Relay Expansion Cable Question
sbidny
Post by sbidny »
Maybe a strange question...
Is it best (e.g., less cross-talk, better over longer runs, more shielding) to run a long VGA cable from the relay box to the relay expansion and a short USB cable to the expansion hub? Or would it be better to run a long USB cable from the hub to the relay expansion and a short VGA cable / coupling from the relay expansion to the box?
Or does it really just depend 100% on the quality of the cables?
-Steve
Re: Relay Expansion Cable Question
Extend the svga
sbidny
Post by sbidny »
Thanks. Will do. Can I ask why?
Whatever is after the hub doesn't carry the bus signal.
sbidny
Post by sbidny »
But both the USB cable to the relay expansion and the SVGA cable to the relay box are after the (expansion) hub.
Sorry. I wanted to say the relay expansion module not the hub
sbidny
Post by sbidny »
Got it. Thanks!
