
    e.lcd_BacklightOn();
    InternalMemory.MHOnHour_write(13);
    InternalMemory.MHOnMinute_write(30);
    InternalMemory.MHOffHour_write(21);
    InternalMemory.MHOffMinute_write(30);
    InternalMemory.MHDelay_write(00);
    InternalMemory.StdLightsOnHour_write(13);
    InternalMemory.StdLightsOffHour_write(22);
    InternalMemory.LEDPWMActinic_write(100);
    InternalMemory.LEDPWMDaylight_write(100);
    InternalMemory.WM1Timer_write(200);
    InternalMemory.HeaterTempOn_write(245);
    InternalMemory.HeaterTempOff_write(255);
    InternalMemory.ChillerTempOn_write(265);
    InternalMemory.ChillerTempOff_write(275);
    InternalMemory.OverheatTemp_write(1750);
    // display the values
    char buf[128];
    sprintf(buf, "MH %2d:%02d-%2d:%02d,%d", InternalMemory.MHOnHour_read(), InternalMemory.MHOnMinute_read(),
                                         InternalMemory.MHOffHour_read(), InternalMemory.MHOffMinute_read(),
                                         InternalMemory.MHDelay_read());
    e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW, buf);
    sprintf(buf, "Std %2d:%02d-%2d:%02d", InternalMemory.StdLightsOnHour_read(), InternalMemory.StdLightsOnMinute_read(),
                                          InternalMemory.StdLightsOffHour_read(), InternalMemory.StdLightsOffMinute_read());
    e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*2, buf);
    sprintf(buf, "LED A: %d%% D: %d%%", InternalMemory.LEDPWMActinic_read(), InternalMemory.LEDPWMDaylight_read());
    e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*3, buf);
    sprintf(buf, "WM1: %ds", InternalMemory.WM1Timer_read());
    e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*4, buf);
    sprintf(buf, "WM2: %ds", InternalMemory.WM2Timer_read());
    e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*5, buf);
    sprintf(buf, "F: %ds", InternalMemory.FeedingTimer_read());
    e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*6, buf);
    sprintf(buf, "S: %ds", InternalMemory.LCDTimer_read());
    e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*7, buf);
    sprintf(buf, "H On: %d -> %d", InternalMemory.HeaterTempOn_read(), InternalMemory.HeaterTempOff_read());
    e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*9, buf);
    sprintf(buf, "C On: %d -> %d", InternalMemory.ChillerTempOn_read(), InternalMemory.ChillerTempOff_read());
    e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*10, buf);
    sprintf(buf, "PH %d - %d", InternalMemory.PHMax_read(), InternalMemory.PHMin_read());
    e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*11, buf);
    delay(10000);
    sprintf(buf, "OH: %dF", InternalMemory.OverheatTemp_read());
    sprintf(buf, "ATO L: %ds (%dh)", InternalMemory.ATOTimeout_read(), InternalMemory.ATOHourInterval_read());
    sprintf(buf, "ATO H: %ds (%dh)", InternalMemory.ATOHighTimeout_read(), InternalMemory.ATOHighHourInterval_read());
    sprintf(buf, "DP1: %2d:%02d", InternalMemory.DP1OnHour_read(), InternalMemory.DP1OnMinute_read());
    sprintf(buf, "     %ds", InternalMemory.DP1Timer_read());
    sprintf(buf, "DP2: %2d:%02d", InternalMemory.DP2OnHour_read(), InternalMemory.DP2OnMinute_read());
    sprintf(buf, "     %ds", InternalMemory.DP2Timer_read());
    e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*8, buf);
    delay(10000);
Re: ATO High and Black Screen
I don't think this is it.
This is an internal memory file
dhave
Post by dhave »
rimai wrote:I don't think this is it.
Where i find it?
It should be the code you uploaded to the controller.
Did you generate from RAGen?
If so, it starts with RA_
dhave
Post by dhave »
Ok. Here it is:
// Autogenerated file by RAGen (v1.1.0.126), (01/15/2012 16:34)
// RA_011512_1634.pde
#define DisplayImages
#define DateTimeSetup
#define ATOSetup
#define MetalHalideSetup
#define DirectTempSensor
#define SingleATOSetup
#define StandardLightSetup
#include <ReefAngel_Wifi.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
    ReefAngel.SetTemperatureUnit(1);  // set to Celsius Temperature
    ReefAngel.FeedingModePorts = B00000000;
    ReefAngel.WaterChangePorts = B00000000;
    ReefAngel.OverheatShutoffPorts = B00000000;
    ReefAngel.LightsOnPorts = B00000000;
    ReefAngel.Relay.On(Port7);
    // Specific functions
    ReefAngel.StandardLights(Port1);
    ReefAngel.SingleATOLow(Port2);
    ReefAngel.StandardLights(Port3);
    ReefAngel.SingleATOHigh(Port4);
    ReefAngel.MHLights(Port5);
    ReefAngel.StandardFan(Port6);
    ReefAngel.StandardHeater(Port8);
Try enabling WDT when you generate the PDE.
On RAGen, make sure that WDT is checked on the features tab.
dhave
Post by dhave »
rimai wrote:Try enabling WDT when you generate the PDE.
It is not checked, the "watch dog". You think is it the problem?
Now the RA is on black screen and still working with light on in night time... :x
Yes, make sure it is checked, generate the code again and upload to RA.
dhave
Post by dhave »
watchdog enable, second ATO sensor removed.
Still have blak screen every 2-3 days... the RA controller stop working...at midnight white light are still on... i have to suht down ad restart... then everything start working again.
At today i have removed heating and cooling (this "crash" cause the heater to increase/decrease temperature over limits.
If i will remove also the light...well... there will been nothing on the RA...
I think you have wrong paths on your RAGen which is not turning the WDT on.
Please correct the paths according to this post:
http://forum.reefangel.com/viewtopic.php?p=5291#p5291
