Graph Data Doesn’t Load
icecool2
Post by icecool2 »
I’ve been noticing that graph data takes longer and longer to load both in the iOS app and using the U-App. It is to the point t where even after minutes I can’t get the data. Is this being phased out?
Re: Graph Data Doesn’t Load
No. Let me look into it.
I had to delete all history, but it should be good now.
icecool2
Post by icecool2 »
Loads in a flash now. Thanks!
topjimmy
Post by topjimmy »
icecool2 wrote:Loads in a flash now. Thanks!
I am having the same problem with the graphs, can you do the same for me?
Sent from my SAMSUNG-SM-G935A using Tapatalk
Unrelated.
That problem was a server side issue that was affecting everyone.
On your case, the controller is not sending data to the portal.
Double check your controller and Wi-Fi attachment.
topjimmy
Post by topjimmy »
Hmm I'm using a diy ethernet mod. Maybe it can't pass the data into the the portal the same way.
Can you post your code?
Maybe the code you have is pointing to the old server.
topjimmy
Post by topjimmy »
rimai wrote:Can you post your code?
Web Server
A simple web server that shows the value of the analog input pins.
using an Arduino Wiznet Ethernet shield.
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
* Analog inputs attached to pins A0 through A5 (optional)
created 18 Dec 2009
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x02 };
IPAddress ip(192,168,1, 177);
IPAddress remoteserver(198,171,134,6); // www.reefangel.com
EthernetClient clientout;
unsigned long lastmillisout=millis();
unsigned long lastmillisin=millis();
boolean sending=false;
char strout[600];
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(2000);
void setup() {
// Open serial communications and wait for port to open:
Serial.begin(57600);
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// start the Ethernet connection and the server:
Ethernet.begin(mac);
server.begin();
// Serial.println(Ethernet.localIP());
void loop() {
// listen for incoming clients
EthernetClient client = server.available();
if (client) {
// Serial.println("new client");
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
while (client.available()) {
char c = client.read();
if (sending==false) Serial.write(c);
while (Serial.available()){
memset(strout,0,sizeof(strout));
int b=Serial.readBytesUntil('>',strout,sizeof(strout));
// Serial.flush();
client.print(strout);
client.print(">");
// char c = Serial.read();
// client.print(c);
if (millis()-lastmillisin>2000)
// Serial.println("Timeout incoming");
Serial.flush();
client.stop();
Serial.flush();
client.stop();
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
// Serial.println("client disonnected");
if (Serial.available())
memset(strout,0,sizeof(strout)-1);
int b=Serial.readBytesUntil('\n',strout,sizeof(strout)-1);
Serial.flush();
// Serial.println(b);
// Serial.println("Connecting");
if (b>10)
sending=true;
// Serial.println(strout);
// Serial.println(" HTTP/1.0");
// Serial.println();
if (clientout.connect(remoteserver, 80))
// Serial.println("Connected");
// while (Serial.available()){
// clientout.print(c);
clientout.println(strout);
// clientout.println(" HTTP/1.0");
clientout.println();
while (clientout.available()) {
char c = clientout.read();
Serial.print(c);
if (millis()-lastmillisout>8000)
// Serial.println("Timeout connected");
clientout.stop();
sending=false;
if (!clientout.connected())
clientout.stop();
sending=false;
// Serial.println("Timeout global");
clientout.stop();
sending=false;
// GET /index.html HTTP/1.0
//GET /status/submitp.aspx?t1=806&t2=0&t3=0&ph=441&id=test&em=0&rem=0&key=&atohigh=0&atolow=0&r=0&ron=0&roff=255 HTTP/1.0
//GET /status/submitp.asp?t1=806&t2=0&t3=0&ph=441&id=test&em=0&rem=0&key=&atohigh=0&atolow=0&r=0&ron=0&roff=255 HTTP/1.0
//Host: forum.reefangel.com
//Connection: Keep-Alive
Sent from my Lenovo TAB 2 A10-70F using Tapatalk
New server ip address is 104.36.18.155
Change this:
To this:
IPAddress remoteserver(104,36,18,155); // forum.reefangel.com
topjimmy
Post by topjimmy »
rimai wrote:New server ip address is 104.36.18.155
Change this:
To this:
Thanks, I'll try it this weekend.
topjimmy
Post by topjimmy »
ok changed it.
Can you tell if its posting any data?
Yes, your banner is updating.
topjimmy
Post by topjimmy »
rimai wrote:Yes, your banner is updating.
Great success!
Thanks again.
