i want when the float active then skimmer is auto,on or delayedon to override
when the float is deactive it turns off but when active again it turns back to auto,on or delayedon to override
im doing this
if(ReefAngel.HighATO.IsActive()!=1){ReefAngel.Relay.Override(SKIMMER,0);} else {ReefAngel.Relay.Override( SKIMMER,2 );}and it is ignoring the relay off for waterchangemode,feedmode but the delayon is working
full code
// Define Custom Memory Locations
#define Mem_B_AtoHourInterval 101 //MB101
#define Mem_B_LightsOffPerc 102 //MB102
#define Mem_I_ReturnDelay 103 //MI103
void init_memory() {
// Initialize Custom Memory Locations
InternalMemory.write(Mem_B_AtoHourInterval,1); //MB101 "(Mem_B_AtoHourInterval,X)"X=hour
InternalMemory.write(Mem_B_LightsOffPerc,0); //MB102
InternalMemory.write(Mem_I_ReturnDelay,300); //MI103 "(Mem_I_ReturnDelay,X)"X=sec
// Define Relay Ports by Name
#define AUTOTOPOFF 1
#define SKIMMER 2
#define BLUELED 3
#define WHITELED 4
#define HEATER 5
#define POWERHEAD 6
#define FAN 7
#define RETURN 8
//dimmingchannel call out
// 0 blue led channel
// 1 white led channel
// 2
// 3
// 4 powerhead left
// 5 powerhead right
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit | Port8Bit ;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit | Port8Bit ;
ReefAngel.LightsOnPorts = Port3Bit | Port4Bit ;
ReefAngel.OverheatShutoffPorts = Port5Bit ;
// ReefAngel.Relay.On( SKIMMER );
ReefAngel.Relay.On( POWERHEAD );
ReefAngel.Relay.On( FAN );
ReefAngel.Relay.On( RETURN );
// Ports that are delayed on
ReefAngel.Relay.DelayedOn( SKIMMER );
ReefAngel.SingleATO(true, AUTOTOPOFF , InternalMemory.ATOExtendedTimeout_read(), InternalMemory.read(Mem_B_AtoHourInterval));
ReefAngel.StandardHeater ( HEATER );
ReefAngel.PWM.Channel0PWMParabola();
ReefAngel.PWM.Channel1PWMParabola();
//REMOVE ReefAngel.DCPump.DaylightChannel = None;
//REMOVE ReefAngel.DCPump.ActinicChannel = None;
//REMOVE ReefAngel.DCPump.ExpansionChannel[0] = None;
//REMOVE ReefAngel.DCPump.ExpansionChannel[1] = None;
//REMOVE ReefAngel.DCPump.ExpansionChannel[2] = None;
//REMOVE ReefAngel.DCPump.ExpansionChannel[3] = None;
ReefAngel.DCPump.ExpansionChannel[4] = Sync;
ReefAngel.DCPump.ExpansionChannel[5] = AntiSync;
//if ( ReefAngel.HighATO.IsActive() == 1 ) {ReefAngel.Relay.Override( SKIMMER,2 );} else {ReefAngel.Relay.Off( SKIMMER );}
//REMOVE if ( ReefAngel.HighATO.IsActive() != 1 ) ReefAngel.Relay.Off( SKIMMER );
//C blue led relay port 3/BLUELED +dimming channel 0
if (ReefAngel.PWM.GetChannelValue(0) > InternalMemory.read(Mem_B_LightsOffPerc)) {
// Value over MB102
ReefAngel.Relay.On(BLUELED);
} else {
// otherwise, value IS MB102 or less (which should never happen)
ReefAngel.Relay.Off(BLUELED);
//C white led relay port 4/WHITELED +dimming channel 1
if (ReefAngel.PWM.GetChannelValue(1) > InternalMemory.read(Mem_B_LightsOffPerc)) {
// Value over MB102
ReefAngel.Relay.On(WHITELED);
} else {
ReefAngel.Relay.Off(WHITELED);
//C First X minutes after feeding mode disable return
static time_t FMTimer=0;
if (ReefAngel.DisplayedMenu == FEEDING_MODE) FMTimer=now();
if (now()-FMTimer >= 0 && now()-FMTimer < InternalMemory.read(Mem_I_ReturnDelay))
{ReefAngel.Relay.Off(RETURN);}else{ReefAngel.Relay.On(RETURN);}
ReefAngel.Portal( "troylong45" );
