Adding relay expansion and ph expansion
AlanM
Post by AlanM »
I have an RA+ which has been running the same code for about a year with a single expansion, the 16 channel dimmer.
I am now hooking up a used expansion hub and connecting my dimmer expansion, a used relay expansion box, and the ph expansion.
If I just reboot the RA+ I figured I would not need to load new code to the RA+ and I would at least see the extra outlets and probe in the portal, but that isn’t happening.
Is that how it should work or do I have to include statements in my code and recompile and load it in order to get it to see the new probe and relay box?
Re: Adding relay expansion and ph expansion
You need to upload a new code and enable the expansion modules you are connecting.
AlanM
Post by AlanM »
OK. Just refer to them in a code statement to get those included or specifically include at the top somehow?
AlanM
Post by AlanM »
Nevermind. I hadn't worked in the code in so long I forgot where to look for things.
It's ReefAngel.AddPHExpansion(); right?
Anything special in setup() to add the relay expansion? I didn't see that one in ReefAngel.h
AlanM
Post by AlanM »
Nevermind again, heh. I saw it get recognized as a module in the Arduino GUI and it all compiled so I think I'm good.
I've been gone so long I hadn't seen that you released the Star. Nice. Gotta get me one at some point.
