LCD no longer going to sleep.
I reloaded my RA Plus controller tonight to test the latest public build and everything went well. I was testing some general changes to the code and now the LCD screen is no longer going to sleep like it was before. It stays on forever. I uninstalled and reinstalled the RA arduino IDE and reloaded the wizard sketch from a fresh IDE install and the LCD is still staying on so the time. Halp.
Re: LCD no longer going to sleep.
Have you changed internal memory values?
Can you post your code?
What is the timeout period for the screen? I just got out of bed to look at it and it was off but I haven't touched it in and hour. Could have sworn earlier when it was working that it turned off about about 30 seconds... I can give you the code tomorrow bit its bare bones arduino RA Wizard code with zero modifications.rimai wrote:Have you changed internal memory values?
OK, tried it again and i think it is working. Weird because i swore that it was sleeping after about 30 seconds before. Ill keep an eye on it and let you know if it acts weird. Thanks rimai!rimai wrote:10 minutes if you have not changed.
